Brother WP-760D. Machine is spontaneously, erratically initializing already formatted disks containing data. Problem is occurring with two new disks bought '09. Are data unrecoverable? Cost is not a problem. In one case a disk was cleaned. In another case only one file was wiped--the one being worked on. I can open files on an early disk bought '03. Another disk containing backup files, bought '09, does not open. Machine groans briefly then starts to initialize. Is my vintage machine finally giving up the ghost or are current disks inferior? Does Brother make a new machine which will allow me to access data on my 760D disks? Would greatly appreciate some suggestions. Am thinking of looking for another 760D or more recent compatible typewriter on Ebay or elsewhere. Any advice re purchase? Can my data be transferred to a computer? If so, how. Assistance greatly appreciated.
  • 13 Answers
SOURCE: WP-760D
I thought I found the instruction manual for you on Brother's website, but instead of it being instructions it was the service manual. I had one of nifty typewriters in the early 90's that a friend gave to me, until my ex-boss decided to keep it after I left.
Posted on Feb 25, 2008
byteguy
  • 2229 Answers
SOURCE: Toshiba Satellite P105-S6064 Laptop
You have a corrupt registry.
You can do a Windows repair (the easy way to solve this)
Or, you can do it the hard way.
Try the easy way first: Boot from your recovery disk and see if it will let you do a "repair." If not, get back online and I'll post the directions for doing it the long, hard way. But it works.
Posted on Jan 29, 2009
  • 37 Answers
SOURCE: PC constantly reboots after external HD error
Firstly remove the external drive. If that works, great! Otherwise continue.
If that didn't work, then you'll need to figure out a bit more. When you go into safe-mode windows will list off each file as it loads it. Note the file it crashes on! Insert your XP disk and run the recovery console. From here on, simply copy the file you need to your hard drive, example:
If the system crashed on (fake file): C:\WINDOWS\this.is.important
Then run a command like:
copy this.is.important C:\WINDOWS\this.is.important
You may need to remove the file beforehand using the 'delete' command:
delete C:\WINDOWS\this.is.important
If none of these options work, or you don't want to fiddle with the command line, try a professional computer repair service!
Posted on May 21, 2009
bob_computer
  • 3153 Answers
SOURCE: 320GB seagate freeagent, cant open some of the files.
If you have the ability and space then recover any files that you can
use the RUN option from the start menu
now type in "cmd" then ENTER
Now in the black box that appears type "chkdsk x: /f /r" and press ENTER
The "x" is the drive letter of the drive you wish to check
It may take some time but this will try fix any errors it comes acrosss and you may have to re-start to complete the task.
Now remove any more files that you can.
Use the RUN command again but this time type "compmgmt.msc"
Select Disk management
Make sure you freeagent is listed here.
Right click and select "Format"
Select NTFS as the file system
Do not tic any other boxes
Click OK
When it is done you can move the files back to this drive.
It is quite possible you hit the limits of the FAT32 file system which would have caused the types of error you saw.
Posted on Sep 17, 2009
  • 52 Answers
SOURCE: trying to sort out MyGuide 3100 problem. added
run software cd you got in the box. it will reinstall the original software
Posted on Apr 05, 2010
I have a Brother word processor 3550 I need to replace the disk drive. How do I open the machine? There are no screws!
Hello, Kittdaveandt -
I have not found a service (repair) manual for a Brother WP-3550 word processor. That is the publication where I suspect one would find directions on how to open the unit and replace the disk drive.
Therefore, if you have not already done so, I suggest you contact Brother Business Machines Customer Support directly and ask about the availability of a service manual for the WP-3550. The company probably has at least one copy of the manual in its archives. If such a manual is available, there may be a charge for a copy.
Brother Support, Business Machines:
877-276-8437
Monday - Friday, 9 am - 9 pm, Eastern time (USA)
Source:
https://www.brother-usa.com/brother-support
Best wishes.
Jun 01, 2018 | Office Equipment & Supplies
When i use the WP mode to retrieve details from the floppy disk, it prompts initial or not. It cannot retrieve from the floppy disk, why?
The floppy might be defective. It is asking you if you want to format the disk because it can't read it. Make sure that you keep anything magnetic away from the disk. It will corrupt the data.
May 08, 2014 | Brother WP-1700MDS Typewriter
Word Processor no longer reads disks
Sounds like the disk drive has died. Brother does not have parts for this model anymore. You may have to find some one to convert your disks to another format.
Oct 07, 2013 | Office Equipment & Supplies
Retrieving stored information on Brother WP 3550 disk from another source
Another identical wp should be able to read your disk.. Did you try to replace the drive with another? Check ebay for parts?
eBayeBay
Sep 24, 2017 | Brother Usb Cable For Mfc-3240c Hl-lbp...
When i want to open my D drive ,it gives this masage 'the disk in drive d is not formatted. do you want to format it? yes or no' . i don't want to format it. what shoud i do?
As you know already that format disk basically creation of FILE ALLOCATION TABLE (FAT) NTFS (new technology file system)
it is necessary to store data on disk. but if this error occurs while disk already formatted with any file system then simply run disk repairing utility to fix the problem
If its intel based machine or AMD and running windows then i would recommend run scandisk utility
if its mac run disk utility from utilities and check disk for any error and it will repair the disk
good luck
Aug 19, 2011 | Computers & Internet
WP-760D
Dec 04, 2007 | Office Equipment & Supplies
96 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
