Question about Panasonic PT-47WX49 47" Rear Projection Television
Shadowing of projection T.V.
There is shadowing on my projection t.v. and it's the PT-47WX52CF model.
i'm hoping someone would suggest something. i've cleaned the mirror and the lenses inside so i;m running out of options.
  • 121 Answers
If it looks like a 3-d you need to replace both your STK-392-110'S IC's and you can get them at the following link with step by step picture installation instructions as well as free online tech support
http://servicemanuals.vstore.ca/
Posted on Apr 26, 2008
Missing red composite signal on panasonic pt-47wx52cf
Check your jacks and cables.
The RED jack is either (1) left or right channel AUDIO signal or (2) the RED color channel of an RGB (Red, Green, Blue) COMPONENT video signal.
Yellow is the COMPOSITE video signal.
Dec 31, 2012 | Panasonic PT-53TW54 53" Rear Projection...
I can't get the 3 colors to be one picture - I've got shadowing (or triple picture)
Set will need both the STK-392-560 convergence chips replaced===several sites sell kits with all the parts needed by brand/model number with instructions.
May 19, 2012 | Sony KP-57WS500 57" Rear Projection...
Picture settings
settings are not likely to resolve a "yellow" looking screen.
Go to an unused video input or turn color all the way off----the screen should be gray or black and white looking.
What this really suggests to me is a total or partial loss of blue--the set has a red, green, and blue picture tube---a loss of blue means red and green=yellow.
You can peek inside with the set on and see if all 3 lens for the tubes are lit equally bright.
Let me know what you find (press make comment on this page) and depending on what you find I may be able to suggest something to try)
Mar 24, 2012 | Panasonic Televison & Video
PT-47WX52CF Shuts off automaticly then 3 flashes
I know what is wrong--3 blinks is short protection--
it means 98% chance one of the two STK-392-110 convergence IC's this set uses is shorted.
The chips are side by side (see photo) on metal heat sinks---there are about 12 light blue resistors in front of them marked 2.2 ohms---I bet if you locate them you are going to find one discolored or white in the middle.
I have start to finish, step by step instructions for this repair--shops get 300 or more but you can buy all the parts on EBAY for under 30 if you think you can do it yourself.
If you want the instructions and source for the parts let me know and I will provide them for you.
If this helped you rate this solution as I do this here for free.
Dec 27, 2009 | Panasonic PT-47WX52 47" Rear Projection...
PT-47WX49E Blue and Yellow Shadows!! Help me
Have a qualified repair shop come have a look and give you an estimate. If it's the optical block it's probably not worth repair.
Sep 22, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic PT-53TW53; Red shadows appear and then the t.v. shuts down.
The convergence output IC's have failed. Only fix is to replace them. These are large amplifier IC's bolted to heatsinks and have a high failure rate in all projection sets.
Jun 03, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Red horizontal convergence PT-47WX49E
converge outputs getting tired or limiting resistors opening up. adjusting this incorrectly will make the situation worse keep in mind that overdriving these chips will cause a fold over of your image when you see this carefully adjust in the opisite direction as you may be overheating the outputs
Oct 08, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Pt 53wx53 convergence
Same here,sorry I can ajust all but it just wont come in perfect.
What is the problem.Will the sevice menu work?
how do you get it?
Dec 16, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-47WX49 47" Rear Projection Television Logo
35 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
