Question about Poulan Pro Chain Saw 46cc 20"
I have a model 295 which was running, and suddenly it wouldn't get gas to the carburator. It has plenty of gas in the tank, and it gets a spark. No matter how many times I pull it, it won't start.
  • 144 Answers
Most likely a clogged fuel line, or clogged fuel filter.
Posted on Aug 05, 2010
Model o3o319 portable generator not getting gas or air has spark
your filter inside tank may be clogged take aome air and blow in the out let of gas to see if it maybe dirty. check the fuel line itself maybe weak inside and collaisping and not allowing fuel.
May 10, 2014 | Briggs & Stratton Briggs and Stratton...
Outboard troubleshooting. I have a 75 hp Mercury with 2 carbuerators. Serial # 6559142 it's around a 1989 model.. Problem= tank bubble pumps up tight...sits for a minute and gets soft...when I pump it up...
Sounds like the fuel pump isn't working, you can buy service kits though quite often corrosion will prevent you from removing the valves.. or it could simply be the fuel cap isn't venting, remove fuel cap and see if the engine continues to run!
Mar 18, 2017 | Boating
I have a 1998 Dodge Caravan. I got a "tune up" approx. 2 weeks ago with new spark plugs, fuel filter & air filter. It did fine driving around town & on a 130 mile trip. I filled up with...
Sounds like you got a tank of bad gas. That would easily cause your issues. Start by draining as much as you can, put a can of Seafoam in there, add a few gallons of fresh gas, drive to the gas station and tank up, and run that tank down until your gas light comes on before adding more. You may end up needing a fuel filter or plugs again, but with minimal run time on the bad gas, you'll probably be fine.
Jul 29, 2011 | Dodge Caravan Cars & Trucks
Will not start
THE BLOWERVAC COULD HAVE GAS PROBLEM OR A NO SPARK TO SPARK PLUG PROBLEM. TO DETERMINE THE SPARK PROBLEM FIRST, REMOVE THE SPARK PLUG, LOOK AT THE END OF THE SPARK PLUG (ENGINE END) TO SEE IF IT IS DRY OR WET WITH GAS, THEN RE-ATTACH THE SPARK WIRE WHILE THE SPARK PLUG IS LAYING LOOSE AND PULL THE ROPE TO TURN THE ENGINE AND LOOK TO SEE IF THERE IS SPARK OCCURING AT THE SPARK PLUG. IF THERE IS SPARK PRESENT, YOU HAVE NO PROBLEM WITH SPARK. REPLACE THE PLUG AND WIRE. IF NO SPARK CHECK YOUR WIRE LEADING TO THE SPARK PLUG TO MAKE SURE IT HAS AN ELECTRICAL CONNECTION AT BOTH ENDS, SPARK PLUG END AND ENGINE END. IF LOOSE FIX THE CONNECTION THEN RE-TRY THE SPARK/ENGINE TURN OVER BY ROPE METHOD AGAIN TO SEE THEN IF YOU HAVE SPARK. IF THEN YOU DO HAVE SPARK, RE-ATTACH SPARK PLUG TO THE ENGINE AND RE-ATTACH SPARK PLUG WIRE TO THE SPARK PLUG AND TRY THEN TO START THE ENGINE.
IF THERE WAS A WET PLUG WHEN YOU FIRST REMOVED THE SPARK PLUG AND YOU NOW HAVE SPARK AT THE SPARK PLUG, YOUR ENGINE SHOULD START.
IF IT STILL WILL NOT START AFTER THE SPARK CHECK, I WOULD REPLACE THE SPARK PLUG WITH A NEW ONE.
IF THEN IT WILL NOT START, THEN REMOVE THE SPARK PLUG AGAIN AND POUR A SMALL AMOUNT OF GAS INTO THE ENGINE SPARK PLUG HOLE. A PINT PLASTIC OIL CAP FULL OF GAS IS ENOUGH, DO NOT OVER USE MORE THEN THAT.
THE RE-ATTACH YOUR SPARK PLUG AND SPARK PLUG WIRE AND TRY STARTING THE ENGINE AGAIN. IT MAY TAKE SEVERAL PULLS TO GET THE EXTRA GAS IN THE SPARK HOLE TO BE USED UP BEFORE YOU START TO HEAR IT RUN ALITTLE AND FIRE NOW AND THEN.
IT SHOULD START THEN.
