Question about Whirlpool Washing Machines
Whirlpool cabrio WTW6500WW1 is beeping and showing an Fon the signal
4 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool Washer-Cabrio. It won't run and time
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&^@#$%
Posted on Sep 21, 2010
blueextc3221
  • 15935 Answers
SOURCE: display shows F1 top load cabrio whirlpool washer
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^#*
Posted on Sep 20, 2010
  • 6277 Answers
SOURCE: I have a whirlpool cabrio
Just in case, and no promises (!) but I would gently suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning!
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Apr 16, 2011
What is load capacity for cabrio wtw6500ww1
It may only think it's overloaded. When the cycle starts the control checks the load to determine how much water to add. If there's a problem like stuck basket or rotor, bad sensor etc it will quit with the error you see.
Jun 19, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio dryer
this is a signal from some codes, read your owner manual and see what is the indication with the beeps.Normally after your clean the filter and exhaust vent, and continuos beeping the control board is faulty, replace it.
God bless you
Jul 13, 2013 | Dryers
Whirlpool cabrio wtw6500ww1 stopped working when it needed to spin n drain?
get a putty knife and between the top and cabinet about 2 inches in on the left and right shove the putty knife in to depress pins (this can be frustrating) once you can lift up the whole top you will find a tech sheet in the inside of cabinet left . also you will need to do this to replace lid switch. run through diagnostics to view all errors . there will be a list of error codes in this tech sheet with troubleshooting ideas.
Feb 17, 2013 | Washing Machines
Whirlpool Cabrio washing machine button does not work.
Possible that the main controller unit is faulty. You need to confirm the voltage on the controller unit and the connectors to the panel.
If there is no support from the controller then it can be faulty.
This requires testing the board for the processor and the set voltages for the board to function which must be measured..
Jun 05, 2012 | Whirlpool Washing Machines
Whirlpool Cabrio WTW6500WW1 stops spinning.
Hi there
The ideas I have are sort of homemade. What I did wrong was that I did not let the machine rest long enough between starting the machine for it to stop a while later.
good luck
kolbrun
Mar 18, 2012 | Whirlpool Washing Machines
Model wtw6500ww1, error code LD, power off power on selected cycle but wont start just blinks and locks all buttons. let it sit and then error code comes back. washer is empty but wont reset to start...
Suspect that stands for LiD. There is likely to be a problem with either the lid solenoid/lock or the 'lid closed' sensor requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
John C
Aug 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Our Cabrio is showing "LD" in the display code and
you need to check your main drain pump for anything that may be restricting the water flow or stopping the impellar wheel from turning
Nov 21, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Code f50 and beeps.
Your controller board is dead. If it's under warranty, you'll have to contact Whirlpool for a replacement.
Dec 16, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Machines Logo
332 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
