Question about Pioneer Audio Players & Recorders
Hello my Pioneer RX-540 was working just fine yesterday but today it would not put out any sound at all i know its not the speakers and everything seems to be working on the receiver the only thing i found that was different was that the red light on the volume knob would flash. Any suggestions as to what it might be
The Marv
  • 72 Answers
SOURCE: JVC RX-618V SOUND IS MUFFLED
check to see if the radio is clear. If it is it may be the signal going into the amplifier. if it is muffled as well, depending if you have an Equalizer hooked to the unit. This also could cause the problem. Finally check the bass, treble balance and volume knob but turn them back and forth while unit is on and see if signal clears up momentarily. if this is the case the control knobs need to be cleaned. Also spin the connection jacks {RCAs} in the rear and see if this clears it up. If not you may have to have the unit serviced by a professional.
Posted on Aug 05, 2006
SOURCE: Yamaha RX-V793 flashing light on volume control and no volume
Per Yamaha support page: The volume light on my Yamaha AV receiver is flashing, what does this mean ? The "MUTE" function on your remote control has been activated. The reason that you can still hear a very low sound is that the muting circuit within your stereo is not a full mute, but rather a -20dB mute. To deactivate the "MUTE" function, simply press the "MUTE" button on your remote control. (Make sure the volume control is turned down to avoid damage to your system.) If you misplace or lose your remote control, you will have to purchase a new remote control unit, as there is no duplicate function on the front panel of your stereo. Unplugging the stereo will not deactivate the muting circuit, as the microprocessor "remembers" if the muting circuit was active prior to being turned off or unplugged. If you need to purchase a remote control, you may order one directly from our parts office. You may reach them by dialing (714) 522-9888 from 8 am to 3 p.m. Pacific Time, Monday through Friday. If you have any other questions, please contact our customer service department by dialing (800) 292-2982 Monday through Friday from 8:00 a.m. to 4:00 p.m.
Posted on Sep 12, 2006
jeesusfreek
  • 18 Answers
SOURCE: Rear Speaker volume too low
Channel level output can be adjusted in the menu if you have the remote. Set the rear channel level volume higher and the fronts lower if need be, and then turn up the volume. Enjoy!
Posted on Jan 28, 2008
SOURCE: Rotel RX-800
I have an RX 600 - which has just gone 'phut' - which is how I came today to find this website ! I once had your speaker problem but eventually tracked it down to a bad connection of the speaker cable into the rear of the Receiver. Plastic sheathing and dust was partly in the way. Strip off a bit more plastic to expose fresh bright wire, and remake secure tug-proof connection before you try anything else. Oh, and while you doing it, do the others as well !
Posted on Sep 11, 2008
SOURCE: Low volume from Akai turntable attached to Pioneer Surround Sound Receiver
If you receiver doesn't have phono inputs,you will need to buy an inline phono amplifier.Phono inputs have a built in amplifier,all others don't.Try Crutchfield.com.If they don't carry them,they will tell you who does.
Posted on Jan 27, 2009
Why am I getting no sound?
I hope u might have muted the sound or batteries of the remote are to be replaced /also check left right connection of the out put
Dec 23, 2014 | Pioneer Audio Players & Recorders
Same prob. My acer worked y.day and now no sound.
I completely unplugged my speakers. And uninstalled all the hardware for my speakers. Then restarted my computer. Then inserted my format disc for my speakers. Reinstalled it. Using all automatic speaker settings. And they work fine now.
Jun 29, 2009 | Acer (90.18612.36B) Computer Speakers
Yamaha RX-V2700 no sound from any speaker outputs
Make sure that you have the correct input signal selected.
Also, check if the sound is not muted.
If you have a multi-room speaker switch, make sure it is set correctly to main speakers.
Apr 28, 2009 | Yamaha RX-V2700 Receiver
Logitech x-540, front right & left speakers not working
Turns out my soundcard wasn't fully inserted into the motherboard, so I just took it out then put it back in and everything works fine.
Mar 30, 2009 | Logitech X-540 Computer Speakers
Acer speakers no sound
Hello!
You should tell the model of your acer or the sound card on it so that i can serach it for you. However you can search it by your own by simply going to the acer website and then search the model of your laptop and the go to the support and downloads.
http://www.acer.com.ph/ or selet your location and search your model.
may this help. melnavz
Mar 14, 2008 | Acer (90.18612.36B) Computer Speakers
Connect DVD Player to logitech X 540 Surround System
Bad connection on that one speaker, if you have tested the system with other equipment and it works thn you MUST have a bad connection INSIDE you DVD player. If your DVD had a whole channel out on your output amplifier I beleive then 2 speakers would not work so more than likely you have a bad solder joint inside system for DVD output
Feb 11, 2008 | Logitech X-540 Computer Speakers
Connecting X-540 speakers
Green is the speaker out let.
Make sure the sound card is activated.
Dec 26, 2007 | Logitech X-540 Computer Speakers
127 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
