Question about Amana Heating & Cooling
I have a locked rotor on my ac unit. how do y 'unlock' it
When you turn on the rear ac it sounds like it humms and then trips the breaker. Any ideas? Thanks, John
it could be the capacitor gone bad. without it the compressor can draw lock rotor amps.
Aug 02, 2014 | Coleman Dometic Duotherm Rv Air...
How do i unlock my blue star AC remote
Just change the batteries! The AC remote gets unlocked for me. When I contact the service centre they asked me to pay Rs. 500 for visit and unlock the remote.
Mar 23, 2013 | Cell Phones
How to unlock gree ac remote
To lock and unlock Gree remote control press '+' & '-' simultaniously.
Jun 26, 2012 | Heating & Cooling
What is L.R.A. for a samsung SK1A1C-L2W ?
A rule of thumb for lock rotor amps is 5 times the running load amps. That unit probably draws 3-4 amps max when running so lock rotor probably 15- 20. If its drawing lock rotor amps try a hard start, if that wont do it unit is bad
Jun 22, 2011 | Refrigerators
What is the difrent between LRA and BTU ?
One really has not much to do with the other directly
BTU - British Thermal Unit.- A heat measuring unit. IE:12,000 BTU (British Thermal Unit.) The amount of heat required to melt one ton of ice.
LRA - Lock Rotor Ampere-LRA is nothing but locked rotor current , generally it is located on compressors name plate, when ever pistons locked at a particular position the rotor does not move further at the time rotor draws large current, that current is located on name plate, by seeing that LRA we can know compressor rotor was locked
May 20, 2011 | Air Tools & Compressors
My church has a roof top ac unit, model # GP-1360H41BA. The ratings plate has the following ratings: RLA 26.4 AND LRA 134. What is the KW draw of this unit 1. At startup 2. After startup?
RLA ( rate load amps/current) is the rate of unit ( usually about 65% against Max. load current < FLA/FLC>)
LRA ( Locked rotor amp/current)
Seems your AC use Y or Delta starter, so at start the current draws will between : 3X ( 26.4 to (26.4(1 +35%). And After start up the current draws will drop to 26.4 to 26.4(1+ 35%) in normal operation.
Remember, that the current draws also depending to the condition of your ac.
Nov 03, 2010 | Goodman Heating & Cooling
My lux TX1500a home ac thermostat unit is ''locked'' help !!
you press Next, Next, Next, Hold. This locks and/or unlocks the thermostat. I had the same problem but found the manual online.
May 18, 2010 | Heating & Cooling
Ac compressor makes a repetitive starting sound but wont kick in all the way. Fan is working fine.
Verify proper line voltage to the unit and compressor prior to any further testing, and correct if found below normal.
I would check the amp draw thru the compressor circuit. the compressor may very well be "locked rotor" and be pulling a high amp draw. that magic number for locked rotor amps should be listed on the compressor nomenclature plate as "lra".
the compressor may not be pulling any amps if the windings are burnt though, as their will not be any flow of power through the device.
best of luck,
ttfn
Oct 24, 2009 | Ruud Central System Air Conditioner
Locked rotor!
Turn the belt by hand and see if that frees the motor. GE is known for bad motors on the units made in the last two years.
Sep 05, 2009 | GE Profile WPRE6100G Top Load Washer
Radio is locked-need to unlock, plus unlock code
1 have h3 hummer and replaced the radio (ac delco) and is locked,i need to unlock it
Apr 30, 2009 | Hummer H2 Cars & Trucks
Heating & Cooling Logo
160 people viewed this question
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
