Question about Boating
I have a apelco model 285 fishfinder that will not power on wondering how to fix of if it can be fixed
4 Suggested Answers
SOURCE: cant find pictures of an Apelco 365 fishfinder?
Here is one on the cover from a VHS instructional tape showing the 265 and 365. Might be able to blow it up a bit and crop the 365 out....
http://ecx.images-amazon.com/images/I/51EAJS27Z5L._SL500_AA280_.jpg
And, you can go here:
http://www.raymarine.com/SubmittedFiles/Handbooks/Fishfinders/G627296www.pdf
for the 365 handbook to get some pretty fair drawings on the unit. I ran through the pages pretty fast and didn't see any photos but did run across a few drawings and illustrations.
Hope these help. If you can locate a former dealer for them, they might have some clip art from their coop advertising info.
Good Luck....
Posted on Apr 15, 2009
AndrexT
  • 21536 Answers
SOURCE: Raytheon --Apelco 365--fishfinder
For the information of future searchers, I add an OEM type repair that has just worked for me.
Go to the dollar store and pick up any audio lead that has a single narrow pin in the centre. Cut the plastic where the cable enters the plug to expose the end of the pin and wire connection. unsolder the plug and at the same time using the heat from the soldering iron, withdraw the pin from the plastic that is holding it in place. Now you have an unsoldered pin all on its own.
Remove the back from the Apelco 365 and unsolder the wire on the broken pin, (mine was just a push fit). Touch the broken pin with the soldering iron and withdraw it. Insert the new pin, heating it a little with the soldering iron. From the outside of the back case, check the alignment of the pin, making small alterations using a bit of heat. Once satisfied, apply a little dab of crazy glue to fill any gaps around the pin.
Job done. In future use a little Vaseline Petrolem Jelly on the female plug and make sure the plug is square to the back when you insert it, and lined up with the notch at the top.
Posted on Nov 14, 2009
SOURCE: Hi I have an Apelco 530 fishfinder/gps and need a
I have a new one. If you still need one, please contact
nakdogan@t-online.de
Posted on Oct 21, 2010
Gps wont work but fishfinder works fine
This model has two versions, one with the GPS as an external piece, and one with the GPS mounted internally. If the location of the internal mounted GPS cannot get a clear shot at the satellites overhead, it will tell you it cannot get a GPS fix. If it says it is disconnected, you may have a problem with the internal GPS. There are external GPS pucks available for this unit. Here is a helpful website.
http://www.humminbird.com/leading_innovation/fishing-systems.aspx
Nov 07, 2011 | Humminbird 788ci Color Fishfinder Combo...
My unit display note gps fix required for this operation? I can't see nothing only white page.My model # is385ci
I would contact our customer service group and see if they can help you out. The number is 800-633-1468.
Joby @ Humminbird
Jan 06, 2011 | Humminbird 385ci Fishfinder Chartplotter...
LG 285 microphone does not work
Sadly sometimes the fix is way over your head to fix so please take it to a qualified dealer for repair or better yet trade it in or get insurance with a small deductible and if anything else happens to it - get a new one.
Gary
May 27, 2010 | LG Prada KE850 Cellular Phone
Hi I have an Apelco 530 fishfinder/gps and need a through hull transducer kit. Apelco were taken out by Raymarine who advised me to contact Airmar who made the transducers. So far no answer but their...
Embedded
I was looking to see if I could find a replacement for the display and was able to confirm that the transducer is a single beam 120khz unit so I doubt that you've find a replacement for it ..as is .
The Airmar C-49 is the proper number for the connection line but like me I think your going to have to think about a whole new unit and or system . Been there already.
Best of luck.
Sir Isaac
Jun 22, 2009 | Raymarine Boating
I have a sharp copier, model AR-285, H4-01
H4 error pertains to lamp errors.
that would either be the copy lamp or the heater lamp.
check both lamps.
with heater lamps,it's usually caused by either a broken heater lamp or a dirty thermostat on the heater roller assembly.
Jun 09, 2009 | Sharp Office Equipment & Supplies
Cant find pictures of an Apelco 365 fishfinder? any body have an idea on where to look
Good Luck....
Apr 14, 2009 | Boating
Oct 15, 2008 | Boating
Apelco 365 fishfinder. Broken pin on power connector
i did the same damn thing and am amazed this question is on the net. i bought a new system but plan on taking it back. the 365 was a pretty nice model and i'm just going to splice it straight to the power supply. but i was lucky, the two pin connector is the damaged one so drilling it out and splicing it SHOULD be easy. well see. at this point i have nothing to lose.
hope this helps.
Jul 27, 2008 | Raymarine A65 Combo GPS...
Searching for wiring diagram
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=420817e4b66b5093026515350edf12d2&q=Raymarine+Apelco+6760
heres the link to download manual it will have wireing diagram in it for you also i will be uploading the manual to fixya
May 20, 2008 | Computers & Internet
Boating Logo
27 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
