Question about Sony VAIO PCG-K35 Notebook
There a blinking red light on the side of my sony vaio laptop that would not turn off. My screen would not turn on.
  • 253 Answers
SOURCE: VAio VGN-FS742 Screen does not display
Try to remove the battery, remove AC adapter, and press and hold power button for 45 sec. reinsert battery, and Plug and try again, if that doesn't solve it, you may need to try to change memory first, (cheapest) or the motherboard or CPU.
Please give good rating if this helps your issue, Thanks
Posted on Apr 12, 2009
SOURCE: power problem with sony laptop
Did u try holding down the function key and pressinf F2 at the same time sometimes this enables it.
Posted on Feb 20, 2010
Comp-U-Doc
  • 148 Answers
SOURCE: Sony VAIO Laptop won't turn on. The power lights
Unplug from A/C adapter & remove battery and let sit fo a while..
Put battery back and plug in the A/C adapter, then turn back on.
Posted on Mar 31, 2010
BElectric
  • 1140 Answers
SOURCE: why is my hard disk
This is perfectly normal. Your hard-disk indicator light is always blinking because your hard-disk is constantly being used by the operating system. Windows and other applications are performing operations in the background which require both reading from and writing to the hard-disk regardless of whether you are doing anything or not.
You only need to worry when the hard-disk light STOPS blinking . . . permanently!
Posted on Nov 03, 2010
  • 11 Answers
SOURCE: Sony Vaio E series laptop not turning on
check your ram slot.check your bios setup.or reset it.remove your battery press power button 3/5mnt and connect ac power now power on.
Posted on May 30, 2013
Sony vaio lapto black screen
Please check that they have any LED blinking. If it not blinking it is hardware issue. need to contact local tech. if it blinking. Reboot the computer and taping F10 button while you rebooting the computer and run system recovery and follow by the steps.
Mar 17, 2012 | Sony VAIO PCG-7181L, PCG-7182L, PCG-7183L,...
Mar 31, 2010 | Sony VAIO Notebook
Firstly the ac adapater went donw than a bought a new one and now my Sony vaio is Bllinking the red light what can be?
maybe the battery is very low, that's why its blinking or the new ac adapter you bought is not compatible with the computer.
That's why its blinking the red light.
Take care.
Mar 05, 2010 | Sony VAIO PCG-K35 Notebook
VAIO - blinking line at the bottom of the screen
MY VAIO TOO! there's a blinking WHITE LINE at the bottom. i just noticed.. my vaio's just months old.
Dec 15, 2009 | Sony Computers & Internet
I have a sony Vaio N250e. It powers up, boots up and get to the windows desktop. It will stay there for about 2 minutes then it just turns off on its own. I did notice that the battery light blinks twice....
Hi
Does this occur when charger is also plugged in?
If it does then sounds like the CPU vent ports are clogged and CPU may be overheating,
Turn laptop upside down and look at CPU vents, if clogged simply use vacuum cleaner to clear.
Aug 12, 2009 | Sony VAIO VGN-N250E/B Notebook
Sony vaio blank screen
pls consider changing ur RAM issue will be resolved most likely ok let me know , there is strong chance ur RAM is faulty, if power comes but unable to start the system u see blank screen and no hard disk activity and light blinking then it is the RAM issue
pls rate me if i solved ur problem or explain ur problem in detail
Feb 27, 2009 | Sony VAIO VGN-FE880E/H Notebook
PCG-8P3M starting problem
Hi there
plug an external monitor to the laptop to rule out the inverter
post back
Jan 21, 2009 | Sony VAIO PCG-K35 Notebook
42 in SONY LCD flat screen has red light blinking and won't turn on
Does the red light blink in a discernible pattern? How many times does it flash or blink?
Jul 11, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Laptop Screen turns black or red all of a sudden
Hi, Sounds more like a glitch in the movie file you were watching which caused the video problem. Something like this is rather common while watching CDs with scratched surface. Since there is no apparent problem after rebooting, then you probably need not be worried. However, if this frequently happens, then you probably should have the memory upgraded or at least checked. Good luck.
Apr 21, 2007 | Sony VAIO (PCWA-A200)
Sony VAIO PCG-K35 Notebook Logo
192 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
