Question about Sharp R-7A95 Microwave Oven
Sharp R-A95 no power
Used my Sharp to heat water yesterday and today there is no power. I have checked the wall plug with a hair dryer and it is ok. Is there an internal fuse, if so, where is it located? Need Help
  • Sharp Master
  • 8,973 Answers
On these models, the fuse is usually located either between the door switches or on the floor of the chassis.
A microwave can be dead for many reasons.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open. Then when it cools, it closes the circuit and allows power through again.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If it has a hood thermostat, that should read open, as opposed to the others, which should read closed.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can possibly still find an exploded view by entering your FULL model number (with and without dash) here: http://www.searspartsdirect.com
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Apr 27, 2008
Microwave clock and panel was lit in am wasn't used but in evening when went to use it isn't lit and won't work at all
Hello Anonymous
At the risk of starting with the very basics, when you say that the clock and panel aren't lit and wont' work at all, the first place to look is the wall power. You may be missing power from the wall because:
  1. The microwave isn't plugged in. Someone may have yanked a plug to plug in a mixer, phone charger, thanksgiving animated ornament, or what have you. Trace the cord back and make sure it's plugged in.
  2. Make sure the outlet has power. Take some plug-in-able item and plug to the outlet and see if it can turn on. If not:
  1. A number of kitchen outlets may have GFI switches, especially if they are anywhere near sinks. The GFI may have been tripped. There should be a reset switch in the middle of the plug. See if it's tripped, and reset if necessary.
  2. The breaker may have been tripped. Most kitchen circuits are wired to 20Amp breakers. If this is elsewhere in the house, like in an entertainment room or such, it is likely a 15 Amp outlet. Microwaves can draw a fair amount of power. Someone using another kitchen appliance, hair dryer, or what have you, on the same circuit, may have tripped the breaker. Newer code may specify an AFI or GFI breaker for kitchen outlets. In that case, a fault with something else on the circuit may have tripped the breaker. If that is the case, and it trips again, talk to an electrician. You don't want a fault like that undiagnosed.
    3) You may also want to try plugging the microwave into another outlet, even if the normal outlet seems OK
    If there's wall power and a good plug-in, then you work back to the microwave itself. A number will have fuses. Also, there may be interlocks that kick in if, for instance, the carousel rotation is impeded - that can mean something on the carousel is hitting a wall, which can risk tipping something over and spilling, or risk mucking up the reduction gears for the carousel axle if it keeps pushing.
    At that point, looking for specifics on your microwave model will be needed. You may also try the Microsoft Support approach - i.e unplug it for 5 minutes, then plug it back in and see if it works.
    Hoping this helps, Good Luck!
Nov 18, 2015 | In Microwave Ovens
Hi sharp microwave R-33ST 900w was used to defrost now won't heat anything up how do I change settings back?
It should default to the highest power setting.
If not, you can reset it by unplugging the power for a minute or two, plugging it back in, and setting the clock.
Otherwise, refer to your owner's manual.
Apr 15, 2013 | Microwave Ovens
F3 Message on microwave
Hello
GE microwaves with a digital display will show an error code when there is a problem or malfunction with the unit. One type of error code that will be displayed on a GE oven and require troubleshooting is a code F3. An F3 error code indicates that the keypad for the control panel is bad or has a short. This will cause the microwave to beep continuously after the set clock message appears.
Unplug the power cord for the microwave from the electrical outlet. Pull the microwave out from the wall and set it on a table or the counter.
Find and remove the two screws from the top of the grille, on the font of the unit, with the Phillips-head screwdriver. Pull the grille off of the microwave.
Find and remove the screws that are used to secure the control panel to the microwave frame. Lift the control panel unit up and away from the microwave.
Find and remove the screw that is used to secure the green ground wire. Pull out all of the connectors and ribbon cables from the control board.
Apply heat from a hair dryer to the front of the control board for at least 30 seconds. Make sure the hair dryer is at the low setting. Pull up on one corner of the top membrane, then peel it off of the control board.
Repeat Step 5 for the other membrane that is on the control board.
Insert the pliable circuit of the new membrane through the opening in the control board. Remove the wax backing to expose the adhesive for the membrane. Place the membrane onto the control board.
Peel the wax backing off of the top membrane, then place it on the control board.
Place the control board back on the microwave and secure it with the screwdriver. Reattach the grille, and set the microwave back in place.
Plug the microwave back into the power outlet and reset the clock.
Oct 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Ge profile microwave f3 error and beep
1 Unplug the power cord for the microwave from the electrical outlet. Pull the microwave out from the wall and set it on a table or the counter.
2 Find and remove the two screws from the top of the grille, on the font of the unit, with the Phillips-head screwdriver. Pull the grille off of the microwave.
3 Find and remove the screws that are used to secure the control panel to the microwave frame. Lift the control panel unit up and away from the microwave.
4 Find and remove the screw that is used to secure the green ground wire. Pull out all of the connectors and ribbon cables from the control board.
5 Apply heat from a hair dryer to the front of the control board for at least 30 seconds. Make sure the hair dryer is at the low setting. Pull up on one corner of the top membrane, then peel it off of the control board.
6 Repeat Step 5 for the other membrane that is on the control board.
7 Insert the pliable circuit of the new membrane through the opening in the control board. Remove the wax backing to expose the adhesive for the membrane. Place the membrane onto the control board.
8 Peel the wax backing off of the top membrane, then place it on the control board.
9 Place the control board back on the microwave and secure it with the screwdriver. Reattach the grille, and set the microwave back in place.
10 Plug the microwave back into the power outlet and reset the clock.
Hope this helps.
Jul 01, 2011 | Microwave Ovens
The microwave had been working fine we now have no power at all
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Feb 21, 2010 | Maytag MMV5207AAS Microwave Oven
Microwave dead
one of 3 things, for sure the internal fuse is gone, then check for a: bad Hi-Voltage;diode, Hi-Voltage capacitor, or the magnetron tube is defective,none are too hard to change out,but the magnetron is fairly expensive to replace:
Sep 22, 2009 | Microwave Ovens
Burning wire smell
Since it's less than one year old, it should be fully covered under warranty.
I'd suggest contacting the manufacturer to get it fixed free.
Nov 20, 2008 | LG Microwave
Microwave Ovens Logo
85 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ed Mac
Gerry Harvey
Gerry Harvey
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
