Question about Nokia Cell Phones
I have a 6255i that just will not boot up...key pad lights then cuts off after a couple of seconds. Battery seems to be fine and phone does the same thing when on charger. My biggest concern, other than losing the use of my phone, is how can I get my contact list off? Are there forensic drive information recoverers like with PCs? Sure could use some advice and help.
  • soytnly Aug 05, 2010
  • 4,102 Answers
Hi, to me it sounds like the problem is with the phones firmware, you may be able to get this wiped and re-installed at a phone shop for a small fee, doing this will wipe everything on the phone such as numbers,ringtones,messsages,pictures etc
you can get the info off the phone if you have a cable from your phone to usb port on computer then all you need to do is download nokia pc suite and connect the phone,once you have done this and connected the phone you will be able to access the info stored on your phone and you can then back it up on your pc until you either get the phone fixed or get another nokia
hope that gives you a good idea of the way to save your data, all you need to do is get a nokia data cable for your phone, you can get one from the well known auction site for next to nothing.
nokia pc suite is free to download just go to google search page and type in free nokia pc suite then hit search this will then list loads of sites that will let you download the nokia pc suite for free and you can then back up everything on your phone to your pc
let me know how you get on or if you need further assistance ok
Posted on Aug 05, 2010
  • soytnly Aug 06, 2010
    Many thanks for the extensive reply. Two questions though.
    1. If the phone will not boot, can I still use the Nokia PC Suite to retrieve the phones info...contact list, pics, etc?
    2. If so, I would certainly need to do this prior to having the frimware rest, right?
    Again, many thanks.
    President:
  • 2,559 Answers
Just remove the battery and hold down the power button for 20 seconds,(this allows for discharge) reinstall the battery and restart the phone,This should fix this issue
    Thanks for the reply. That didn't do it.
  • 881 Answers
Nokia's PC suite can do that. You can also copy all your contacts from phone memory to your sim card.
Posted on Aug 04, 2010
    Where do I gain access to the Nokia PC suite (I'm on a Mac)?
    If the phone will not boot how, can I access phone memory and I do not believe I have a sim card.
Problem To Start
It s fix. Not the wiring problem. The battery is lack of power. So I charged it only and it seems to be fine. thanks anyway
Jun 01, 2009 | 1992 Daihatsu Charade
Keys on Blackberry 8330 don't work
First I disconnected the battery again and let the unit sit for over an hour. Then I took the phone and went through every button to make sure that one of them was not stuck. For one reason or another after replacing the battery this time the phone started to work again. I had tried taking the battery out while it was turned on to reset the unit a couple of times. The 30 seconds they suggest, and 5-10 minutes. Neither of those attempts fixed the unit. I would say that letting the unit sit and checking for stuck keys allowed the unit to reset itself and everything seems to be working fine now.
Jan 28, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
Nokia 6255i mini screen light won't go off
go to the settings set the light AUTOMATIC,, do not choose ON,, if it will not work you must go with the warranty of it, it is the format programmed of your cellphone that will not allow to enable light,
regards JAN_yuanjia
Nov 27, 2008 | Nokia 6255i
how can i get the keypad ights on nolia 6255
Feb 19, 2008 | Nokia 6255i
Nokia 6255i will not turn on
Probably noting wrong with the battery, might be a hardware issue, I recommend you take the phone for analysis to a phone shop.
Feb 12, 2008 | Nokia 6255i
REPAIR NOKIA 6255I
bagaimana sih format nokia 6255i, menggunakan *#7780# masih aja tidak hilang applikasi yang ada di hp
Jan 17, 2008 | Nokia 6255i
V3i Problems
you need to have the flex cable replaced
Dec 30, 2007 | Motorola Mobility RAZR V3i Cellular Phone
Phone shuts off
it could be two problems. one is the battery, clean the connections with Alcohol, or place a small piece of paper between the case and the battery to push the battery down more towards the coonector. second problem could be your key pad flex.
Nov 11, 2007 | Motorola Mobility RAZR V3
Nokia 6255i keypad problems...PLEASE HELP!
if you manage to open the phone you go to the face plate were the key pad is possitioned and clean it with isoprophyl alcohol that can curethe problem . advice by dogy
Jul 03, 2007 | Nokia 6255i
Some of the parts on my keypad do not glow
send to shop to fix or change you led on keypad
Aug 02, 2006 | Nokia 6255i
Cell Phones Logo
18 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
