Question about Whirlpool Refrigerators
Refridge modle ed2choxkq05 ice maker quit how to tell if water punp or ice maker note water pump doudle
  • 218 Answers
SOURCE: Ice Maker not Getting Water
There are two solenoid-operated water valves - one for the water dispenser and one for the icemaker. They're located near the water connection at the back of the fridge. There is no pump; the water pressure sends water to the icemaker whenever this valve is opened by the icemaker controls. Your symptoms sound like the coil is burned out on the valve. You can check it by disconnecting the wires and checking for coil continuity with an ohmeter. If the coil is open, replace the valve. Both valves might be combined into one assembly, so be sure you test both coils. Of course it's also possible that the trouble is in the icemaker itself, but a failed intake valve is more likely.
Posted on Jul 23, 2008
SOURCE: ice maker quit
check water supply toice maker also check water inlet valve
Posted on Mar 06, 2008
SOURCE: Ice maker
I am having the same problem with mine.
Posted on Jul 15, 2008
  • 12 Answers
SOURCE: Whirlpool side by side refrigerator, model # ED25PQ
Under the right side of the fridge in the back there is a dual valve for water and ice. Try changing it out, most likely the ice side is not working. Make sure you unplug the unit first
Posted on Dec 01, 2008
  • 190 Answers
SOURCE: The ice maker just quit working. No water is in
Dear customer,
       The general procedure to do when an icemaker doest work is as follows,
  1. Check the shutoff arm
  2. Check the supply valve
  3. Inspect the water supply line
  4. Test the shutoff switch
  5. Check the freezer temperature
  6. Inspect the ejector gear
  7. Test the ejector motor
  8. Test the ice mold heater
  9. Test the holding switch
  10. Test the water inlet switch
  11. Test the thermostat
  12. Test the water inlet valve
by clicking on the highlighted words u can get details of how to check them or try out the link http://www.acmehowto.com/howto/appliance/icemaker/ice-maker-repair.php
plz rate the solution.. thank you.. good luck..
Posted on Apr 08, 2009
Ice maker is not getting water,
Hello
Either the ice maker makeup water tube is frozen or the solinoid timer for water is broken.
Try running a hair dryer near where the water comes through the refridge wall to the ice maker,this will remove any ice blocking the water from coming in.
Sep 10, 2011 | Refrigerators
Hotpoint refridger ice maker not despencing ice or water
my ice maker stop making ice there is ice cubes in the tray but the ice maker does not dispence the ice
Apr 04, 2010 | Hotpoint HSS25GFP Side by Side...
GE refridge icemaker won't work
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards!
Jan 03, 2010 | GE Refrigerators
Ice maker is not making ice...no water to tray, but.ice maker motor works
there may be a sensor in the bin where the ice cubes drop into. It tells the ice maker when the bin is full so it stops making ice. Check to see if that sensor got bumped or moved or needs to be reset
Jul 07, 2009 | Roper RS22AQXKQ Side by Side Refrigerator
Intermittantly no water from inside water dispenser
I just started having the problem of no water dispensing from the in-door dispenser. I checked the operating manual and it suggested that the refridge temp may be set too low thus freezing up the water line. I have set the temp higher and we will see if that helps. I do not think that will do it because as you too note, the ice maker works fine. If the filter were an issue the ice maker would not refill either.
illinoisjas
Apr 19, 2009 | KitchenAid KBFA25ER Bottom Freezer French...
THE ICE MAKER WILL NOW ONLY MAKE A FEW CUBS
Our Kenmore ice maker GSI23 has stopped making ice cubes, the water still flows out the front, the sensor arm is down and we have pushed on the O button numerous times but still no ice. Help please
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Ice maker not working now refridge seals are hot, but still cooi
okay....i used to be an employee at Vinothque and these piece of **** units are always and I mean always running low on refrigerant, due to a slow leak in the system. You will have to get tech to come out and recharge the unit
Dec 29, 2008 | Refrigerators
Ice maker not making ice
The fill tube could be frozen. Gently use a hairdryer. If not you have to check the fill valve coil in the back to see if it's getting power. If it is replace the valve. if not check wiring connections etc. If there's no power out of the Im to the valve, replace the IM
Problems with water are most common tho. Please rate this
Jan 23, 2008 | Roper RS22AQXKQ Side by Side Refrigerator
Ice maker leaking a lot of water
could be your water valve is stuck open its located at back of refridg.
Dec 14, 2007 | Whirlpool ED5VHGXM Side by Side...
Refrigerators Logo
43 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
