Question about Amana ALG331RAW Gas Dryer
Does an Amana gas dryer Model PLG8409W2 have a pilot
  • 71 Answers
SOURCE: Amana gas dryer
there is no pilot it has an ignitor bar that glows when it lights the gas.
Posted on Dec 20, 2008
kachbibi1
  • 979 Answers
SOURCE: heat in dryer not hot enough, runs cool not hot
You may have a leg of power out. First turn off the breakers, then back on to insure a good reset. Then check the wiring at the receptacle, then the plug, then the wiring to the back of the dryer. This may be the problem. Have you cleaned the lint tray?
Posted on Feb 10, 2009
  • 84 Answers
SOURCE: my amana gas dryer (model # lg8519w2)has an
first check you exhuast. If you have access to the vent outsid where the vent termintes the check and see if there is no lint build up or make sure nothing is block the air flow to the outside(storage caontainers or anything that will block the airflow from the dryer to the outside)..if no blockage or lint build up, then i would change you gas coil vales. they are located on you gas valve. they are 2 black looking things. But make sure when if you change them,one of them has a metal sleeve that goes on the shaft...make sure you know whick one it came from and slide it back on there..sometime when you take the old oned out, itll come off with the coil. Just take it out and slid it onto the gas valve. Like i said tho, make sure you know whick one it came off from...but yeah, try changing you gas valve coil....if its an amana dryer then there should be that bottom panel to take off and the gas valve should be right there..hope this helps
Posted on Jul 27, 2009
SOURCE: amana gas dryer mod #NGD5240TQ0 intermitten heat
i went to a local appliance store asked them for assistance. they were more than helpful and sold me the parts i needed. fixed the problem for under $30.00. i also didnt have to pay for their ADVICE !!!
Posted on Aug 23, 2009
  • 11 Answers
SOURCE: Amana gas dryer Model #ALG866SWB: When pushing
The motor is bad and needs to be replaced.
Posted on Jul 24, 2010
It wont heat
never heard of having a pilot light as well an ignitor, the two don't go together. If your have a pilot light that is on the unit is getting gas. If there is pilot light there is usually a knob to switch between pilot light, off, and active on. maybe set to pilot light only.
Nov 09, 2013 | Amana ALG331RAW Gas Dryer
No heat gas log furance
if it has a pilot light, then it would not have an ignitor. also if it has a pilot light, it should have a knob that has settings for just the pilot light, just off, or on. Find that knob and check settings
I have an Amana Designer Series Gas Dryer. It worked fine for more than 10 years. Suddenly, yesterday it still ran, but there was no heat. I opened the bottom panel while it was running, and...
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Sep 22, 2011 | Amana ALG331RAW Gas Dryer
How do I relight my amana ALG331RAW pilot light?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 16, 2010 | Amana ALG331RAW Gas Dryer
Amana NDG2335AW Gas Dryer runs but doesn't heat
Check the spark ignitor when firtst starting the dryer up. It should click within the first 15 seconds to light the pilot up
May 31, 2010 | Amana NDG2335AW Gas Dryer
Is there a pilot light on amana gas dryer model LG4309W
There is no standing pilot light. The gas is ignited by a hot surface device that is electrically controlled. Trace the exhaust venting to locate the burner area.
Sep 08, 2009 | Dryers
Amana Gas Dryer Model LG44097 suddenly quit heating. Can I correctly assume the problem is the Fabric Selection knob, part PS2201078 that controls heat/no heat?
probably not as these rarely go. More likely is that the glow bar ignitor on the gas valve has failed. Unlike old gas models, today's dryers do not use a standing pilot but a glow ignitor. This is the weakest link in the system. Part number fsp-279311
Apr 09, 2009 | Dryers
Amana gas dryer
Sep 03, 2008 | Amana ALG331RAW Gas Dryer
Gas Dryer won't stay hot
There is a thermoelectric eye that says it is OK to keep the gas burner on. If this sensor is defective or blocked from "seeing" the gas flame is properly lit, it will turn off the gas flow (safety) override solenoid. With the unit unplugged make sure that the optical path on the upper right (1:30 CW position) flame tube inside sensor window is clean. The rattle you hear is probably the safety gas shut-off solenoid engaging. If you need more help, please ask -- SWT
May 03, 2008 | Dryers
Amana ALG331RAW Gas Dryer Logo
41 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
