Question about Shop Vac Vacuums
Check Amazon.
Posted on Oct 18, 2010
I need a manual for a Sop-vac 1.5 gallon.
Have a look at this page and if it matches your product, you can click "user manual" on the right hand side to download a PDF version of the manual.
Shop Vac 1 5 Gallon 2 0 Peak HP All Around EZ Wet Dry Vac
Sep 19, 2017 | Vacuums
I have the porter cable 10 gallon tool trigger drywall vac why is it that the bags keep braking. Have had it for years and it's only been about the last two years they rip open way before they are half...
Need some more information, are you vacuuming dry wall dust or wet dust or saw dust ? The reason I ask is sometime their are "upgrades" available for the newer models of vacs you may not be aware of, when I worked at the Big Box H D tool rental center the vac we rented out used a water filtration set up instead of bags U might wont to check newer model for any changes, like you ,I had Craftsman for over 15 yrs. and when it died the replacement vac had a new mod for the filter that I always thought was needed. Good luck , Bret
Sep 28, 2014 | Porter Cable 7812 Wet/Dry Vacuum
I need a user's manual for Voltcraft Fast Charge Delta Peak model MW3610HC. I believe it is a battery pack charger. It is a Europian product that requires a U.S. AC adapter. I want to know what size...
  • V detection
  • Cigarette lighter plug
  • Double output
  • Discharge function
  • Dla Ni-Cd/ Ni-MH battery
  • Input voltage: 230V AC, 50Hz, 13.8V do 24V DC
  • Output :
  • Dla 230V AC or 24V DC input: 5.6V DC (4 celle) do 11.2V DC (8 cell)
    • Dla 24V AC input: 5.6V DC (4 celle) do 8.4V DC (6 cell)
  • Output regulowany : 1,000/2,000/3,000mA
Sep 04, 2011 | Vacuums
We have a scunci recharge cordless wet-dry vac model # 52033. The battery does not charge. What can we do to fix this?
if the charger is working, and the battery does not hold a charge for very long, you will need a replacement battery. this is the most likely problem. if the battery does not charge at all it may well be the charger and you will need to replace that. hope this helps
Jun 08, 2011 | Scunci 52033 Canister Wet/Dry Vacuum
I need a manual for ridgid wet/dry vacs model #wd16500
I was unable to find the model WD16500 instruction manual anywhere online. In fact I did even find a link to that products owners manual, but when I clicked through the page no longer exists on Ridgid's site. I was able to find the parts diagram for the WD16500, and the instruction manual for the WD16600 which is also a 16 Gallon Detach Wet/Dry Vac, also with a detachable blower, and the model that even replaced the WD16500.
I also left you the number to Ridgid if you'd like to contact them, they may be able to mail you a paper copy of the instruction booklet.
I hope this helps you:
Instruction Manual:
Parts Diagram:
Phone Number for the Ridgid Company:
If this was helpful, please be so kind to rate my answer as helpful, this is what keeps me coming back to Fixya to help people with their vacuum related questions. Thanks alot, I really do appreciate it.
Chris J.
Apr 07, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Dewalt 2gallon corded/cordless vacume...unsed one time brand new wont turn on. motor and switch both tested and work...any ideas
Check the battery contacts... a common problem on this model. they are easily bent and prone to corrosion.
Mar 08, 2010 | Dewalt Cordless/Corded Wet/Dry Vac 2...
Dewalt DEWALT Cordless/Corded Wet/Dry Vac 2 Gallon Vacuum: It was purchased new, and used only one time,the second time the unit was turned on it never worked and have never worked since, the motor and...
This vacuum has a history of problems with the battery contacts. Check that yours are not bent out of shape or corroded. if they are... straighten them or remove the corrosion.
Feb 18, 2010 | Dewalt Cordless/Corded Wet/Dry Vac 2...
When the switch is flipped on (either corded or battery) the unit does not turn on
Check battery contactor on the vacuum and on the battery. It is a common problem on this vacuum. Check for bent pins and corrosion.
Aug 16, 2009 | Dewalt Cordless/Corded Wet/Dry Vac 2...
Over heating?
it sounds like you need to replace the motor in it . thank you for using fixya
Jun 19, 2009 | Shop Vac ShopVac 3 HP 2 Stage 10...
I have same problem. Please post it if you find source of battery charger HHD-20-200.
Apr 18, 2009 | Vacuums
Vacuums Logo
218 people viewed this question
Top Shop Vac Vacuums Experts
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
