Question about Motorola Mobility ic502 Cellular Phone
Motorola ic502 Cellular Phone Problem My phone is stuck with the in progress screen and I have no way to get to menu.
How to turn on a motorola ic502 moble phone
It must have 15% charge before it will power up.
Mark
Motorola Support
Apr 30, 2014 | Motorola Mobility ic502 Cellular Phone
I have a motorola ic502 but it will not execpt my sim card
Without more info the phone is probably locked to only matching home base sim cards.(simlock)
Jan 29, 2010 | Motorola Mobility ic502 Cellular Phone
I dropped my ic502 now the screen is dark can i swap the flip portion from another ic502 with mine
Yes you can, but its not an easy repair.
There is a delicate data ribbon that joins upper and lower sections of handset and is partially contained in the hinge assembly.
Jan 06, 2010 | Motorola Mobility ic502 Cellular Phone
How can i put my boostmobile sim card into motorola ic502
you must UNLCOK the phone. Also the other phone must also be a sim style phone. Any phone can be unlocked and used with your simcard. To unlock the phone is different for each phone. So, you need to unlock the motorola ic502 so it can read your sim. The cell company can give you that code if you have owned the motorola for more then 90 days but you can also unlock it with out the need to call the cell company. I would need a little more info or from what I have said above you can start to google around for it.
Dec 28, 2009 | Motorola Mobility ic502 Cellular Phone
Phone keeps trying to boot over and over motorola ic502
You have a damaged ROM so you can not access the phone. My phone has damaged ROM and i have to wait 10 minutes for mine to load. If yours is completely wrecked then you need a new phone, There is no point trying to repair.
Oct 09, 2009 | Motorola Mobility ic502 Cellular Phone
Can i shut off the back light and or dim the
To change the backlight setting:
1.Press Menu/Ok >Settings >Display >Light Control > Backlight Control.
2.Select how long the backlight should stay on.(If you
choose Flip Open ,the backlight stays on as long as the
phone is open.)
3.Press Menu/Ok .
Thank you for using Fixya
Oct 08, 2009 | Motorola Mobility ic502 Cellular Phone
Ic502 sim card swap problems
The phone is attached to another account and the previous owner will have to contact Sprint to have the device removed from the line.
Aug 27, 2009 | Nextel BOOST i835g i835 LTD. ED UNLOCKED...
I have a new motorola ic502 phone and no wners manual. How do I retrieve voicemail from another phone when I am traveling and out of range of cell service?
call your phone # when you here your greeting cant remember if you hit the #or the * but one of those will have your voice mail pass word then you con get your voice mail
Jun 03, 2009 | Motorola Mobility ic502 Cellular Phone
Motorola Mobility ic502 Cellular Phone Logo
101 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
