Question about Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
MODEL # 59673504203 DRAWER IS ALWAYS FREEZING EVERYTHING IN IT. NOW NO ICE IS BEING PRODUCED
I had the same problem. I pulled the drawer all the way out. In the back is a vent flap. Ice had formed on it keeping it open. I chipped off the ice so the flap can move. This stopped the freezing veggies.
My ice maker stopped working. It was suggested I change the water filter as it may be clogged preventing water moving to the ice maker. As I am getting a new refrigerator I all not be buying a new filter.
This message is little late for the original poster but may help someone else.
Posted on Nov 14, 2011
Samsung RM255LABP/XAA freezer only gets to 27 degrees, won't harvest ice. Fridge and lower freezer work fine.
Ice cannot be produced at that temperature you're going to have to find out by taking the drawer out removal of the rear wall of the freezer and see if the evaporator is freezing over or is the condensate drain opening is blocked. Your model has dual evaporators and we need to see if your evaporator in the freezer is defrosting properly or if for some reason the defrost drain is blocked causing moisture to cover the fan causing a cooling problem.
Appliance 911 Sea Breeze
Aug 31, 2016 | Samsung Refrigerators
Items in deli drawer keep freezing
is the freezer freezing too? to much ice build up? if not check ur damper vent, make sure its not stuck closed or open to far, check the thermistors, the tempeture control thermostat, defrost timer and defrost terminator
Feb 19, 2015 | Kenmore Refrigerators
Fridge keeps FREEZING food in my fresh food pullout drawer!
temperature sensor is not working
this part to control the temperature in the fridge
Nov 28, 2017 | Whirlpool Gold GI0FSAXVY 19.8 cu. ft....
Fruit is freezing in the bottom drawer of the KitchenAid KSCS25FKSS Side by Side Refrigerator
There is a chance that your refrigerator needs defrosting. Remove everything and unplug your refrigerator, open the doors and let stand for 12 hours. Sometimes the air vents restrict with ice causing this trouble.
http://www.on-timeapplianceplano.com/refrigeratorrepair.html
Jul 23, 2012 | KitchenAid KSCS25FKSS Side by Side...
Ice maker overfills tray
Sounds like a probe fault. It should stop freezing when the set point is reached and defrost for a short while. Have you set it to fast freeze?
Apr 05, 2012 | Thermador Refrigerators
The refiridgerator is freezing everything, The coils have been cleaned as well as the filters and no matter the "cold" setting, anything put into the refridgerator is frozen.
It might actually be a bad thermostat, or a stuck damper. All the cold are is "produced" in the freezer section, and there are ducts with dampers that lead into the refrigerator section. If these dampers collect some ice on them it will cause them to stick in there current position. If this is the case, and the dampers are open, then it will always be to cold in the refrigerator. Hope this helps
May 11, 2010 | Frigidaire FRS23KF7AB Side by Side...
Maytag Model MZD2768GE
I've got the same problem with my 2nd drawer. Did you figure out the problem with your top drawer?
Oct 06, 2009 | Refrigerators
Leak to under ice cube tray causing drawer to freeze shut.
May be your freezer evaporator drain hole is frozen. If this is the case, you can try to install a low heat drain hole heater into the drain hole and connect the wires with the defrost heater.
Jul 04, 2009 | Traulsen Refrigeration 48'' Wide x 24''...
GE Monogram Ice Maker makes ice, unit doesn't cool enough
This model Icemaker makes ice by flowing water across a freeze plate. It is located in the top of the unit behind the white cover directly below the ON/OFF/CLEAN switches. After freezing a sheet of ice it releases and slides to the cutting grid. It then drops into the ice bin and begins to melt and the whole process starts over again. The level of ice in the bin is controlled by the high level sensor on the right side of the ice bin. It is a whit tube with two wires coming out of the top. Without this sensor it can overrun the bin capacity. Bottom line this unit does not freeze ice, it only holds it like cooler does.
Jun 03, 2009 | GE Monogram ZDI15C Automatic Icemaker
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator Logo
122 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
