Question about Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Red light on display not green as usual
2 days ago suddenly when try to turn on tv the red light just blinking and not becomes green as usual tried unplugging thr e tv for an hour and still same
  • 1 more comment
  • Ilenerogogg May 03, 2008
    same thing happened to me. haven't come up with solution yet
  • cucocuco May 30, 2008
    the message stated that someone has a solution you have to fix your site first because they have the same problem and not a solution????
  • Buddies May 31, 2008
    Having same problem here.... we just had a movie with my family, suddenly it turns off and it showed red blinking on power led....any solutions???
Same problem...AirmanB29 are you talking about the main power on the AVC or the LCD itself?
Posted on Nov 20, 2008
    Problem Solver:
  • 6 Answers
Sure seems like a bad design or a batch of defective parts. I have the same problem. Tried a work around that worked for a day and then it is back to the same problem! Got it to work, but when I turned it off, it would not turn on again. Seems like the controller box has some kind of flaky part in it. The LCD panel itself is OK. Too bad you can't use the TV without that external box.
Posted on Aug 14, 2008
  • AirmanB29 Aug 15, 2008
    OK. Here seems to be a solution that is working now. Unplug both the AVC and the panel (I used a power strip to make this easier by just turning off the strip and back on again). With the AC removed, press the "MAIN POWER" on. Next, press and hold the "VOL (--)" and "INPUT" at the same time. Finally, plug the AC power back in and the set should come on.
    After it came on, mine was in a factory test mode. I had to enable the write mode (I think it writes to the PROM) and then selected the second line down on the first menu (1 of 15 ) to have it do the restore or something.
    Finally, my set came up with OPC enabled to auto and it seems to have a sensor issue. At night, the monitor is unwatchable with such low light. So, I turned on a bright light near the monitor and set that to "Manual". so far, for two days and nights now it has been working again. I hope this helps. Good luck! -Brad
Same problem here... just happened yesterday... fortunately it is under a contract.
Posted on May 29, 2008
I also has this problem, found any solution ??
Posted on May 27, 2008
No power output or display.green standby light flashes.
Sounds like either a blown mainpower fuse or the thermal fuse for the power transformer. If the protect circuit was kicking in, the display would light up, but then turn off with a red blinking light. the green light with no display means the transformer is not getting power.
Dec 31, 2013 | Denon Avr-1610: 5.1 Ch A/V Home Theater...
TV will not turn on just green blinking light
If you paid a low price like $20 to $60 for the lamp it may not be an original replacement and may have failed.
But another thing it could be is to check the lamp cooling fan(s) where you might have to take some of the TV apart to do it.
If they have lots of caked on dust it would kill a lamp due
to inefficient cooling.
Nov 12, 2017 | Panasonic PT-40LC12 40" Rear Projection...
Mitsubishi Proj. TV,Model VS-50603, S/N 119340, won't turn ''ON'' when pushing TV ''ON'' button or remote. Green ''ON'' light comes on and then immediately off. Whats the problem?
62" mitsuabishi WD62525 had it over 5yrs now, we have been changed lamps three times,(geee lots money!!!)it worked ontill now...
two weeks ago blinking red lamp light was on , i thought lights out again so soon, i order new lamp, i cant turn on TV but blinking green timer light, TV is not working, try reset botton, turn off TV few days.
Please help
Lilly
Dec 06, 2009 | Televison & Video
Sony kdf50e 2000- green power light turns red what to do
Does red light blink? if yes, please count blinks as there would be pause of 3 seconds between blinks and let me know to help you out.
Feb 12, 2009 | Sony Grand WEGA KF42WE610 42" Rear...
No picture
ballast is not striking the lamp and needs replacing
Jan 10, 2009 | Sharp XR-10X Multimedia Projector
Display powers of with power up of AVC
how many blinks does the red light give in a row? This would be an error code?
The problem for 7 blinks would be an Interface board. Apparently there is a glitch in the interface board that sends signals to the television. Basically the glitch shorts out the board and the t.v wont turn on and you will see the power light blink 7 times pause then 7 more. You can replace the board with a new one and update the software on the new interface board.
If is isn't 7, let me know and I will help you out with this
thanks
Apr 26, 2008 | Sharp Aquos LC-37HV4U 37 in. LCD HDTV
Red light blinks
Check the lamp door (with green on) ,.. both green and red blink - bad lamp. Green off, red blinks..Try unpluging for 2 minutes and retry - if no different (sorry, call a service person).
Apr 21, 2008 | Toshiba 43H70 43" Rear Projection...
Tv cuts off and green light flashes
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Sep 23, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sharp Aquos LC-37HV4U 37 in.  LCD HDTV Logo
492 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
