Question about Black & Decker CTO7000 1500 Watts Toaster Oven with Convection Cooking
On my Toaster Oven, serial #CTO8000, the Toast controller stop working. I checked the controls and switches with no results in toasting. How do I fix this problem? I believe it could be a broken wire connection. Thanks, Art Spencer
SOURCE: Cuisinart toaster oven modele no.TOB-30BWC, serial no.50421.
I have the same problem. It is due to a bad relay switch in the toaster. I have found that for now, my toaster will work if I leave it on the "TOAST" function rather than "OFF" overnight. I think it lets some current or voltage hit the relay and encourages it to work.
I will try to replace the relay and post a "how to" on that when it is done.
May all of your toasting be succesful.
Posted on Jan 21, 2008
  • 1011 Answers
SOURCE: I need a manual for my toaster oven broiler
dear,
here is the manual..
check this link , scroll down and save the manual which is in pdf form..
http://www.cookware.com/Black-and-Decker-TRO700S-BND1070.html
regards,
dont forget to rate.. its hopefully work
Posted on Aug 16, 2008
SOURCE: top element broken
Oster 6233 toaster oven top heating elements don't work
Posted on Apr 19, 2009
cactus bob
  • 267 Answers
SOURCE: button to toast won't latch
THE BOARD IS BAD .the problem is b&d will not sell it to you . i had one that i DID FIX , there was a problem in the power supply on the board , i checked out the parts i needed there where 2 diodes , and an scr transistor i found bad . ordered them (with shipping 28.00 ) got them and installed . and the first power up POP the ic timer blew apart and damaged the two diodes . cost of the ic another 25.00 plus the other parts. so i now have around 60.00 in parts and 4 hours labor in to my great working 7 year old toaster oven ( that i only paid 25.00 for in the first place ) so unless your like me and never give up ,NO MATTER WHAT ! its time for a new toaster oven ......... if this answer helped please rate a 3 or 4 stars this high rateing will help keep me in the paid answer department , thank you
Posted on Jun 21, 2009
  • 57 Answers
SOURCE: I have Toast-R-Oven TRO200 and it just stop
You probably have a switch in the oven that has failed or a broken wire. These are basically the only reason it wont come on. The best bet is if it is old buy a new one or see how much it would cost to repair. Usually the cost to repair is almost as much as the cost of a new one and getting parts can sometimes take two or more weeks.
Posted on Oct 09, 2009
Repair of model 553 krups toaster over. Lever will not stay down to toast
if there is a open circuit the lever will not stay down. hold the lever down check if the elements glow , most times it costs more to fix then a new one.
May 05, 2018 | Krups Toaster Ovens
Black & Decker Toaster Oven - elements cycle on and off, which makes for a SLOW cook.
Oven has three modes: 1) oven mode cycles elements on and off to maintain a specific temp setting for up to 60 min. 2) toast should keep all elements on for a few min. 3) broil mode top elements only always on, up to 60 min. Make sure you have dials in correct position and use the toast timer.
Apr 17, 2014 | Toaster Ovens
KCO223 toast function not working
I too have the same KCO223 countertop toaster oven, and the toast function is not working. All other functions work fine, but the blue light won't come on in the TOAST mode setting.
Apr 09, 2014 | KitchenAid 12" Convection Toaster Oven...
The toaster oven does not toast. the oven and timer work, though
Your selector switch may be broken if the oven works on selections other than toast.
Jan 05, 2010 | Black & Decker TRO390 1200 Watts Toaster...
I have Toast-R-Oven TRO200 and it just stop working.The light indicating the toaster or oven is being used does not come on.I plug it into other working outlet and it is still not working.
Oct 09, 2009 | Black & Decker TRO200 Toast-R-Oven Toaster...
Stopped Working!
check the switch or thermal fuse, if it has.
Aug 29, 2009 | Black & Decker TRO603 Toast-R-Oven Toaster...
Button to toast won't latch
Jun 19, 2009 | Black & Decker TRO360 Toast-R-Oven Toaster...
Toaster switch- Black and decker- TRO360TY6
I don't know if you can fix it but if you are good at basic diagnosis you can take off the right side and see if the toast latch is broken or perhaps out of place. This type of unit is not so easy to take apart and put back together. The parts fit is a bit strange.
May 14, 2008 | Black & Decker TRO360 Toast-R-Oven Toaster...
The contacts for these toasters fail. The plasic cam that depresses the contacts also can melt. The design is poor and no replacement parts are available. When selecting a setting, if the selection is not exactly perfect, the contacts arc and eventually fail. Unless cuisinart changes the selection cam to a solid state or relay, this failure will continue to happen during normal use. If your unit works properly do not switch the function setting while heating, this will cause the contacts to arc and erode the contact surface. This posting is applicable to the TOB-30BC, TOB-30BCC and probably all TOB-30XXX models.
Dec 26, 2007 | Cuisinart TOB-30 Toaster Oven with...
Black & Decker CTO7000 1500 Watts Toaster Oven with Convection Cooking Logo
78 people viewed this question
Top Black & Decker Toaster Ovens Experts
Steve
Are you a Black & Decker Toaster Oven Expert? Answer questions, earn points and help others
