Question about Kenmore 7746 Gas Range
Whistling sound when gas stove burners are used
gwshaw71
  • 83 Answers
SOURCE: gas stove top burners
Make sure nothing is blocking burner tubes and burner tops. All holes need to be free and clear. If that dont work replace your inlet valve were your gas lin goes in.
Posted on Dec 08, 2007
daddy1264
  • 76 Answers
SOURCE: Kenmore gas stove
replace the spark module
Posted on Jan 03, 2009
TheMobilian
  • 8220 Answers
SOURCE: The ignition spark for my gas stove won't stop flicking....
On the shaft of the burner control they mount a small $5 switch. It is fairly simple to replace.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jan 17, 2009
jumptrout51
  • 3361 Answers
SOURCE: oven burner makes a popping or whistling sound during baking cycl
STOP>>>>STOP{>>>STOP>>>
You have a gas leak in the oven.
Get this fixed immediately.
Posted on Feb 21, 2009
craigjamesbt
  • 65 Answers
SOURCE: stove burners won't ignoite
just to be clear I am assuming that you can in fact see a spark traveling from the ignitor to the metal surface over where the gas should be expelled... that being the case you must remove the the gas burner from the stove and check for damage or sign of deterioration ie: cracks, rust holes, missing sections etc. more than likely if there is no damage after 7 years of use the problem will be in the form of carbon and rust deposits inside the burner pieces or associated piping (pipe that are in the burning side of the system don't tear into the gas side) *NOTE THIS WILL NOT KEEP GAS FROM COMING OUT BUT MAY PREVENT IT FROM EXITING IN THE PROPER PLACES DESIGNED FOR LIGHTING* you can clean these carbon deposits by tipping the open end face down and tapping the burner pieces with a block of wood or similar device. These deposits should fall out as a heavy black or reddish brown dust you can also try vacuuming it and running an appropriately size drill bit through each of the burner holes to clean them as well or you can probably just purchase a new one by ordering it from the place you bought the stove
Posted on Apr 26, 2009
Why does our new frigidaire gas stove bggf3042kf make a high pitch whistle when the oven is heating?
Could be some blocked vents on the burner. Remove the burner and make sure all the gas vents are clean and clear.
Mar 22, 2015 | Frigidaire Kitchen Ranges
Gas stove blows off the knobs
When you went to use the stove again it sounds like a burner did not light. The gas built up and then came into contact with a flame and ignited. Gas, propane or natural, does not float around and dissipate, it settles and builds up, which is what it sounds like happened, and then ignites with a flame or spark. When you suspect that gas has been on, it is best to wait and turn a fan or something on to dissipate the gas before trying to light a burner...
Feb 07, 2013 | Kitchen Ranges
Frigidaire GLG=F366asd stove igniter problems and solutions . ... on the element lights up the smell of gas is real strong and then it lights and sounds like an explosion.
Where is the problem -- in the oven burner or a stovetop burner?
If something got spilled on a burner ring and clogged the small holes, especially near the igniter, the burner will be slow to light. A stiff wire (small enough to fit) can be used to clean out the holes.
Mar 18, 2012 | Kitchen Ranges
Gas Oven Whistling noise
I HAVE A NEW PROPANE OVEN THAT I CONVERTED TO NATURAL GAS. NOW I GET A WHISTLE WHEN I USE THE OVEN ONLY. DO NOT GET A WHISTLE WHEN I USE THE TOP BURNERS.
Jun 23, 2010 | Maytag Ovens
No Clicking Sound
Sounds like the ignitor control module is bad, if none of the ignitors are working. If it is only one burner with a problem, it is likely an ignitor.
May 12, 2010 | Brown Stove Works TM210-3 Gas Kitchen...
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
For the GE XL44 model, where would i find the pilot light? the stove is not working
There is not pilot light on the stove top since the burner is activated by a spark generate by high voltage to a small ceramic disk with a wire protruding from it by the burner.
You have the have AC Power to the stove and you should hear a clicking when you slightly turn on the burner. Once the burner is on fire then turn the burner control to the desired temperature. If the burner will not light after 4 seconds of clicking sounds turn the burner control off and make sure the round gas diffuser on top of the burner is correctly seated on the burner. It should lock in place and is removable for daily cleaning of the stove. Now try the burner control again in the light position for no more than four seconds to see if it lights.
Do you smell gas? Do you hear clicking when slightly turning the burner knob? If yes to both the stove is working and the top of the burner is not seated correctly. If no on either or both you may have a stove, electrical or gas problem.
Jul 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I need to ge my stove lit
Does it have electronic ignition (clicking sound when starting) if it doesnt and you have an older model you may need to re light the pilot? Also make sure your getting gas to the unit (you will hear a hissing sound when the burners are turned on) try using a match to light the burner
Jun 25, 2009 | GE Profile Spectra JGBP79 Gas Kitchen...
Gas burners/electronic ignition
Jan 26, 2009 | Tappan TGF657 Gas Kitchen Range
Jan 16, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Kenmore 7746 Gas Range Logo
1,073 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
