Question about Dryers
I HAVE AN AMANA DRYER MODEL LG8409W2. DOES THIS MODEL HACE A PILOT LITE OR DOES THE HEAT FLAME COME ON WHEN YOU TURN ON THE DRYER?
  • Dryers Master
  • 43,501 Answers
Your dryer has an ignitor that lights the flame...
here is the part...
http://www.repairclinic.com/SSPartDetail.aspx?s=t-LG8409W2-%3d%3di1194687&PartID=1194687
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas DryerI HAVE AN AMANA DRYER - 2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is ..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gifDryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Aug 05, 2010
Dryer come on and runs but no heat is there a thermal fuse some where on this model. it amanda lg 8219W2
http://www.servicetechhelp.com/techs-only/01-11/Amana-Dryers-LG8409W2-Service-Manual-RS3200001.pdf
Service manual is above. Model should be similar. Page 93 walks you through no heat diagnosis Step by Step. I don't know your mechanical abilities. Check back if you need more detailed Technical help. Good Luck
Nov 17, 2015 | LG Dryers
Hooked up roper dryer and it's propane everything seems to be hooked up right but won't get hot or even heat up. This is first time ever having to use propane. Any idea what it might be or could have...
1.is the pilot light lite burning.
2. if pilot light light is on ,does the blue flame of the pilot light touch and heat up the thermocouple.
the dryer will not turn on the heat if the pilot flame does not touch and heat up the thermocouple.
3 is the dryer plugged in to the electricity.
4. is the dryer actually getting electricity.
If the dryer has electricity and the pilot flame is touching the thermocouple, then try buying and installing a new thermocouple.
****have you purged the air out of the gas lines so that the dryer is actually geting pure propaine and not just air getting pushed ahead of the propaine.
how old is your dryer, if new, warranty service will trouble shoot & repair for free.
you need to tell us more so that we have some facts to work with. vagueness does not cut it.
Oct 09, 2013 | Dryers
The flame won't light everytime I turn the dryer on I have to turn it on and off a couple times to get it lite. And when it don't lite I hear a buzzing noise that I don't hear when it its lit.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 14, 2010 | Amana LGA10 Dryer
Hi, i have an amana dryer, model LG8409w2. it is running but has no heat. is this a gas dryer? and how do i get into it to see what's wrong. thanks
Hi, to tell if it is gas or elect, just pull it out some and look behind it. A gas dryer will have a galvanized pipe with a gas flex line and shut off valve going to it. If electrical, it will have a large diameter cord plugged into a large round plug much different then a regular receptacle. It sounds as though it is a electric dryer as it is running. A gas dryer will have a regular plug on it to. If no heat, it could be a number of things that are wrong. The heat strips are located at the rear of the dryer behind the panel. You will need to unplug it and pull it out to do this. Give yourself lots of room with a strong light to work with. The heating element has several coils of wire lined up in a vertical position. Look them over very good for a break in any part of these coils, look very carefully to find one. If you do, you will need a new one. Take the model, serial, and name to a appliance parts house to get one. If by chance it is gas, make sure there is gas to the unit and the valve is open. Shut off the valve and take loose the line. Crack open the vale a little to hear and smell the gas. There is not much you can check on a gas dryer but this, that's about it. It may be the ignitior, a thermostat ect. I am sure you have a electric dryer, so check the element and clean all of the lint from the unit. Get back to me on this, so we can go further if needed.
Sincerely,
Shastalaker7
Jun 12, 2010 | Dryers
Amana NDG2335AW Gas Dryer runs but doesn't heat
Check the spark ignitor when firtst starting the dryer up. It should click within the first 15 seconds to light the pilot up
May 31, 2010 | Amana NDG2335AW Gas Dryer
Igniter keeps going out on LP dryer
Look at the gas control box. Inside this box has a valve to open the gas so it can sustain the burner. This valve is control by the voltage of dryer sensor. This thermocouple is near the ignitor.. If this fails, there would be no voltage to open the valve. Here is how it looks like: 7f43321.jpg
Jan 08, 2010 | Amana ALG331RAW Gas Dryer
Pilot lights but main burner dose not light when turned on
possibly a fowled thermocouple if the thermocouple doesn's sense the pilot flame then it will not send a signal to the gas valve telling it that its okay to open cause the pilot is lit.
Dec 28, 2009 | Lite On Laars Lite 2 Heaters: 250,000BTU...
Inglis gas dryer heat loss
Replace these solenoids on the gas valve. Feel them if you can. They get hot and quit.d910ca8.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 04, 2009 | Dryers
Amana Dryer LG8409W2 - The dryer heats for a few seconds then runs cold. The dryer has been cleaned as well as the vent and still no heat.
karenl46 -- Flame sensor has to "see" proper flame in order for gas burner to stay on. Safety solenoid engages (shuts off gas) when flame light not detected. Check window on sensor (1:30 CW position) on burner tube. If you still have problem after cleaning it, then refer to URL below. -- SWT
http://forum.doityourself.com/kitchen-laundry-home-gas-appliances/350993-another-gas-dryer-no-heat-failure-rates.html
Aug 18, 2008 | Amana Dryers
Amana dryer will not heat up
Yes replace the thermostat .Please rate this !
Aug 11, 2008 | Amana Dryers
Dryers Logo
113 people viewed this question
Top Dryers Experts
Marvin
Marvin
