Question about Sansui Televison & Video
Hi, Want to program my dvd remote to work with Sansui TV. What manufacturers code do we use? Our DVD player is a Sony RMT-D187A Thanks. Annie Follow these steps to program the remote control to operate a television. Turn on the TV. On the remote control, press and hold the TV I/O button. While holding the TV I/O button, enter the manufacturer's code using the arrow buttons. NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works. Release the TV I/O button. Point the remote control at the TV. Press the TV I/O button to verify operation.
  • 4 Answers
SOURCE: Who is the manufacturer of the ILO 26HD Television?
the manufactured should be on the back of the tv- i have an ilo 27 flat lcd hdtv the name on the back is
SUPERIOR ENTERPRISES
5900 CANOGA AVE
WOODLAND HILLS CA 91367
Posted on Mar 17, 2009
  • 3197 Answers
SOURCE: Can not program both keypad & remote to operate at the same time
One of your units has reverted from "rolling code" to "billion code" and as you have found they will each work but will not work with each other. The problem is finding out which unit reverted. The most common one is the hand remote but that could be wrong.
Posted on Aug 10, 2009
SOURCE: RAV311 WJ40930 US how to program the TV on the remote
It does not prompt you to enter your code, simply hold the 2 buttons for a few seconds, then enter the code you have. If successful, it will read remotesetup OK. Hope this helps and if you have any codes for techics cd players, let me know!
Posted on Dec 20, 2009
jhinsincity
  • 616 Answers
SOURCE: I have a symphonic tv that i am hooking a sony dvd
INTERNET
Posted on Jan 12, 2010
SOURCE: Comcast remote codes for Sony Bravia DVD Home Theater System
This Also Works for DAV-HDX598w
Posted on Feb 19, 2010
I have a sansui flat with build in DVD but don't have a remote the DVD will load but when push play it says operation not possible with disk what is this do I just need a univ.remote
First, check which input you have the TV set on. There may be an Input button on the side of the TV. (On the SLEDVD197, the button just below the DVD Eject button.) Just press Input and use the Channel Up/Down arrows to navigate the menu to change to the DVD. Press Input again to Enter the selected option.
With the TV in DVD mode, try pressing Play again. If you still have the error, check the region code for the disc. The "Operation not permitted" messages is usually that something on the disc is locked. Frequently, it's the result of using a different region code disc than the DVD player knows how to interpret. Try a different DVD.
If your TV doesn't have the Input button on the TV, you absolutely need a universal remote. However, you will want one that can match the TV/DVD button, the Input/Select button and the Menu button. Usually this requires a higher end remote; you also need a remote that was programmed at least 6 months after Sansui released the TV. If you do have the Input button on the TV, a universal remote may make using the TV easier.
I hope this helps.
Apr 13, 2015 | Sansui Televison & Video
Codes to program a dvd remote to an emerson tv
Access the Emerson Remote Support site online.Locate the television's manufacturer brand within the table list. Obtain the television manufacturer codes to begin programming the television with the remote control.Power on the television you are trying to program the Emerson TV remote control to operate with.
Press and hold the "TV" button at the top of the Emerson TV remote control keypad to prepare the remote for programming and association with the television.
Enter the television's manufacturer code when the Emerson remote's TV button begins to flash. The television will automatically power off to process the new settings.
Jan 06, 2012 | Sony Televison & Video
Hi Iam trying to program a universal remote control to my sansuni tv vcr dvd combo but haven't had any sucess. I have tried to do it with several different universal remote but none of the codes seem to...
How old are the remotes relative to the TV in question? If the remotes are older than the TV or were programmed within 6 months of this TV being released, then the code you need wasn't included in the remote's programming. In addition, unfortunately, many universal remotes do not work on combination TVs (with the DVD player and VCR built-in).
You can try to search through all the codes for the remote if your remotes have that feature. (On RCA remotes, turn on the TV, press and hold the Code Search button until the indicator light comes on, then press and release the TV button. Then press the On/Off button repeatedly until the TV turns off. Press Enter and see if the other functions of the remote work. If they do not, repeat the search. Then do the same but press the DVD and VCR buttons instead of the TV button.)
