Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I need 2 get the thing that turns the blade - Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
  • 144 Answers
The thing you are referring to is a belt most likely. Go to a hardware store and tell them the make and model of your mower. If you do not need a belt you will need a pulley.
Posted on Aug 04, 2010
What direction to turn nut to remove blade from an HU625AWD LAWN MOWER
normal right hand thread so counter clockwise to undo
Apr 30, 2017 | Garden
My blade does'n cut what am I doing wrong
Hi Nancy:
The first two things I would check:
1) Are the blades turning?
2) Were the blades installed upside down?
Reply as a comment on this post and I'll try to coach you.
Cheers
Nov 01, 2015 | Garden
The blade on my new skil 3310 won't raise. It came preassembled & has never been used, but the elevation wheel feels locked. I can adjust the angle, but turning the knob doesn't raise/lower blade.
Just as a question and I am not being smart you know that the wheel to raise the blade work counter clockwise.
The other thing you need to check is in your manual here is the part how to adjust the blade for raisin/lowering.
After five hours of operation, the blade elevation/tilting mechanism should be checked for looseness, binding, or other abnormalities. Disconnect the saw from the power source, turn the saw upside down and pull up and down on the motor unit. Observe any movement in the motor mounting mechanism. Looseness or play in the blade raising screw 1 should be adjusted as follows (Fig. 55): 1. Loosen nut 2. 2. Adjust the nut 3 until it is finger-tight against the bracket 4, then back off the nut 3 1/6 turn. 3. Tighten nut 2. The maximum allowable play of the screw rod 1 is 5/32" (4 m). Place a small amount of dry lubricant (such as graphite or silicon) on the screw rod 1 at the thrust washer 5. Do not oil the threads of screw rod 1. The screw rod 1 must be kept clean and free of sawdust, gum, pitch, and other contaminant's for smooth operation. NOTE: If excessive looseness is observed in any other part of the blade elevation mechanism or tilting mechanism, take the complete unit to an authorized service center.
Oct 21, 2015 | Skil Saws
My poulan 18 inch chain saws blade turns but only cuts in about an inch and won't go any farther. It's two days old and worked fine cutting the first 2 trees down.
It sounds like the chain does want sharpening, it depends on what you are cutting ( type of timber, dirty timber,burnt timber etc ) as to how long before it needs sharpening, if the chain comes into contact with the ground below the tree it will lose its edge instantly.
Dec 29, 2012 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Edger blade quit turning on convertible weedwacker
One of 2 things...drive cable broken or clutch spring broken
Sep 10, 2012 | Sears Craftsman Convertible 25cc 2 Cycle...
During mowing grass will gather underside of deck leaving 2 streaks on r and l if you turn deck off grass will fall out of deck before restarting u need tgo move or mower will stall from grass build up...
There are a couple of things going on here. First, the blades are likely worn out and need replaced. As they wear and loose some length they can leave a trail. Second, if you have regular blades on a deck configured (by having discharge plugged) for mulching and you are using regular blades, then you can have a problem with build up. Third, you can have clumping problems if the grass is not dry when you are mowing.
I hope this is helpful for you.
Aug 24, 2011 | Ariens 48" Riding Lawn Mower Blade ...
How to put together the blade
askmanny.jpg Instruction to assemble a clipper blade.Above picture Socket askmanny_0.jpg
Turn Socket & Spring Tension over Make sure Socket is slide back askmanny_4.jpg
This is Call a Blade Guide Make sure the blade Guide is on the Spring Tension askmanny_5.jpg
Make sure blade guide is on like picture above, Now place Socket & Spring aside askmanny_6.jpg
Place cutter blade as picture above, making sure cutter blade smaller blade is on the comb blade Rail. askmanny_9.jpg
Hold the blade like this Finger on top and Thumb on the bottom askmanny_10.jpg
Turn blade over like this while still holding the blade together askmanny_11.jpg
Now that you have the 2 screw in and not tight place the blade like this You need to hold the blade with one hand and with your Philips screw driver tap the cutter blade back lightly until the cutter teeth are 2/32 back from the comb blade. askmanny_14.jpg
the cutter blade which is the smaller blade is back 2/32 from the comb blade which is the bigger blade. When this is done by holding the blade together with your finger & Thumb askmanny_15.jpg
We hope this was helpful when assembling a clipper blade.
May 11, 2011 | Andis AG 2 Hair Trimmer
I have an old Sears Jig Saw, model 110 25710, that has a broken blade. I need a new blad and instructions on how to remove the broken one, and replace it with the new one. Can you offer any assistance?
Take a look at the point of blade locking to the tool. Should be 2 hexagon bolts. Using the right size tool, unscrew them carefylly, pull out the broken blade, go to your local hardware store, and get a new one that will have the same size on the tail. ( the side that gets inside the slide on the saw). Slide the new blade to the saw, and tighten the bolts back but do it equally twisting them in turns, half a turn each time to keep the blade staying straight.
Whole thing should last no more than 5 min. ( Remember to keep the power cable unplugged all the time you make the change. Your fingers are priceless).
Sep 08, 2010 | Sears Saws
A5 dog clipper or blades may need tune up or
some times the link and gear inside the front part of the clipper wears out and the blades just wont cut. try this, remove the clipper blade on the front of the clipper their is a lever color red grab this part with your 2 fingers and move it side to side if it moves and feel sloppy your gears and link are worn out. you need to replace, also check the hinge for spring tension. if you need help Contact mannyssharpening@yahoo.com
Feb 22, 2010 | Oster Golden A5 2-Speed Universal Motor...
I hit a rock and bent the blade on a yard machine. Replaced the blade and tried to start the mower, but the start rope doesn't come out all the way and recoils hard as I'm trying to pull it out.
I did the same exact thing over the weekend, try adjusting your new blade unscrew the main bolt to the blade about 1/2 turn that should get it spinning again, same exact thing happened to me. Good Luck
May 17, 2009 | Mtd 22" Yard Machine Push Mower
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
