Question about Goodman CKL36AR36 Air Conditioner
My modle number is aruf 036-00a-1 my serial number
My modle number is aruf 036-00a-1 my serial number is 0405057196 im installing a pcb,time delay and i need to know the wiring color diagram because im tired of waiting on the guy
    Problem Solver:
  • 5 Answers
MY MODLE NUMER IS CPLE42-1 SERIAL NUMBER IS 010940037
Posted on Aug 06, 2010
Aaa
aa
I have a Goodman ARUF series air handler with a 10KW heat kit. The unit will not stop running and heats all the time. The thermastat is digital and is 3 years old.
your heat-relay aka heat sequencer, time delay... is stuck most likely remove and replace if it checks closed and no 24 volts is going to the timer portion.for 3 to 5 minutes. some of these switches stay closed for 3-5 minutes.after power is removed
Mar 02, 2012 | Heating & Cooling
Is my Beko fridge freezer modle number CDA 543 FW/1. Serial No : 0810184607. one affected by cathing fire.
No, you can relax.
Although your model is on the list of those affected. the serial number begins "08" so it's definitely not one of the affected models.
You can reassure yourself by clicking here.
Jul 06, 2011 | Microwave Ovens
Copier model canon ir 3300 error 000354-0002
E354 is a mismatch or absence of the serial number stored in the Serial Number PCB and Main Controller/Image Processor PCB or Counter PCB. Check and reseat connections to the counter and Serial number boards on the main controller.
Jan 10, 2011 | Kitchen Ranges
Canon ir2020-seystm err e354 please tel me what ido tanvir gillani
E354
•When turning ON the power, inconsistency of the serial No. of
the serial number PCB and that of the controller PCB
(SRAM)/counter memory is detected.
•When turning ON the power, it is detected that no serial
numbers are assigned to the serial number PCB and the
controller PCB (SRAM)/ counter memory.are you trying to change the counter board this not possible bec the serial no of the machine is embedded on the counter board so no counter tampering allowed
Oct 01, 2009 | Canon imageCLASS D320 Digital Copier
New Konica bizhub C351 copier with only 58 copies. It will make copies but it has a 6 1/8" x 8 5/8" BLACK area in the center of the 8 1/2" x 11" copy if you make a copy from the platen glass. It does not...
Gray box after installation.
Solution
CAUSE: Installation procedures were not completed properly.
SOLUTION: Complete the installation procedures thoroughly:
1. Adjusting Touch Panel - Press the Accessibility key, Touch Panel Adj.
2. Setting Gradation Adjustment - Go into Service Mode, Image Processing Adjustment, Gradation Adjustment. Service mode- ulilty/counter, check details , then(Stop00 stop01)
3. Touch High Compression Mode and press Start [perform 3 times].
4. Touch Gradation Mode and press Start [perform 3 times].
5. Touch Resolution Mode and press Start [perform 3 times].
6. Date/Time Setting - go into Service Mode, Press Stop, 1, 1, 4, 4, Clear.
7. Go into Utility/Counter, Administrator Setting, System Setting, Date/ Time Setting.
8. Install Date - go into Service Mode, System 1, Install Date.
9. Serial Number Input - go into Service Mode, System 1, Serial Number [If Serial Number is already there, Clear and re-enter it].
10. Unit Change - go into Service Mode, System 2, Unit Change.
11. List Output - Please Load 8.5x11 Landscape paper on Tray 1, go into Service Mode, List Output, and Touch Machine Management List and press Start.
12. Press Adjustments List and press Start.
13. Press Service Parameter List and press Start.
14. Press Fax Setting List and press Start.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 04, 2009 | Konica Minolta Office Equipment & Supplies
Error 354
E354
controller PCB (SRAM)/ counter memory , if you are try to change the counter pcb to get rid of high meter reading this error is possible, this a security measure of canon to prevent meter tampering
Jul 15, 2009 | Canon Office Equipment & Supplies
Washing machine won't start. when hit start 0' displayed
Hi, Unplug the unit from AC power for 30 seconds to 1 minute, This should reset it back to the defaults. Good Luck!
Feb 08, 2009 | Frigidaire Affinity ATF7000E Front Load...
Hi, i have 2pcs of canon iR2016 Digital copiers which displays error codes of E246 AND E247. these errors are not in the service manual, please help
Sir i am a Canon trained tech. I just checked our website and my service information. I found the following. I suspect someone has been working on these machines or swapped some parts around.