More likely you need a newer universal remote, a programmable (via computer USB) universal remote or a substitute remote from the manufacturer. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=12845952409830&smodel=TDC2075&brand_pn=SANSUI_TDC2075 for an exact substitute remote that will replace the original remote.
I hope this helps.
Sep 15, 2010 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
I need to program the one for all URC-3021B00 to my sony tv
Configuring codes:
1.Turn on a desired device (VCR or DVD player)
2. On the remote control, press a device key once (i.e., DVD/VCR,
CBL/SAT or TV).
NOTE: To program control of a VCR, PVR (or DVR),TV/VCR Combo, or TV/VCR/DVD Player Combo press DVD/VCR once. After programming a VCR Combo device, you will be able to control channel selection,volume, and VCR functions.
To program control of a DVD Player,DVD Player/VCR
Combo, or TV/DVD Player Combo, press DVD/VCR once. After programming a DVD Combo device, you will be able to control channel selection, volume, and DVD functions.
To program control of a Cable Box, Cable Box/PVR (or DVR)
Combo, Satellite Receiver, or a Satellite Receiver/PVR (or DVR)
Combo, press CBL/SAT once.
3. Press and hold SET until the LED (red light) blinks twice,
then release SET.
4. Use the Manufacturer’s Codes to locate the type of device and brand name and then enter the first four-digit code for your device. If performed correctly,
the LED will blink twice.
5. Aim the remote control at the device and press POWER once. The device should turn off. If it does not, repeat steps 2 to 5, trying each code for your brand until you find one that works. If it still doesn’t work, try Searching For Your Code on next page
Auto Code Scan:
1.On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the TV and slowly press POWER button.Stop when the TV turns off
5. To lock in the code, press and release SET.The LED will
blink twice.
6. To search for the codes of your other devices, repeat steps
1 to 5, but substitute the appropriate device key for the device you are searching for.
Code for sony tv are 0000, 1100, 0810
Thank You
Sep 13, 2010 | One For All URC-3021 Remote Control
I have a 36" insignia tv and just bought a sony dvd player and in the user manual for the dvd player there is no code for the remote for an insignia tv which i find wierd seeing as insignia is made by sony...
A variety of remote control codes can be found at InsigniaProducts.com; just search for your TV model number and click Support. Also, try codes for the following brands: Orion, Emerson, Memorex, Sansui, Sylvania, Zenith.
Jun 07, 2010 | Sony DVP-NS55P DVD Player
Does any one have the code for westinghouse tv -dvd player for the r remote JR300 and for a vcr- dvd player combo{sansui progressive scan}
If you don't have a Westinghouse remote the only codes that will work for a universal is the Sony codes, if all else fails you can buy an original remote for about $15 plus shipping and handling at parts@wde.com, just make sure you write the correct model of the TV and your contact information.
Jan 17, 2010 | Jensen JR300 Remote Control
LG DVD remote control
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! If that didn’t work, you will probably have to contact the manufacturer to get the code..
Thank you for using FIXYA!
Cheers!
IrishDruid
May 28, 2008 | LG DR-4810 DVD Recorder
Programming remote for Zenith DVB412 DVD Player
Here is the response from LG/Zenith customer support:
Unfortunately, this remote has very limited programmability. The manual is correct.
INSTRUCTIONS: Controlling other TVs with the remote You can control the sound level, input source, and power switch of non-LG TVs as well. If your TV is listed in the table below, set the appropriate manufacturer code.
  1. While holding down TV POWER button, press the number buttons to select the manufacturer code for your TV (see the table).
  2. Release TV POWER button. Code numbers of controllable TVs If more than one code number is listed, try entering them one at a time until you find the one that works with your TV.
Manufacturer Code Number
LG/GoldStar 1 (Default), 2
Zenith 1, 3, 4
Samsung 6, 7
Sony 8, 9
Hitachi 4
For further information or troubleshooting, you may contact us at 800-243-0000 for LG Customer Service assistance. An agent will be glad to assist you. Please feel free to contact us with any additional questions or concerns. Thank you again for contacting LG Electronics.
Jun 30, 2006 | Zenith DVB412 DVD Player
Televison & Video Logo
48 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
