Question about Razor E200/300 Electric Scooter Battery
Scooter only seems to charge about 25% after charging for 7to8 hrs, it is about 2 yrs old.
  • 144 Answers
You probably need a new battery.
Posted on Aug 05, 2010
2013 EW36 ewheel scooter. Why doesn't it start?
I think the the fuse is under the head light cowling glass type 25 amp fuse. Your throttle, motor wiring, or controller maybe causing this problem.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Oct 24, 2015 | Electric Wheels Ew36 Mobility Scooter Red
Scooter batteries are completly discharged for a long time. the red light on. while connected to the 220v. All fuses are checked OK. the charger outlet is round 3 poles connector. you said it will not...
Use an automotive NON automatic style to charge the batteries individually. This may tale up to 72 hrs. to get the voltage up tp at least 10 volts. When that happens, the regular battery charger made for the scooter will finish off the charge. If the battery won't take a charge, then they're history.
Feb 09, 2014 | Pride Travel Pro 3-Wheel Mobility Scooter
Charging problem the red light and green light or both on when charging and the batteries don't seem to be charging
sounds like the batteries are dud, most chargers have 2 or 3 lights, red (max charging) Amber (battery nearing full charge) Green (fully charged and most will switch to a trickle charge) has the scooter been out of use for some time as scooter / wheelchair batteries must be kept charged, and only a short time of no use can destroy the batteries.
Sep 09, 2013 | Golden Technologies Companion II Travel...
The scooter charges and shows full charge when started. Scooter will not drive uphill - certainly seems to lack torque - when driving up hill battery indicator drops to red
Either the hill is too steep of a grade/incline, the weight of the rider is more than the scooter is designed to carry, or the battery does not have enough power. If the batteries are old or have not been maintained properly, they may not be getting a deep solid charge that is needed to operate on hilly terrain. This is indicated when the batteries show a full charge, and then drop off quickly after a short period of use. Make sure that you are not exceeding the recommended weight limit for the scooter and that your batteries are less than 2 years old. Inclines of more than 5-6 degrees are typically not recommended for safe operation.
I hope this information is helpful to you, good luck!
Dec 27, 2010 | Electric Strider Mini 4 Wheel Mobility...
HOW CAN i GET MORE THAN 3 HRS DRIVE TIME ON MY COMPANION 11 SCOOTER?
I'm not to shure the dimensions of your two batteries but this is what i would do. (i go to high school so i have a bunch of time on my hands) Try some car audio batteries like these. http://www.sonicelectronix.com/item_17907_SHURiKEN+SK-BT20.html
http://www.sonicelectronix.com/item_17902_SHURiKEN+SK-BT35.html
you are probably going to have to copy and past the links. if these can rune a car stereo all day then they should run your scooter for way more than 3 hours.
Sep 10, 2010 | Golden Technologies Golden CompanioN II -...
My scooter says its fully chrged but its not. this happens once in awhile, any suggestions?
your batters have lost their charge at some point in time. These gel batteries, if they ever set for a long time with out recharging, or arn't recharged daily with daily use, will seem to be charged. but arn't. their expensive but I've seen batteries last over 5 yrs when taken care of properly.
Nov 09, 2009 | Pride Mobility Victory 3 Wheel Electric...
Shoprider cadiz scooter, batteries show full charge when first charged up but when driving scooter battery power runs out after about 3 miles. brakes work fine, no noises from motor or gearbox, what's...
I think your batteries haven`t been charged properly,or they have been left standing so the charge has leaked out.At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity,but looks like a fullcharge, it says it fully charged but will die
quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential
resulting in short battery life.
Unfortunately majority of scooter batteries like this have to be newly replaced.
Nov 06, 2009 | Health & Beauty
Can't charge battery
At a minimum your batteries need to be charged for 12 hrs a day for the first month if not they will not build the capacity and will dwindle and die for example it is at only 25% capacity it says it fully charged but will die quickly this happens because it is charged to its full capacity but that is only 25% of the batteries true potential resulting in short battery life. The best thing to do is contact your dealer, as I think you won`t be able to charge the batteries on your scooter as they will have no power. Thething with scooters is to put it on charge when not in use.
Sep 01, 2009 | Golden Technologies Compass Electric...
My K800i battery dies very quick
Dear Friend,
                 U are saying that u have bought this mobile 2 yrs back so check wither ur battery has been expired and change it.Otherwise switch off ur mobile and put it in charge and check it out the normal standby for any mobile is 2 to 3 hrs.Kindly check it and revert back
Regards,
Aysaam
May 06, 2009 | Sony Ericsson K800i Cellular Phone
Razor E200/300 Electric Scooter Battery Logo
75 people viewed this question
Top Razor Toys Experts
Bryan Mcphee
Bryan Mcphee
Level 1 Expert
David Payne
David Payne
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
