Question about Maytag M6Y12F2A Air Conditioner
WHEN YOU TURN ON MY AIR IT COMES ACROSS EE IN THE TEMP SPOT.. WHATS GOING ON WITH MY AIR?
I don't know a good setting on a robertshaw 9420 thermostat, for really cold,and fast air condition.
Well Brian, an air conditioner creates the same temperature drop across the evaporator at any thermostat setpoint, so there is no setting that will get it really cold really fast. If your return air is 88 degrees (in a hot house where the system has been off) the supply air temp is going to be near 68 degrees..... as the a/c runs, the air changes within the structure cause a reduction in the average return air temperature and slowly drops the return to 87, then 86 then 85 etc, etc and the corresponding supply air temp continues to drop from 68 to 67 to 66 to 65 etc etc. Eventually the supply air temp after the appropriate 'air changes' within the structure will drop to 55 degrees and possibly even lower to satisfy the average room temp at 75, 74, 73 etc. to a point.
There are SOME newer a/cs that have two speed compressors that may effect the supply air temperature drop under differing load conditions, but thats a different ball of wax.
So, if you want it cold quickly you are out of luck, just leave the t-stat set at 70 degrees and pay the electric bill when it comes in.....
Dec 25, 2014 | Heating & Cooling
I have a 1993 4runner 3.0 4x4. It runs fine. But if I drive for a while turn iy off and try to start it within the next hour it starts then bogs out and dies.Not sure whats going on. Any suggestions or...
have the fault codes read Look for a problem in the fuel pressure system for starters then check for ambient air temp---water temp ---crank position --- sensors
Mar 23, 2013 | Cars & Trucks
Weird colored bar
screen is starting to crash ,
Mar 23, 2012 | RCA 46 46LA45RQ LCD TV
I get a EE code on the display. What is it?
Hello
EE is a high pressure error code. The unit may be to small for the room deppending on what temp it is outside.If its over 95.f The a/c is probably overworked.
One way to solve this would be to cool down the coils outside.Spray water lightly on the outside of the unit too cool it down which will bring the pressure down also.
Jul 20, 2011 | Maytag M6W12W7A Air Conditioner
I bought a 2000 KIA SEPHIA a couple of weeks ago and have noticed that when I put my defrost on that my air compressor also comes on along with the air conditioning light in the car, would anyone know...
It should do this or else in cold temp your windows will stay foggy and in cold temp you can still control the temp from hot to cold.It's ok suppost to work that way.
May 13, 2010 | 2000 Kia Sephia
Flashing temp light
MOST NEW CARS DONT LIKE AFTER MARKET PARTS THE COMPUTER IN YOUR CAR DOESNT RECOGNIZE THESE PARTS SO YOU MIGHT BE GETTING FALSE READINGS ASK YOUR VW DEALER ABOUT THIS
May 13, 2010 | 2003 Volkswagen Beetle TDI
99 Buick La Sabre-accelrating problem-fuel injectors?
It sound as though the car is overheating and maybe the mechanic did not properly blled the system to expel the air.
Air does not heat or cool in a pressurized environment and will read ok on the temp guage.Basically the air is plugging the circulation at the senders spot.
Call the repair shop and ask if it was properly bled.
Jun 19, 2009 | 1999 Buick LeSabre
I have a new Goodman GasPack heating and A/c unit. I turned the a/c on for the first time this year and I'm having problems with the theromastat. When it is set at any set point say 77 the a/c comes on...
If the space temp is (example) 72 degrees and you set at 80 degrees the unit should not come on. The A/C comes on when the space temp gets 2 degrees above setpoint temp. What type of tstat was installed digital or old syle mechanical. I'm leaning more towards a short in tstat wiring
Jun 04, 2009 | Goodman CKL60AR60 Air Conditioner
Maytag error message EE
What is the name and model number of your unit?
Jun 10, 2008 | Maytag M6Q10F2A Air Conditioner
EE IN TEMP DISPLAY
I just called a maytag repair store, and they just had one in the shop, it sounds like the control panel has died, and will need to be replaced. They cost around 60 dollars, + install fee.
Jul 05, 2007 | Maytag M6Q10F2A Air Conditioner
Maytag M6Y12F2A Air Conditioner Logo
18 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Marvin
Marvin
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
