Question about Sharp Televison & Video
What guage wire do I need to ground my TV antenna to my grounding rod?
    Genius:
  • 1,340 Answers
I would recommend something thick.8 or 4.Maybe thicker depending on the lightning activity in your area.Good luck!
Posted on Aug 05, 2010
How do I ground a tv antenna ?
run a wire from the antenna to the ground. 10 gauge wire min, and attach to metal post at least 3 ft into the ground.
Aug 23, 2015 | Televison & Video
How do I connect icom 9100, MFJ IntelliTuner and PW-1 AMP?
Well I'm not an expert, but it sounds like you're going to need some short RG8U and RG8 coax pieces with connectors at each end, a 3 or 4 way antenna switch, a ground buss, some heavy ground wire (6 ga. or heavier) and an 8 foot ground rod if you don't already have this stuff. I never used an amplifier with my radio, but I would assume that the coax out from the radio goes to the input of the Tuner via coax, in which you can use RG8U for short lengths 3 feet or less. Then from the output of the tuner to the amplifier input. The output from the amplifier to the antenna switch which has your varoius antennas connected to it. You might want to use RG8 to connect the amp to the antenna switch to prevent power loss, especially if you use a piece longer than 4 feet. Make sure that all devices are properly grounded via a heavy ground buss (I used a solid copper bar 1" wide x 1/4" thick and 2 feet long. Then run a heavy wire (6ga. at least) from your ground buss to a ground rod at least 8 feet long that has been pounded into the ground at least 6 to 8 feet away from your dwelling for proper grounding. Make sure that your radio, tuner, amp and switch are all grounded to your ground buss. If you work 2 meters or 440, you might want to get on a repeater and double check with someone who can verify these connections. As I said, I didn't use an amp or a tuner as my radio was 100 watts and had an internal tuner. Enjoy your rig. 73! N2MKG...
Aug 26, 2014 | Radio Communications
Grounding uhf antenna
First off, using a Ground post driven into the soil is important. The best ground post procedure is to SLANT a 6 or 8 foot rod into the soil at an angle (not directly down). The angle allows for a greater ground surface and is more effective. If a Ground rod is cut off because it cannot be driven deep into the soil; this defeats the need to ground electronic or other devices.
12G wire is OK for an antenna if 8 or 10 are not available. Copper is best, but aluminum will work. The Grounding bock is attached to the mast, usually near where the antenna if affixed to the mast. Simply drill a small hole into the Mast section using the block as your guide. Using a hex driver and small hex screws, tighten the block to the mast. Good contact is necessary, so tighten all attachments. I suggest getting Rubber Boots or Covers to protect the connectors on the block from corrosion. The reason I attach blocks to the mast is to ground the Mast first and Antenna second. Not a critical feature. You may also use petro-jelly to cover the nuts, bolts, and screws to prevent corrosion or binding.
Dec 18, 2013 | Cable Wholesale F-Pin Coax Grounding...
How to ground a circuit breaker panel to an outside ground rod
First of all you need to have two grounding rods outside the house. Usually they're 12' long and have to be driven in 11-11.5 feet... but different particulars apply to different states and local codes. Ground rods should be placed no less than 6' away from each other and as closely placed as possible to the equipment or structure they are intended to protect.
wrap the stripped 14 AWG wire tightly around the copper ground rod. Try to get it as flush against the rod as if possible so that when you heat the rod later, it bonds very strongly at all points. Then heat the copper rod, rather than the wire and allow the wire to be heated by the rod. Don't heat wires directly or instant oxidation will occur, making it much more difficult to solder. Leave the ground rod to cool off for about an hour.
You would then dig the area to place the rods. The wires running off of them need to be ran to the circuit breaker box and terminated to the grounding bar. If there isn't a grounding bar in the box (only neutral) you can buy a single grounding bar specific to your box to install.
Jun 23, 2012 | Square D Qo 100 Amp Breaker Box Qo120m100...
