Question about Dryers
I have a Creda T622CW condenser tumble dryer, that appears to be working fine, other than leaking water all over the floor rather than into the collecting box. i have read that this a a problem with the drain cap being blocked, but i can feel that the hole is clear. I haven't yet taken the tumble dryer out of the garage to see if there are any other problems? Ehat do you think could be the problem please? Regards Jayne
3 Suggested Answers
SOURCE: drum wont turn on my creda t622cw tumble dryer
my tumble dryer drum wont go round
Posted on Mar 11, 2009
barkencoa
  • 3463 Answers
SOURCE: Creda T622CW condenser tumble dryer drum wont turn
You need to check if the belt is o/k.
Remove top cover, and grasp belt, it should be firmly wrapped around drum.
If o/k, then could be a motor problem, or programmer fault
Once you have got the drum turning again, it is possible the filter light will go off,if not, then you have another fault
Hope this helps.
Posted on Dec 16, 2009
Hi my miele condenser tumble dryer t294c has started leaking water from inside machine and leaking onto floor has anyone any sugestions of the problem I'm getting thanks
you should remove the cabinet then pour water in and jumper the door switch and run and check where and which hoses are leaking if any? check ur water pump for damage and leaks
Feb 28, 2015 | Miele Dryers
My creda simplicity t622cw condenser dryer wont turn
Broken or belt has come off. If can open back and fix or replace. You may need to remove the top. Careful of the heat element, lift out drum and place new belt on motor holding it while you put the drum back keep hold of belt and place around drum replace top and should be ok. Hope this Helps
May 25, 2010 | Dryers
Hope this helps.
Dec 16, 2009 | Dryers
Tumble dryer wont dry
hi do you have any blockages in the vent system (lint) can you hear the fan running and are the filters clean.did you put it back together correctly.hope this helps.
Mar 05, 2008 | Dryers
Thermostat wiring diagram for creda t622cw
I assum there are four wires, you really cant get them wrong as they are all Neutral wires so it won't go of bang, it just may not heat as it should, I would connect them as you think it should and try them.
Dec 02, 2007 | Dryers
Drum wont turn on my creda t622cw tumble dryer
Nov 15, 2007 | Dryers
Not collecting water in the tank
I also have this problem and is leaking all over my floor underneath...i've only had it a day. the condenser is soppin wet and no water in the tank..i'm dead angry...anyone else have an idea how to fix this mother F*****...thanks...clair
Sep 21, 2007 | Zanussi TC7102W Electric Dryer
Dryers Logo
145 people viewed this question
Top Dryers Experts
