Question about Admiral AAV7000A
Won't fill washer will not fill during rinse cycle. not always - 50/50. water runs in and out simultaneously. i was told "float is sticking". can i get to the float without tearing apart the whole machine?
  • 246 Answers
Probably a siphon condition. Remove the drain hose from the wall. Now re-insert only 6" of it. If you put it too far down inside the wall it can cause an intermitent siphon condition. Make sure you tie down your drain hose so it does not pop out durring the drain cycles.
Posted on Jun 16, 2008
Washer won t fill water
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
Dec 04, 2013 | Frigidaire Washing Machines
Tip
Dishwasher Water Temperatures
No matter what detergent you use, the "pills", powder, or gels, they are meant to activate PROPERLY, key word PROPERLY, at a minimum of 120 degrees Fahrenheit in a dishwasher. I recommend ALWAYS using the "high temp wash, boost, etc" on ANY cycle in order to keep the water HOT! Always run the hot water in the sink prior to starting the dishwasher! The unit is tied in to the hot water line under the kitchen sink and requires very little water to fill--by the time the hot water finally reaches the dishwasher, chances are it'll be running on cold or tepid water--the detergent won't dissolve or activate the way it's supposed to. Not only that, in between fills during the cycle, especially in winter, the water will cool down in the pipes too much. Normally, the water heating selection will maintain water temps in the 130-150 degree range! If someone has been sick in the house, turn on the SANI RINSE if your unit has it! This won't stop--but it'll help prevent cross contamination--people getting sick from the dishes--this setting normally kicks the water temp up to 190 degrees during the rinse cycle.
on Sep 08, 2015 | Dishwashers
SM 8525492A whirlpool washer rinse cycle no water comes out, just hums
when the washer goes into rinse cycle it only uses cold water so clothes don't rinkle,so most likey you have a problem with your cold water,do this,shut down the water to the washer,remove the water lines from the back of washer and mark them so you know how they came off,stick the hoses into the washer if they reach or a bucket,turn on the cold water to see if water is coming out of hose,if water does come out of hose good then stick the cold water hose back on the washer and run it only on cold,if it doesn't fill then you know you have a problem with the water valve on the washer and it's not the house water valve that's bad,and usually if you have a problem with the washer water valve it will just hum and no water will enter the washer so if you hear a humming sound it will be the water valve.tried looking up the model number you sent but it doesn't come up on the parts lookup
Apr 25, 2013 | Washing Machines
The washer only fills halfway up during rinse cycle only, even on high water setting. it fill completely during the wash cycle.
Has it always done this or just recently? Some washers have lower rinse fills then spray the water on the clothes as it goes through its cycle.
Sep 24, 2011 | Estate Washing Machines
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
Aug 26, 2011 | Maytag Washing Machines
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Jun 24, 2011 | GE WPGT9360EPL Top Load Washer
Washer wont fill up during rinse cycle
all rinse cycles are filled with cold water to keep the clothes from wrinkling.set up the washer to run with just cold water.start it,if no water comes into washer,shut down your house water valve that fills the washer,take off the cold water hose,stick it in the washer or if there's a sink or where ever and turn on the water,if water comes out of the hose then you need a new water valve on the washer
Feb 15, 2011 | Whirlpool Washing Machines
Water won't fill
it's syphoning caused by the drain hose in the stand pipe (wall) too far.
pull the drain hose out and stick in 6 inches only and secure to one of the fill hoses so it does not go back down too far. This will solve your problem
Apr 05, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My washer keeps filling with water even after the cycle is going. I put it on small load, it fills to the right level for a small load, the cycle begins and soon the washer is overflowing. Even after final...
hi there......wow !! your using a lot of water...sounds like you have a failed inlet valve resulting in water flowing continually into the machine.....remedy relace the inlet water valve
regards Sir Galahad
Aug 12, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Admiral AAV7000A Logo
61 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
