Question about Radio Shack TRC-447 CB Radio
Need a new mic for TRC447 radio Shack CB. Has a 6 pin connector
  • 29 Answers
Hi Old
here is the link to wire up a different mic look on pg. 51 of this pdf.
link.http://www.cbtricks.com/radios/realistic/trc_447/graphics/trc_447_sm.pdf
hope this helps save this radio from the trash!!!
Ray
Posted on Aug 23, 2010
Radio Shack TRC 47. What are color codes for the 5-pin mic?
did you cut the wire to the mic plug . 99% of R.S. mics are wired the same. there are some four pin and 6 pins but basically all the din type plugs are the same.
Apr 07, 2016 | Radio Communications
Need pin out for trc 432 cb radio
its a 5 pin din connector.All radio shack radios with the din plug are 5 pin
Dec 08, 2013 | Radio Shack Radio Communications
Need mic wiring diagram for trc-446
you may have to order one from radio shack because the wireing diagram is for that radio and mic only . You cannot use another mic on that radio , only the one that comes with it . If you are patient enough and have another mic with the same controls you could wire it up. it has to be ( I think a 6 pin ) ???
Nov 10, 2013 | Radio Shack 40 Channel Cb Radio Model...
How do I delete question for TRC447
why do you want to delete a question? maybe the answer you get will help someone else .
Oct 28, 2011 | Radio Shack TRC-447 CB Radio
I need to find a replacement 6 pin micriphone
Your going to have to keep looking on places like ebay, on CB radio forums.
You can get a 6 to 4 pin connector and you can use the radio. The only thing the extra 2 pins are for is to change the channels with the mic. they are not necessary of operation of the radio.
Also, you have to make sure the mic is wired for the radio you have. You may find a 6 pin mic, but you might have to rewire it.
I have a 6 pin mic, but its not going any where.
Sep 30, 2010 | Radio Shack TRC-447 CB Radio
I need to know what colers go where on the mic pin for a trc 447 thank you
I don't know which mic you're trying to wire to this radio. The colors of the wires in the mic cable may change from one mic to another, so relying on the color is not reliable. Usually you refer to these connections as Pin1 to a Signal or Function; or Jack Pin1 to Plug Pin3. No one assumes a color will always be used to connect Pin1 to TX (transmit).
With that said, I found an answer on FixYa from someone that answered the question some time ago like this:
HERE IT IS THE CORRECT MIC WIRING FOR THE REALISTIC TRC 447.
1.)Audio
2.)RX
3.)TX
4.)CH.Down / Shorted to Ground
5.)Ground
6.)Ch.Up / Shorted to Pin 4
Be extremely careful when wiring this radio! pin 4 and pin 6 carry voltage shorting these to the wrong place can result in serious damage to your radio.
Lastly, since I doubt what was provided above is going to help you very much - you can review all the info ever printed by Realistic on your radio, here. There's a wealth of info on this page and you should be able to find what you're looking for in it. You're looking to find the pinouts of the radio to the pinouts of the mic.
If you ever have to disconnect a multiconductor cable from a connector, and you don't have the time or means to write the colors down, it is better to simply cut the cable - leaving all the colored insulation of wire ends soldered / still secured to the connector. When you are ready to do the replacement of the connector or cable, you've got the wiring order in place still, and can make the new connections one at a time at your leisure.
Aug 11, 2010 | Radio Shack TRC-447 CB Radio
Need to replace microphone on a Radio Shack TRC 447 CB. 6 pin Anybody know?
A great mic is the RK56 $39.99+tax in Temple, TX on Hwy 95.. And comes with a 4pin for cobras but can be wired for any radio
Aug 09, 2010 | Radio Shack TRC-447 CB Radio
I need a wiring diagram for the courier Centurion cb mic, it has a phono jack pin tip .
The center of the mic pin is your hot, and the outside is the ground. On the mic, the white wire is your hot Audio, and the shield is the ground.
Hope this helps,
J.R.
Jan 19, 2010 | Radio Shack TRC-447 CB Radio
Mic wiring diagram
Want to wire cobra mic to a uniden washington radio
Nov 20, 2007 | Radio Shack TRC-447 CB Radio
Radio Shack TRC-447 CB Radio Logo
149 people viewed this question
Top Radio Shack Radio Communications Experts
john milligan
Steve
xxxxxx xxx
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
