Question about Vtech 5.8GHz Expandable Cordless Phone System with Digital Answering Machine
How to change # of rings before it starts recording
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vtech Master
  • 102,366 Answers
Since you neglected to specify the model of your VTech 5.8GHz cordless system I can only suggest you enter it into the search box here to download the manual to learn how to switch modes.
Posted on Dec 12, 2012
  • kakima Dec 12, 2012
1992 banshee starts up and dies and low compression how to tell if rings are bad
Pull the plugs and run a compression test . record readings . now squirt some oil into the spark plug holes and redo the compression test . record readings . if the compression was higer on the second test , the rings are bad , if not the valves are bad
Feb 24, 2014 | Yamaha Motorcycles
How to change recording on day/ night mode
This depends what voicemail you have, SVM OR TVM. and you need to know what group rings in each mode SVM day *47 (voicemail extension number) (PIN number) *38801 record STORE NIGHT *47 (voicemail extension number) (PIN number) *38811 record STORE TVM voicemail extension number (500 or 200) #6* (ringing group number) option 3 then 1 then 1 follow the prompts
Aug 12, 2013 | Panasonic BTS KX-DT343-W-NR Digital Corded...
Change from voice command to ring tone
This is as easy as any one can do go the main menu entertainment then select record sound and there you can start singing after finishing recording save the recorded file and then search the recorded file in the music go that file and select option then select use tone after that select as set as ringtone.Set the file then make a call to your number then there you can here your recorded ring tone. var geo_Partner = '687b82b2-54e8-44dc-93c0-87c73f39cdb0'; var geo_isCG = true;
Jun 10, 2011 | LG Cell Phones
Selecting a custom recording.
I was told that the day and night settings in the local applications must be the same. It is in your night call routing table that you need to place the extension in order for the system to know which recording to play when. Then, your system will play the application when it is set in night mode. Hint: When you place the extension in the call routing tables make sure the extension is placed ABOVE the +ALL CALLS line, if applicable, and your ring-in-destination is set to your appropriate application recording. I hope this helps.
j
Dec 15, 2008 | Inter-Tel Axxess Corded Phone
How to off the vibration of china mobile GSM S6 ? my mobile is named blueTooth plz help me
just press and hold the '#' button for 3 seconds and the vibration mode will be deactivated. :-)
Nov 11, 2008 | Cell Phones
Problem finding saved sound
Symbian OS/S60 phone: With the Voice Recorder on the screen, open Options. Select Go To Gallery. All the recordings you have saved can be accessed from the Gallery. You should see a list of recorded tunes. Highlight a recording, open Options and choose "Set as ringing tone." Windows Mobile phone: When you are still in the Voice Recorder, highlight a recording in the list and open the Menu. Select Set As Ringtone.
If your phone menu doesn't show the Set As Ringtone choice at all, you have to set it manually. Go to the Home screen, push Start, and open File Manager. You have to move the recording from the folder /Storage/My Documents/Notes to the folder /Storage/Application Data/Sounds. Then, go to the Start menu and launch Settings. Select Sounds, open Ring Tone, and pick up the recorded ring tone.
Jun 02, 2008 | Samsung SCH-u340 Cellular Phone
Norstar M7310 auto attendant problem
As far as changing the # of rings, that may be your phone company. Feature 983 will get you in to change to number of rings. It goes as follows:
Feature 983
System coordinator mailbox # and password
OK
AA
Lines
Enter Line Number
OK
Table
Rings
CHNG
Enter the desired number of rings
If after changing the number of rings the Auto atendant does not pick up at all, You have to call your phone company and set up the second delay through them. We had the same problem here.
Mar 27, 2008 | NorStar Meridian M7310 Phone
Phone rings many times with no answering message coming on and no messages recorded
I can't seem to get the security code entered.  It won't change.  None of the numbers will change when I try to set it up.
Jan 28, 2008 | GE 29878GE1 Digital Answering Machine
Howto change ring times for audiovox answer machine
how can I set the proper day and time on my answering machine same as above Audiovox AXT847
Nov 29, 2007 | GE 29878GE1 Digital Answering Machine
How to change Flash timing
The only reference to flash timing I can find in the manual is shown below for you, also here is link to manual :
I hope it helps !
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
If you have Call Waiting service and a call waiting
tone sounds while you are on a call, press talk/flash
on the handset or flash/find hs on the base to accept
the waiting call. There is a short pause, and then you
will hear the new caller. To return to the original
caller, press talk/flash on the handset or flash/find
hs
on the base again.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
answering system plays the outgoing message. You can set the ring time to answer
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select a Ring Time (Toll
Saver, 2 Times, 4 Times, or 6 Times).
3) Press the OK soft key. You will hear a confirmation tone.
Setting the Record Time
Record Time sets the duration for recording the incoming messages. You have three
record time options. The options "1 minute" or "4 minutes" set the duration for
recording the incoming messages. "Announce only" answers the call but prevents
the caller from leaving a message.
1) Enter the Answ. Setup menu, and then the Record
Time submenu (see "Entering the Menu" on page 16).
2) Press volume up/down to select Record Time
(1 Minute, 4 Minutes, or Announce Only).
May 03, 2007 | Uniden TRU8885-2 Cordless Phone
Vtech 5.8GHz Expandable Cordless Phone System with Digital Answering Machine Logo
Top Vtech Lands Phones Experts
David Burbee
David Burbee
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
