Hi i have a laney guitar amp which works perfect but cuts out the sound and comes back on when it feels like it , ive tried to find the cause but im left stumped all the components seem to work fine and i cant find any short circuits or other reason would it be a component cutting out after heating or is it somthing else ?
    Novelist:
  • 169 Answers
Could be a dry solder joint, turn it off and then check all connections , use a magnifying glass, makes life easier.
Posted on Apr 30, 2008
Why do my laney 100 reverb combo lights come on but no sound?
First, plug your guitar and cable into a different amp to make sure the problem is the amp. Then check to see if you have output from any headphone jack or effects loop. If so your problem is in the power amp section. If not, it's likely the preamp section. Whichever section it is, it will most likely need to go to the shop.
May 21, 2016 | Laney Music
Am getting a bad buzzing noise from my laney lc15
Bad connection? Loose fittings? I used to get a crackle from my amp when I turned the volume or balance knobs. A quick spray of WD 40 down the shaft after removing the knobs fixed it.
Mar 13, 2016 | Laney LC15-110 Guitar Combo Amplifier (15...
I bought a Fender Frontman 212R back in March of this year. It worked brilliantly for almost six months, until July 26th, when during a jam session, the audio randomly cut out. Upon inspection, it appeared...
Try using your guitar cord to plug in and out of the headphone jack several times while unit is on. There is a circuit that disconnects the speaker when using headphones and the circuit is activated when something is plugged into the headphone jack. This "switch" can get dirty and cause the can get dirty and cause the problem you describe.
Aug 26, 2011 | Fender FM212 Solid State Electric Guitar...
My Laney VS30 212 at band practice last week decided to intermittently cut out, but not fully just the volume would drop out then return about 5 mins later. Not sure if this was a common problem. It might...
Sounds like output valve, if the amp is more than few hundred hours then suspect this for sure. I don't know much about this amp specifically but does the sound fade/return suddenly or over a few seconds? Try running it with the back off and fan on the valves etc. Then play at loudness where problem occurs and see if any improvement. Remember that at band practice you always play much louder than you think and put a lot of stress on it.
May 03, 2011 | Laney VC30-212 VC Series 30 Watt Class A...
Hi ive had a fishman pick up installed under saddle of my accoustic guitar its fine but something is wrong becuase wen im slapping the strings and tapping guitar the sound goes very quiet for around 1...
It is possiblle that the sudden pulse from the pickup due to tapping is saturating the input of your amplifier, and that is what actually kills the signal. Try this into a different amp as a test. Once you do the test I can offer some suggestions to try.
Apr 23, 2011 | Fishman PRO AG-094 Under Saddle Acoustic...
Hi,I just bought a Roland FS 1 footswitch.I have a Laney AOR 100 tube amp which takes a Laney FS 1 footswitch.I was hoping the Roland would work with my Laney but it doenst.I bought the Roland used as well...
OFTEN Roland has the opposite sense of normally closed contacts versus normally open. Test the switch with any continuity tester or an ohmmeter to see that the contacts work and come out to the switch. ALSO some amps require a TRS type connection (three wire plug) and others do not. From the schematic it appears that the Laney may REQUIRE a normally closed contact. There is also a pull switch involved that you MAY have to change the state of for operation of the pedal.
Here is the scheamtic for your amp:
http://elektrotanya.com/laney_aor100h_sch.jpg/download.html
Scroll down to the link at the page "Get Manual" and click to download. It is a JPG type file.
Apr 22, 2011 | Roland FS1 Footswitch Pedal Switch
I have an intermittent trouble with my Laney LV 100, intermittent crackling sound in sequence with the power light getting dimmer. this usually happen with high volume playing in chords. To describe more,...
clean all "vr" (variable resistors) like volume bass treb etc, sounds like bad contacts. this happens due time while they oxidating. maybe helps. use "contact" spray for best result
Feb 27, 2011 | Laney LV100 65 Watt 1X12 Guitar Combo
It lights up but there's no sound what so ever... /Nicke
Hi, when ever an amplifier comes on and no sound with it,it means that you will need to replace the sound IC that controls the sound that comes out from the output.
When you replace it the amplifier will be fine.
Have a nice day.
Feb 22, 2011 | Laney GH50L 50 Watt All Tube Guitar Head
My Laney VC30 Guitar valve amps volume keepd fading in
CHANGE THE TUBES. ARITHEBASSPLAYER
Mar 25, 2009 | Music
144 people viewed this question
 Grubhead
Grubhead
