Question about Video Game Consoles & Games
Well when i start up my xbox 360 the screen is fuzzy and dis-colored a little bit, how do i fix this and whats wrong with it?
    Scholar:
  • 203 Answers
This could be one of two problems.
1: your display cords are defective. Try replacing the wires and see if that helps/fixes the problem.
2: the display drivers in your Xbox 360 are messing up. Try resetting your Xbox back to factory settings (which will reset all the drivers in it) and see if that works.
If niether of these work, then it's an internal problem and you will need to contact Microsoft. :(
Posted on Aug 05, 2010
My Xbox 360 is fuzzy and has green dots all over the screen
I doubt it's the 360 since everything else is working just fine. The menu works fine, the game works fine. However if you downloaded one of these maps from the marketplace it may be corrupt, and you will have to delete and re-download the map pack.
May 15, 2010 | Microsoft Xbox 360 Console
My XBOX 360 is green and fuzzy, if you reset the game it will work for a little while fine but then goes back to the green fuzzy screen.
It's starting . The G.P.U is breaking away from
the main P.C. board . It will get worse with time.
You have three options
1 Send it to Microsoft ,wait 2-3 weeks and keep
your fingerd crossed.
2 do and x clamp mod on it this will get it
back to normal for 1-3 mounths.
3 Have a shop re-flow the G.P.U. back to
the board this is the most durable repair
cost will very 70.00-80.00 the 35.00 fix
is some else doing and xclamp mod that
you could have done yourself.
If you need more info just ask.
Rob
Nov 28, 2009 | Microsoft Xbox 360 Console
Xbox 360 makes televison screen fuzzy and difficlt to see
Firstly check the system configuration blade on your Xbox 360 startup screen and check your display settings, if you've got an Xbox Elite/New Premium and have HDMI cable then it should be set as Intermediate/1080i/p settings, if you have the component cables then it should all be set as default.
If that isn't the problem and your games are still loading up with a fuzzy screen then there is either something wrong with the cables in your Xbox or your TV can't handle the graphics that the Xbox is producing and you will have to go into display settings and try setting them as either lower settings or higher settings depending on the TV you have.
It will help if you can provide details to me on your TV too, I'm not as good with TV's as I am Videogame Consoles/PC's but it will help me if I want to solve your queries further.
Jul 21, 2009 | Microsoft Xbox 360 Console
The screen went all fuzzy and diferent colors so i turned it of to re start it and the red light in the bottom right corner lite up. how do i fix it? what is the problem? the code is e74 it is an x box 360
That is a system error that effects the video on the xbox. It's a pretty common error. The best thing is to contact microsoft at 1-800-4MYXBOX, (I think that's the number but you might want to check at xbox.com) and have it sent in to the repair shop.
Jun 22, 2009 | Microsoft Xbox 360 Elite Console
When turning on the xbox the screen turns pink
OK did you ever try to hack your system did you open the inside of it did you drop or smash it or leave it in extreme temps if not it might be the result of poor cable connection,first turn off your Xbox 360 and check out the cables that are connected to the system. Remove them and re-connect them firmly. Now switch on your Xbox 360 again. There is a good possibility that you will find the fuzzy purple screen gone. If you still find a fuzzy purple screen then this might be a bit more complicated problem that your system is experiencing. Usually system overheating is one of the major reasons that cause various Xbox 360 errors
May 05, 2009 | Microsoft Xbox 360 Console
TV screen is fuzzy
Follow the steps below, Hope this helps
1. Try another Av cable ( Audio video Cable )
2. Try another television
3. If the steps dont work, call xbox customer support to have your xbox serviced. Good Luck! hope your console still has warranty
This issue means that your xbox 360 console is having a problem with its Video Card.
Mar 28, 2009 | Microsoft Xbox 360 Elite Console - Black
XBOX flashes color spots on screen during game play..
it may be your tv, not your 360, check connections, or fix geometric settings (if you live near a fault, or if you have your tv on top a mini fridge.)
Jan 10, 2009 | Microsoft Xbox 360 Console
My Xbox 360 keeps showing a black screen
1. Get 3 towels then switch your Xbox 360 on.
2. Wrap the Xbox 360 in the towels [Note - You must cover the WHOLE Xbox otherwise it won't work].
3. Leave your xbox for 25 mins in the towels.
4. When the 25 mins is over take off the towels of and let your Xbox 360 to cool for 20 minutes, enjoy fixed gaming for the next 4-7 days. Once you get a blank screen repeat this process.
[Why Overheat it?]
When overheating it you attempt to solder the dis-connected wires back to the motherboard.
I recommend getting it fixed instead.
[What does it Fix?]
This fixed the Red Ring of Death, and the Blank Screen of Death
[DANGER]
I do not take responsibility for this. This is mainly for those without warranty or money to repair.
The premise is to wrap the towel around the 360 and to let it heat up. This will weaken solder points and hopefully re-join broken connections. The problem with this method is that you have no control over what solder points are weakened and there is no way to prevent further damages caused by the heat. It is better to send a 360 in for repair with the three year warranty that MS put on the 360s, because if you try the towel method and then send it in for repairs, they will know by the solder points being misshapen and it will void your warranty forcing you to pay for the repairs.
Oct 19, 2008 | Microsoft Xbox 360 Console
Xbox 360 Graphics
Check your connections to make sure that they are plugged securely into your television, if they are, make sure the selector switch on the cable is set correctly. The last thing that I would do, is to try another video cable. If that one is damaged in any way and taking on some sort of outside noise it would explain the fuzziness. Monster makes a great cable that is heavily shielded and takes on minimal noise from outside devices.
Jan 30, 2008 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
152 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