Page 1 of 2
MODELS AFFECTED / SERIAL NUMBERS AFFECTED:
Digital Copiers, Including All imageRUNNER Products
SUBJECT:
Information About The New Soft Counter Circuits
GENERAL TECHNICAL INFORMATION
GENERAL:
This Technical Publication presents information about the new Soft Counter circuit that replaces the mechanical counter
used in the past. There are three (3) PCB’s associated with the new Soft Counter circuit; the Counter Memory PCB,
Main Controller PCB and the Serial Number PCB. A description of their function is provided below. Use this
document as a reference for current and future models that use the Soft Counter circuit.
Counter Memory PCB
On the latest Canon digital copiers, such as the imageRUNNER 5000, imageRUNNER 8500 and imageRUNNER 2200
series, there are no mechanical counters. Instead there is a Counter Memory PCB. This PCB is usually mounted on the
Main Controller PCB with one screw. The Counter Memory PCB is imprinted with the serial number of the machine
the first time power is turned ON and cannot be moved to another machine. Attempting to do so will generate an E246
error code. In the event of a Counter Memory PCB failure, a new one from stock (see Note 4) can be installed into the
machine. At that point the Main Controller PCB will transfer its present total count as indicated in “Counter Check” on
the control panel (recorded the last time power was turned OFF) to the new Counter Memory PCB and the total counter
will increment from that count on. Never attempt to operate a machine without the Counter Memory PCB
installed!
This may generate an E245 code, which can only be cleared by “zeroing out” the Main Controller PCB by
one of our A.P.R.F.’s (Authorized Parts Repair Facilities).
Main Controller PCB
The Main Controller PCB, aside from performing other tasks, retains the total count by means of SRAM with a battery
back up after power has been turned OFF. If, however, the Main Controller PCB has been replaced with either a new
one or a used one, it will read in and record the total count from the Counter Memory PCB retained the last time power
was turned OFF. The total count will then increment from that count on.
Note 1:
Even though the total count will be the correct value for that machine after replacing the Main Controller, the soft
counters in Service Mode will not. If a new Main Controller was used for the replacement, then all soft counters in
Service Mode (service counters in “Counter Mode”) will be zero. If, on the other hand, a used Main Controller was
used for this replacement, the soft counters previously recorded on that PCB would be shown. At that point it is
advisable to clear these values in Service Mode using Function>Clear>CNT-MCON.
All Main Controllers sent to our A.P.R.F.’s for repair will be “zeroed out” before being sent back to the dealer.
Page 2 of 2
GTI-T151
04-30-02 GT I
Note 2:
The Counter Memory PCB and the Main Controller PCB should never be replaced simultaneously!
This will
generate an E354 code and assistance from the Canon Reseller Technical Support Center Hotline will be required. If
the Main Controller is sent to one of our A.P.R.F.’s for repair, you must remove the Counter Memory PCB
before sending it out!
Failure to do so will only increase down time for your customer.
Note 3:
If the Main Controller PCB is replaced, ensure that connector J1023 is connected. If it is not, an E350 will be
generated.
Serial Number PCB
The Serial Number PCB’s main function is to identify the machine’s serial number. This PCB cannot be moved to
another machine.
Attempting to do so will generate an E355 and assistance from the Canon Reseller TechnicalError codes not listed in the Service Manual:
There are various error codes that are not listed in the Service Manual. Canon U.S.A., Inc. reserves the right to treat
these error codes as Proprietary Information. If you encounter any of the following error codes, contact your Canon
E245 E246 E247 E350 E354 E355
Note 4:
Please be advised that Canon U.S.A., Inc. treats the Counter Memory PCB and Serial Number PCB as “restricted” parts.
When a dealer orders these components they will be asked to provide the reason for their replacement, and the original
PCB will have to be returned to Canon U.S.A., Inc. for evaluation.
Jan 07, 2009 | Office Equipment & Supplies
I can't find the serial number for my bamboo fun?
look on the back of the tablet,were the bar code is. There will be a number about the bar code which is the modle number and the will be a number below that says S/N:______(what ever number you have) The S/N is the serial number.Hope this help I'm trying to install my Wacom as well
Dec 26, 2008 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Goodman CKL36AR36 Air Conditioner Logo
665 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