IF THEN IT DOES NOT START, YU HAVE USED UP THE GAS YOU PUT INTO THE ENGINE BY THE CAP FULL METHOD AND IT IS NOT GETTING GAS BY THE GAS TANK SUPPLY.
THIS MEANS THEN YOU HAVE AN IN LINE GAS LINE FILTER THAT IS PLUGGED UP OR YOUR GAS MAY BE OLD IN THE GAS TANK. IF GAS IS NOT OLD AND FILTER IS NOT PLUGGED, THEN YOU NEED TO REMOVE THE GAS LINE LEADING TO THE ENGINE CARBURATOR TO SEE IF IT WILL FLOW FROM THE GAS TANK OUT THE GAS LINE SUPPLY HOSE. IF IT DOES FLOW FREELY, THEN YOU DO NOT HAVE A GAS SUPPLY PROBLEM,
AS LONG AS YOUR GAS IS NOT OLD GAS. OLD GAS WILL GO BAD IN TIME. I'D REPLACE THE GAS WITH NEW AND TRY AGAIN.
IF THIS DOES NOT WORK, THEN ITS CARBURATION CLEAN UP TIME.
IT WILL NEED TO BE REMOVED FROM THE ENGINE BY A FEW BOLTS, HOSE'S REMOVED AND TAKEN APART AND CLEANED. TARNISH FROM GAS AND OIL WILL BLOCK THE CARBURATOR JETS AND VACCUM PUMP FROM WORKING PROPERLY. CLEAN AND REPLACE, TRY AGAIN TO START ENGINE.
MORE GAS IN SPARK PLUG HOLE TO GET GOING MAY BE ANOTHER ATEMPT AFTER CARBURATOR CLEAN UP.
Feb 20, 2011 | Homelite Mighty Lite Blowervac
My Briggs 10 HP Generator is outside and covered and wont start. It will run with gas sprayed directly in the carburator throat bit not on its own. I have just installed a carburator kit and a new spark...
Don't leave gas in the tank, or add additive to gas >>> you know that but the next reader might not know.
If you are able to get washer running by spraying WD-40 or some other accelerant directly into carburetor but engine will not continue running ... there are 3 suspects: 1) dirty air filter 2) the exhaust port is clogged with carbon, dirt, etc 3) the carburetor has given out or no gas is getting to carburetor
2) Check exhaust port >>> we finally broke the screen out with a screwdriver so it wouldn't bother us any more
3) Carburetor ... you have spark but the gas is either not getting to carburetor or carburetor is not letting gas in. Pull off rubber line going to carburetor and see if gas flows out. If gas gets to carburetor and all the conditions above are met, then the carburetor needs gum out or rebuilding or replacement
Oct 16, 2010 | Briggs & Stratton Briggs Stratton 6200...
88 ranger has a new fuel pump new gas tank spark and plenty of spin but it wont crank where is the fuel filter located
IF IT IS THROTTLE BODY THEN FILTER IS IN THE FUEL LINE UNDER THE FLOOR AT DRIVERS FEET, IF ITS CARBURATED, THEN ITS THAT 1"'1-1/4 ROUND THINGY AT THE FUEL LINE WHERE IT GOES INTO CARB...
Feb 27, 2010 | 1988 Ford Ranger
Poulan 446 Pro engine won't run
its probably not getting any gas from the tank try putting your finger on the hole on the carberator and pull your finger should be wet if not take fuel line of the carburator and thenblow then take off the gas cap and blow through the hole on the gas tank it should flow freely throgh teh line to the carburator
Nov 06, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Riding lawnmower wont run long
Check for dirt in gas tank some times stuff will fall in when filling and block the hole in bottom of gas tank and wont let gas flow clean everything out and see if it works. Also check that all kill switches are tight and not moving.
Oct 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Engine is suddenly getting no fuel. Turns over great. There is plenty of gas in the tank. It wouldn't run after driving around two days ago, then it ran all day yesterday all day yesterday, then after we...
Could be the fuel pump. Try hitting the bottom of the fuel tank a few times while someone try's to start it, if it starts then the pump is on it's way out.
Aug 02, 2009 | 1992 Chevrolet Caprice
Mower will not start
you could have water in gas,look in the gas tank for any bubbles floating on bottom of tank this is water empty gas from tank and remove carburetor bowl too remove water from it .
May 13, 2009 | Garden
Poulan Pro Chain Saw 46cc 20" Logo
118 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
