Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Sony F Tinitron 36" Volume lower in regular TV mode, higher in dvd mode
OK, I am stumped. I have to turn the volume up all the way to get half of the volume I used to, but when I pop in a dvd, I get the full volume. Meaning, I'ts much quieter in TV mode, but loud as hell in dvd mode. Is it a setting issue?
Please help!
I have a dvr and dvd connected to the tv also, not sure if this is the problem, since the volume thing just started.
    President:
  • 2,712 Answers
Try to disconnect the dvd andvr when watching plain tv. Thi may help..
Cheers!
IrishDruid
Posted on Apr 26, 2008
  • Swilin Sampson
    Swilin Sampson May 03, 2008
    Just wanted to inquire if your issue is resolved, or if there is anything
    further I can do to assist you…
    If you find that the solution/answer I provided led you
    to, or resulted in a fix, please take a moment to close the ticket with a FixYa!
    rating under my solution.
    I would be very grateful for your show of appreciation.
    Should you have any further questions, please feel free to
    post them here.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
  • Swilin Sampson
    Swilin Sampson May 31, 2008
    P.S. -You can rate this solution with one of
    four votes, if you feel your issue is resolved.
    • "FixYa!"
      - The solution provides great advice on how to solve the problem.
      (Positive Rating)
    • "Helpful"
      - The solution provides useful leads that helps solve the problem.
      (Positive Rating)
    • "Thanks
      for Trying
      " - The solution does not solve the problem but the
      effort is appreciated. (Negative Rating)
    • "Inappropriate"
      - The solution has absolutely nothing to do with the problem.
      (Negative
      Rating)
    If your issue is not still not resolved, do not
    assign a rating just yet. Please post back as to what steps you took, results,
    etc, and I will try to assist you further as best I can.
    IrishDruid
VERY LOW VOLUME
Replace the speakers.
Jun 09, 2015 | Sansui 32" TV
I have a coby dvd/cd home theatre system i have hooked it up to satellite but when i turn it to tv the volume can't be controlled only can lower volume in dvd mode not in tv and the tv remote can't turn it...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
Jan 16, 2011 | Coby CSP92 Theater System
My volume on my sony tv wont go past 12 it will higher and lower but the maximum it will higher to is 12 have i maybe put a volume lock on it??
The only way the volume could be limited is if you were in the hidden tech menu----many of these sets have a setting there for initial volume level and maximum volume level.
Were you in the TECH menu for some reason?
I can tell you how to get in but you have to be very careful if you make any ADJUSTMENTS there--over 200 things can be adjusted there.
Let me know if I can help.
SD TECH
Feb 08, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Have a sony KDL - 46v5100 volume problem
Tap the "Theater" button on the remote. You should see either "Theater Mode: On" or "Theater Mode: Off". If it is off, tap it again to turn it on and wait for it to go away. Now tap again (should say "Theater Mode: On") and then press and hold it for about a second. This should actually turn it off, as opposed to just pretending to. Works on my larger Sony KDL.
Jan 15, 2010 | Sony KDL 46V5100 46 in. LCD HDTV
Sony dvp ns67p plays dvd's at a quiet
I changed the audio settings to TV MODE.
and now the volume is perfect
Oct 05, 2009 | Sony Televison & Video
Audio in playback mode doesn't work
Hi There, Try this: Connect you camcorder to your tv set via a/v input cable. Put camera in cam mode so you can see the picture on the tv. Turn up the volume on tv and if it squeels, the mic on the cam is ok. Record something and then play it back on the tv, if its ok, then all your audio is functioning. This means that the SPEAKER on your camera is defective.
Thanks, mr cicmo
Dec 26, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Philips dvd player
Turn off the night mode on the Philips:
1 In ‘AUDIO SETUP’, press OK to enter
the submenu.
2 Press 3 4 to highlight {Night Mode}, then
press OK.
3 Press 34 to highlight one of the options
below:
ON
Select this to level out the volume. This
feature is only available for movies with
Dolby Digital mode.
OFF
Select this when you want to enjoy the
surround sound with its full dynamic
range.
4 Select an item and press OK.
Jul 20, 2008 | Philips DVD 622 DVD Player
Sound
Set your SAT receiver to full volume and use your Sony TV volume control as the master volume control. If you use an external surround sound amplifier do the same thing using the amplifiers volume control as the master volume control.
Consider that all source devices that have the ability to control their output volume will output what they call line level 0dB when the source device is set for maximum volume. If you set the source device to 1/4 volume your output to the amplifier may be around -25dB or lower. Introduce that low of an audio level to the amp and you will have to turn the amp up to half way or better causing the amp to amplify noise too.
Jul 04, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
TV PROBLEM
I don't know your set in particular:
Genericaly, there are some models of sets that have a pre-set level for the sound. Check in to the menus of the set if there is a setting for the audio level at turn on.
Some manufactures designed their sets so that the sound is at about 30% up when the set is first turned on. This is annoying. They did that because they had people turn on the set and call their tech support that their set had no sound. It turned out that the volume setting was at "0"!
Jerry G.
Nov 21, 2007 | Philips 28PW6506 28" TV
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
59 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
