Question about Exercise & Fitness
The belt on my 68600F EverYoung has quit turning. The display screen is still on and says E2.What does that mean? gaylesues@hotmail.com
  • 9 Answers
E2 normally refers to error in the speed sensor - iff the treadmill starts moving and then stops it is speed sensor related, otherwise if it never starts at all you will need to test your drive motor with an external 18v battery (cordless drill battery) to see if the motor will still turn. if it still turns then that narrows the problem to the motor controller which also means that the motor relays are not working and the controller would need replaced
Posted on Aug 05, 2010
Looking for owners manual for everyoung 86800F model
go for free download: www.fitness.manualsonline.com or www.manualsfactory.com or www.retrevo.com
sincerely. God bless you
May 07, 2012 | Exercise & Fitness
EverYoung 75900 needs to be reprogramed Display unit show F1 can you pls provide the code thanks Joanne Pekar
I have a problemwhen i start the ever young model 75900F
on screen F1
please send me solution
Nov 05, 2010 | Exercise & Fitness
Code e2 appears on display screen
E21or E2 1 means the treadmill is not picking up a speed signal once the start key is pressed. First, determine if the motor is turning before you get the E2 1 or not. If the motor turns, the speed sensor is the most likely problem. If it does not, you can manually turn the belt with your feet before you get the E2 1 and you should get a speed reading but eventually you will get an error code because it is almost impossible to keep the speed constant enough for the computer. Try running it through calibration with the motor cover removed. their is Tech sheet under the hood and it will explain how to do the calibration
May 22, 2010 | Proform 730 Folding Treadmill Model...
Have the same problem with my Everyoung Treadmill EY88800K. Display was zapped with static and treadmill became inoperable. Great condition and hate to toss out. Any hope?
End up dismantling the unit and disposing everything except for the motor and belt and rollers. Was a good machine except for no parts support.
Dec 28, 2009 | Exercise & Fitness
I am getting an E2 error on the display. The
either any of the key(button)is got stuck up prtessed or the motor of the washer is got weak.due to this e2 error code shows up.the washer works if the motor is weak but if there are more clothes in the washer and due to that motor cannot spin properly so it shows e2.First clean the washer internally after emptying it completely then check.if still e2 error then motor needs replacement . you can get new motor at www.repairclinic.com
Aug 30, 2009 | Amana Washing Machines
Range displays e2 f1 and beeps every so often
F1 E2
1. Verify failure if not displayed, using CANCEL/OFF key. Press key for 5 seconds until last
error code is displayed.
2. Disconnect power longer than 30 seconds.
3. Re-apply power and observe for longer than 1 minute.
4. If failure remains, disconnect power, replace control.
Oct 26, 2008 | Whirlpool GS460 Gas Kitchen Range
Exercise & Fitness Logo
394 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
