Question about Canon imageCLASS D320 Digital Copier
In the window it says supply rec.paper tray: freesize the Memory Alarm is blinking yellow and read
2 Suggested Answers
canontech
  • 1219 Answers
SOURCE: Light under memory/alarm is flashing red. Window
if the error is change paper size also, under printer properties set the paper size i.e. A4, by default its ltr and these can cause problems.After that turn off and on.
Hope that helps.
If not, send more detailed description.
Posted on Aug 29, 2010
Canon PC D340. The display says supply rec. paper tray: freesize. I have tried disconnecting the printer and reconnecting it but it has not worked. Can you tell me how to solve this problem...
Because the paper size of your software like Word is "custom", and the paper size setting of the printer is "ltr", the printer won't print until you change the paper size to "freesize". Change it in "Additional Functions" menu on the printer (Canon D340). (Word will change the paper size setting automatically if you adjust the margins of your paper too far)
Mar 31, 2011 | Canon PC-D340 All-In-One Laser Printer
MF5500 Paper Jams Everywhere
check the paper ,from cassete tray to the drum and exit,on every section you have a sensor,check it ,
Feb 29, 2008 | Canon imageCLASS MF5550 All-In-One Laser...
Hope that helps.
Aug 27, 2010 | Canon imageCLASS D320 Digital Copier
Supply rec paper tray - what does this mean when the tray is loaded?
OK, I was having a similar problem: Tray full of paper and tray adjusted properly.
Whatever I tried, the printer kept saying load paper.
I went to print menu>properties button (windows XP this is next to the printer name)>paper source tab.
It tuned out that the paper source had been changed from cassette to multi-purpose tray.
Change it back to cassette and you should be golden.
Jun 03, 2009 | Canon MF8180C Color Laser MFC Printer
Machine won't print, copy or receive a fax
With red button stop the copy, or switch off and on.
If you print on this unit make sure that you did choose a right format of paper (A4,A5,...)
You can change the format ap printer properties or preferences
May 21, 2009 | Canon imageCLASS® MF6550 Laser Printer
Paper jam
Open the paper tray and remove the first couple of sheets of paper - If the paper tray is fully loaded leave it half full.
May 21, 2009 | Canon Office Equipment & Supplies
Not working
Pull out the tray with paper.
You should find a moving plastic "tongue" near the middle of width in the area where your paper tray should go. It's a contact based flag for the device to consider how much paper is in the tray. Check if it's not broken or stuck in odd position. Move it back and forth several times, with no force, it goes very easily. When you lift the flag up, see message and blinking led stop appearing. Try to pull paper tray back in, add paper if error appears again. Enjoy!
Sep 15, 2008 | Canon imageCLASS MF5750 All-In-One Laser...
and PLEASE HELP
Make sure you check both paper sources, the side tray going empty will cause your alarm to go on
Apr 25, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Won't feed the paper
the problem with your machine maybe that the default paper size programmed into your machine. My guess is that it is set to legal size{ 81/2x14} Get your owners manual out and see how to program the paper size in the user settings sections.
Jan 18, 2007 | Canon imageCLASS MF5550 All-In-One Laser...
Canon imageCLASS D320 Digital Copier Logo
255 people viewed this question
old marine
old marine