My cb on uk40 has a problem, i get a strong signal on chnl 1 but a weak on chnl 40 it is a homebase airiel do i need to lengthen or shorten the airiel or is it cause i need to earth the airiel and is ther...
To ground the antenna you want to put a ground rod in the ground and use a copper braid strap between the antenna and the ground rod. Make sure no gas pipes or lines are in the area you are driving that ground rod into the ground. Put a couple round circles in the coax in a couple places too and make sure they stay. This will stop lightning from traveling into your home should there be a strike. You need to match that antenna to your radio. You want to hook an SWR/watt meter in line with your radio to get the best consistent reading. If you get a stronger signal with your CB on lower channels then I'm led to belive your antenna is to long. You really should put an SWR/watt meter in line to be sure of the SWR. If the SWR on channel 40 is higher than that on channel 1, your antenna is too long. If the SWR on channel 1 is higher than that on channel 40, your antenna is too short. Adjust the tuning coils according to your findings.
Mar 20, 2011 | Uniden PRO510XL 40-Channels Base CB Radio
Grand prix gas gauge not working
should be a grey wire going to the top of fuel tank connects to fuel guage / when the guage in the tank reads grounded it shows full , no ground it shows empty. if you ground that grey wire and the guage jumps to full then faulty guage if nothing maybe bad ground on the tank itself. the guages are a reostat like a tyco race car gun the more it moves the more it grounds .. good luck
Nov 19, 2009 | 2000 Pontiac Grand Prix
Radio/tuner reception
You will need to buy a signal amplifier antenna. One that doe not have to be connected to the Clock/Radio. It will provide the amplified signal and the radio antenna (the a/c line cord and the back of the clock/radio) will be able to pick up the signal from the amplified antenna.[http://www.radiolabs.com/products/antennas/am-antenna.php] this web link will show you one type of these antenna's. Copy the web link and paste it into the address bar in your browser. It will take you to the website. There maybe other types of these antenna's but this one had the best price. Call the store and talk to them before you buy the antenna to make sure it will work in your situation. I hope this information helps you with your antenna problems.
Feb 21, 2009 | Emerson Smartset Clock Radio
No range for my Bulldog Remote Start.
Get a Viper 5900, it has a 1 mile + range
Or a viper 5601 has a 2000 ft range.
Bulldog is DIY and entry level stuff. You cant expect much from them.
The wire antennas work the best when they are stretched out. Not wadded in a ball or in a loop. If you have to loop it use figure 8's. Try streatching it up the "A" pillar and in the headliner across the top of the windshield. Also, do not ground the antenna, and let the end hang.
Also check your hot and ground connections. Make your ground at the kick panel sheet metal. Do not use a factory ground or a metal bracket in the dashboard. Do use a file or sandpaper to buff the ground site to the bare metal.
Guy
Jan 09, 2009 | Bulldog Remote Starter & T-Harness Kit for...
Cobra set up
Hello John;
You can ground both the antenna mast and the antenna. your best bet is to place an 8ft grounding rod in the ground from radio shack or local two-way radio shop. Then connect the grounding rod to your mast. You can get a polyphaser from your local two-way radio shop this will connect between your antenna and the radio. it will also be grounded to the grounding rod. This should leave you in pretty good shape.
Happy DXing
Pat N5SLI
Apr 03, 2008 | Radio Communications
Cobra 200 GTL DX 3rd edition Installation
Hello John. A good earth ground for your antenna is more important than for the radio. Using the closest possible point to the antenna pole, preferably within a couple of feet, you need to ground the antenna pole to the earth. Go to a hardware store and buy a copper grounding rod which will be eight foot long and buy, as little as you can possibly get away with, some of 10 gauge wire and some kind of clamps that will attach the wire to the antenna pole and to the grounding rod. Google "antenna earth grounding" may help also.
Apr 03, 2008 | Cobra 200 GTL DX 4-Channels Base CB Radio
Televison & Video Logo
79 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
