Question about Pelonis Heating & Cooling
We have a model MPC-08er. When we turn on the AC, the green light flashes and then turns off. The AC does not turn on.
  • 35 Answers
SOURCE: phillips plasma wont turn on power light goes
need to replace caps on PSB. email for instruction and pics of what to look for. gysgt2u1@yahoo.com
Posted on Mar 21, 2009
tepfy
  • 319 Answers
SOURCE: flashing green ac light six flashes when i hit the
you need to check your freon level. after that then tell me if your clutch is working.
tepfy
Posted on May 03, 2009
  • 1043 Answers
SOURCE: dell d610 wont turn on ac adapter light is green
There is a small IC that Dell solders into their power supply as well as their batteries. When this parts fails you will have the type of problem you are having now. If you do a search on the web you will find a large number o sites that discuss this. Unfortunately there is no fix other than replacing your power supply. I had to do the same thing myself for the Dell laptop I use.
Posted on Nov 02, 2009
ladywinn
  • 5138 Answers
SOURCE: tv - AC failure
Please Post your Make and Model number to TV will be printed on back of set!
Posted on Feb 13, 2010
nonontech
  • 4737 Answers
SOURCE: hello my computer is a
Before we begin troubleshooting, I need some clarifications, What is the operating Systems installed on the Computer? Is it still under warranty? Do you have the Recovery CD?
If it's still under warranty, we shouldn't touch the hardware as it will void the warranty, (this model has 3 years warranty) but if it's not, then we'll do whatever....to fix it.
You may also need a windows CD, it must the hardware issue, but it could also be software issues, so since we haven't tested anything yet, I can't tell you the cause. There are many possibilities and of course, may ways to fix, may take time depending on how much it's been damaged..
Thanks and awaiting.
Posted on Oct 31, 2010
65 inch mitsubishi model# 65736 green light blinking
If the TV does not stay on, press the POWER button on the control panel for at least eight seconds to perform System Reset. The TV will turn off. Power on the TV and the green LED will flash quickly for about one minute. The changes you made most recently, before using SYSTEM RESET, may be lost. If this happens frequently, obtain an AC line power conditioner/surge protector.
An unusual digital signal may have been received, triggering a protection circuit. Wait for the light to stop flashing and turn TV on.
Momentary power fluctuation caused the TV to turn off to prevent damage. Wait for the green light to stop flashing and turn the TV on again
Sep 29, 2016 | Mitsubishi Televison & Video
Sony Grand WEGA KDF-60XBR950 60 green orange green red flashing light
3 blinks is a lamp cover error, did you make sure that the lamp cover is screwed in tight? Also check the lamp cover for deformity, there is a problem with your model where the set over heats and melts the lamp cover a little causing it not to make connection with the lamp cover switch. Let me know if you find either of these problems? If not we can troubleshoot a little further.
Tim Nolan
Sep 14, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
MPC wont turn on!
Remove the battery and press down the power button for 10seconds and leave for another 10mins, then install the battery and see.
Jan 29, 2014 | MPC Computers TransPort GX Notebook
Mitsubishi TV won't turn on green light flashing
Bad capacitor syndrome. Search 'bad caps' and model and you will find on goog.
Apr 17, 2010 | Mitsubishi WD-62525 62" Rear Projection...
My ibm thinkpad a21m will not turn on and a green light just flashes on it
The green light flashing is actually a diagnostic code, IBM should have what the flashes mean on their web site.
I once worked on the the exact same model and the green light was flashing. The owner bought a new Motherboard off of ebay and I installed it and the computer then worked fine.
I am not saying that it is the motherboard, it could be an issue with battery or the AC adapter as well.
Try removing the battery and powering on the computer while it is plugged in. If possible try a different AC adapter.
The Lenovo web site is where you can find support for your system but I was not able to find any documentation regarding diagnostic codes.
Apr 14, 2010 | IBM ThinkPad T21 Notebook
We have a Mitsubishi Model 57733 and this morning when we turned the TV on, the picture is black. We have sound, but no picture. The lamp light indicator is solid green (no flashing, either green or...
Unplug the set from the AC outlet and wait at least 5minutes before reconnecting the Ac power. Turn on set and wait for light to stop flashing before trying to turn on again when it stops it is ok to turn on, if this does not solve the problem then purchase a new lamp. or the lamp ballast is faulty.
Dec 21, 2009 | Televison & Video
Need exhaust hose for Pelonis MCP-08ER
you can make some thing work dryer vent and duct tape cheap fix good luck Tom
Jun 27, 2009 | Pelonis KCD-25YI Air Conditioner
Battery indicator?
Hi there.
Sounds like the battery could be faulty.
The diagnostic procedures from the Dell User Guide are as follows:
Total Power Failure When Using a Battery
If an AC adapter is not connected to your computer, the computer's power source
is a battery. If the battery indicator flashes amber or is a steady amber, the
battery needs to be charged. If the battery is flashing green and amber, the
battery may be defective. To troubleshoot this problem, use the following
procedure.
1. Turn off the computer and peripherals, and disconnect them from AC power.
2. Reseat each installed battery by removing it and then replacing it.
3. Turn on the computer. Does the green power indicator light up?
Allow one minute for the computer to initialize its components before checking
for signs of power.
Yes. Continue to step 4.
No. Use the AC adapter to connect your computer to AC power. If the computer
operates normally when using AC power, go to step 7. If the computer does not
boot when using the AC adapter, see the previous subsection, "Total Power
Failure When Using the AC Adapter."
4. Does the battery indicator flash amber or show a a steady amber light?
Yes. The battery needs to be charged. Go step 5.
No. Go to step 7.
5. Connect the computer to AC power, and fully charge the battery.
For instructions, see the topic titled "Charging the Battery" in the online
System User's Guide.
6. As the battery charges, does the green battery indicator light up?
Yes. Go to step 9.
No. Go to step 7.
7. Is the battery indicator flashing green and amber?
Yes. Your computer may be in a hot environment. Charging the battery in this
condition may affect the life span of the battery. Continue to step 8.
No. The problem is resolved.
8. Disconnect the computer from AC power. Is the the battery indicator still
flashing amber?
Yes. You may have a defective battery. Continue to step 9.
9. Remove the battery, and press its test button. Is the uppermost indicator in
the charge gauge of the battery flashing?
Yes. You have a defective battery. Continue to step 9.
10. If a spare battery is available, fully charge it, and then install it in the
computer.
11. Turn on the computer. Is the power indicator off?
Yes. Your original battery is defective.
Good luck
Jun 01, 2009 | Dell Latitude D600 Notebook
Flashing green ac light six flashes when i hit the ac button and ac does not turn on just the blower''
tepfy
Apr 28, 2009 | 1998 Oldsmobile Intrigue
When I plug in my ac adapter into my computer to charge it the green light turns off and won't charge my computer
procedure.
for signs of power.
No. Go to step 7.
Yes. Go to step 9.
No. Go to step 7.
flashing amber?
computer.
good luck
Apr 05, 2009 | Dell Inspiron 6000 Notebook
Heating & Cooling Logo
133 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
