Question about Poulan Ght225 25cc Gas Hedge Trimmer
Rope will not retract. - Poulan Ght225 25cc Gas Hedge Trimmer
  • 144 Answers
I am assuming you tried to pull start and the rope is stuck out. Just try pulling the rope while it is out, but stand on the hedge trimmer. Sometimes when this happens to me, I just pull the rope a little extra and then hang onto it when it goes back in. Alot of times, I think the rope gets caught on the outside of the retraction pulley causing a tangle.
Posted on Aug 05, 2010
How do i rewind the recoil spring on my craftsman lawn mower?
Normally these small engines use a clock spring to retract the rope.
Remove the cover on the top and you should find the spring either broken or the tab where the spring end has broken off or jumped out of the mount.
You will need to pre-load the spring with enough tension to retract the rope.
Remove the pull handle from the rope, load the spring and then wrap the rope around the pully holding the pully and spring in the loaded position. place the end of the rope through the hole and tie up the handle. The rope should pull and retract without being installed on the engine.
Best explained here...
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jun 27, 2014 | Mtd 22" Yard Machine Push Mower
MANTIS tiller 7225-00-02 starter cord won't retract
take the crank rope cover off and in between rope reel and cover there is a wind up spring either its broke or has come out of its slots.
Aug 16, 2012 | Mantis Garden
Starting rope won't rewind
There are two or three screws that hold the retract assembly on to the engine cover. Take these off, and pull the retract off. First, try to turn the pulley on the inside in the direction that the rope would turn it if you you were pulling it out. Will it rewind? If not, there is a screw on the top of this assembly, that's covered up with a sticker. you'll need to remove this screw, and pull the pulley out. There will be a spring on the inside of this. check the spring to see if it's broken. If not, and it's just come loose, put it back into the slot that holds it, and wind it up enough to get it back together. turn the spring in the direction that the rope would pull it out, until it won't go any more. Hold it, and reinsert the rope, tie a couple of good knots in the end, trim the excess, and let it retract the rope into the assembly. Put the assembly back on your engine, and you're good to go.
Feb 09, 2010 | Yard Machines Tecumseh 148cc Front Tine...
Starter rope will not retract
Either you have a broken rewind spring, or the starter mechanism is dirty to the point where the force of the recoil spring is not sufficient to pull the rope back in.
WEAR SAFETY GLASSES while disassembling your starter mechanism to see what the problem is. Upon reassembly, it is a good idea to lube the post in the starter housing (the one the pulley slides over) with some graphite or teflon lube.
Oct 25, 2009 | Troy -Bilt String Trimmer/Blower...
Pull Rope Broke... How do I replace it and still have it retract?
with the cover in your hand pull the cord out with a pair of needle nose pliers or a little screw driver and where the cord go through the case and before the wheel. pull 5 to 10 inches out and wrap the cord around the wheel turning the wheel but not winding the cord on., do 3 or 4 wraps then pull the handle to get all the cord out and let it retract. if not enough rewind just repeat with 2 wraps
Jul 22, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
Starter rope will not retract.
inside the rope pull housing is a flat spring,it may have come loose from its anchor, its an easy fix...unscrew the 3 screws on housing, lift off housing, and the rope pull is inside the casing, you will then see if its broken, or just come off anchor, 10 minute job if its just loose......
Jul 21, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Rope does not retract
The key is that the spring has to be under tension when winding the rope. For such a simple device these things can be a real pain in the a**. I have fixed a lot of them but they can be so frustrating anymore I just take it to the shop and pay about $15 to have it fixed. This is one of those jobs the shop usually loses money on because it's not a whole lot easier even if you know exactly how to do it.
Please rate if this helps-
Mar 28, 2009 | Garden
Poulan Ght225 25cc Gas Hedge Trimmer Logo
300 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
