Question about Dryers
I ran a new line for my dryer and instal;led a new breakewr in the panel wire the plug as such black wire to one slanted term the red to the other and white to the one in the middle straight one when i turn the breaker on it triped right away
  • 144 Answers
Black on one slant, white on other slant, red in the middle. Red and green are ground wires throughout electrical. Black and White are always hot and nuetral.
Posted on Aug 05, 2010
New house requires 4 prong plug for dryer...mine has 3...bought new cord...How to wire it?
The old three prong, the vertical prong is neutral (white wire), the two slanted are 220 volts. The new plug, the extra prong is ground (bare wire). Shut off the outlet at the breaker panel, and remove the outlet to examine the wiring to it. It should be as above--the 220 volt wires are red and black or black and black. The ground wire is bare or green insulated. Inside the dryer case, tie the green and white wires to the dryer case, and tie the two outside wires where they went with the old cord. Check with an electrician if you are unsure about this.
Jul 16, 2009 | Dryers
Need to switch 3 pronged plug for 4 pronged but not sure which color wire gets connected where.  Other wires were not color coded.
the red and black wires go to L1 and L2 terms doesnt matter which color on which term, white wire goes to"N" neutral terminal and green wire is safety ground that can be grounded to the steel housing of unit if your feed line comes directly from your main panel,not a sub panel,some localities will allow you to tie the white neutral and green grnd wire together in the unit chk your local ordinance first
Jul 11, 2009 | Dryers
Dryer will not start
Go to the breaker panel and make sure the neutral is making good contact. Especially check for corrosion. If it is good there, look for other connections between breaker panel and dryer. It seem to me you have a bad neutral somewhere.
Feb 24, 2009 | Whirlpool LER4634J Electric Dryer
3 to 4 plug dryer
Not really sure what you are asking. But if you trying to hook the cord up... Green and white go to the middle terminal Then black or red to either side it doesnt matter which.
Jan 30, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
How to hard wire 240 volt wall heater
Black is 120v hot
Red is 120v hot
Black and Red go to opposite legs to get 240v between them.
White is 0v neutral
copper is Ground
Dec 27, 2008 | Fahrenheat (FFH1614) Wall Mounted Panel...
Trying to install 3 way cord with a 4 way replacement cord. I have disconnected all wires and put them back. My question is concerning the white wire.The wires that are already connected to the dryer red,...
In a three wire system you have 2 hot wires (black and red) and a neutral (white). the ground is connected to the neutral at the dryer. In a 4 wire system you have the 2 hot wires, neutral, and a ground. (green). The ground is connected with the neutral at the circuit panel. The hot wires at the dryer should be on the outside scres, the neutral should be in the center and the ground should be under the green screw. *****. .
Sep 23, 2008 | Dryers
Used maytag electric dryer installation question
First off, you should be wiring your power cord directly to the terminal block inside the dryer. If someone just cut off the cord that is terminated inside the dryer, and you are attempting to splice the new cord onto the old one.. you are making a mistake.. take the new cord and bond it directly to the terminal block inside the dryer. If you have a new 4-wire power cord, you are probably dealing with a red/black/white and green wire. ( assuming it is a four prong plug).. The black and red wires are the power lines themselves and should mate with the red and black wires inside the dryer. The green ( is frame ground) and is normally bonded to a stud near the terminal block or the dryer frame. The white is the neutral line and is normally tied to the terminal in the middle and between the red and black tie points.. In line splices should not be done on this appliance.. Hope this helps..
Sep 06, 2008 | Dryers
REPLACING DRYER 4 PRONG PLUG
This is common issue. Due to some building codes the 3-prong configuration is no longer used in homes. The wiring is similiar with one exception. The 4-wire plug uses an additonal (WHITE) NEUTRAL wire.
Here's a brief explanation of how the plugs are configured:
Dryer 3 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
Dryer 4 prong wire configuration:
RED - 120 VAC
GREEN - GROUND
BLACK - 120 VAC
WHITE - NEUTRAL
BOTH plugs provide the SAME source voltages to your appliance:
220 VAC - provided across the RED and BLACK leads are what drives your heating circuitry.
120 VAC - usually tapped of the BLACK wire is used to run the drive motor and timer on MOST dryers.
The wire terminal block in the back of the dryer should have a black, white, and red wire running to it from the dryer wiring harness. With the 4 prong plug, simply attach the BLACK, WHITE and RED wires at the terminal block ensuring that you match the RED and BLACK wires as they are configured and attach the WHITE wire at the remaining terminal lug. Make sure you screw them all down securely. Attach the remaining GREEN wire to chassis (dryer frame) ground. I hope ths helps you.
Feb 14, 2008 | Dryers
Won't Start
do you have the power cord correctly hooked up and have the correct voltage ? is the white wire in the middle? you should have 120 volt with red-white . 120 black- white and 240 black-red... careful with electricity it can hurt and kill you. let me know if you fix this one...krazytech
Sep 16, 2007 | Frigidaire AEQ6000ES Electric Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
