Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
Hi IMy seagate barracuda 500gb internal hhd has sector 0 bad.No way with many program to resolve it.I can' format,always say me that there is a bad sector.I used seagate tools,hhd disk repair and othen but...no way...need i change hhd?? thank you
  • 734 Answers
Since the HDD has rejected easy repair by the most appropriate tools, I recommend you recover the data and replace the drive. I've been through this many times for clients.
You did all the right things.
Best Wishes
Posted on Aug 04, 2010
Bios cannot read hard drive
Hi Robert,
IT could be that the Barracuda drive is formatted for boot up. I would boot up with the drive that boots, and make the Barracuda a spare drive, so you can go in and first see if has any issues as a drive,(meaning sector 0 errors, and if you can access it, then you can format it as a boot up drive, or get what data on that drive off for your friend.
Good Luck Mark
Sep 01, 2014 | Seagate 1TB Barracuda Internal Hard Drive...
When computer boots up I get this error code A disk read error occured code 0F00:0666
A bad hard drive or the boot sector (the map of the hard drive contents) has an error.
You have two choices. If you run regular backups you can do a full restore including the boot sector, if not, you'd have to format the hard drive and lose your data. Then reinstall Windows and start from scratch.
The other option that loses your data, as well, is replacing the hard drive if it's defective.
Mar 09, 2014 | Seagate 500GB Barracuda 7200.12 SATA...
Whenever i try formating my hardrive it states "some errors occured while formating"
Step 1:
check your Ram
if your RAM is not ok replace it .
Step 2:
this is last solution replace the hard disk may be there is some bad sector or that part of hard disk is damage.
Jan 10, 2013 | Seagate Barracuda 7200.12 250GB Hard Drive...
I have Seagate HD 500GB (Internal) and my PC configuration is Intel i3 Processor with 2GB RAM, 1GB Nvidia Graphic Card and 250GB HD(Internal) in which OS is loaded. I'm facing a problems as...
Your problem is very clear... The HDD has got bad sectors in it and that is the cause for the Sneak sneak sound...
This causes your HDD to not get detected under bios in most of the situation and this is the root cause for all the problems stated above...
Here is the solution:
It is not possible to do any kind of service from your end...
It has to be sent to a seagate service center to get serviced...
Mostly they will never service the HDD, they will replace it with a new one...
All the seagate HDD comes with 5 years warranty...
you can opt for replacement...
search in google for an authorised service center located in your locality...
Dec 18, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate barracuda 500Gb USB External drive
I have also experienced similar problem and found out that the problem is with the harddisk. It may have bad sectors which cannot be rectified. If your harddisk is older than 3 years then probablity for this this kind of problem is high. Better claim the warranty for your harddisk if its life is within 3 years as segate HDDs were given 3 years warranty.
I hope this is helpful to you
Dec 31, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Lags and says has bad sector after 14 months
Good day sir/maam, hi, 14 months is too short for a hard disk operating span, what we do is run the diskmanager software that comes with the seagate hard disk, on the diskmanager menu, run the low level format which usually removes the bad sectored space out of the way, and mark it as not usable. then may I suggest you partition your hard drive to 2, one for windows and the the other for data. call your computer dealer if they have in house techs for service, or get the copy of disk manager for your seagate. Hope this helps, thanks
Nov 04, 2009 | Seagate 750GB BARRACUDA SATA 7200 RPM 32MB...
I cannot install windows xp sp2 on my seagate barracuda 72000.10 500gb hard drive
I would suggest you go to the seagate website and download and burn out their hard drive test. run the test from boot and see if it detects a bad hard drive after it runs
Jul 11, 2009 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Im trying to copy from mac to pc using seagate removable hard drive and its not working? When i plug the Seagate into my PC nothing happens
The hard drive volume format is only for MAC. Check the volume format if it is MAC OS Extended or MAC OS Extended (Journaled). If it is, then change it to MS DOS to make it readable and writable to a PC and MAC OS
Jul 08, 2009 | Seagate 500GB Barracuda ES.2 SATA 3Gb/s...
Seagate sata hdd error
Quick format removes files from the partition, but does not scan the disk for bad sectors, while a normal format does that. That's why the formatting takes so much longer.
You should definitely check your drive for bad sectors by issuing "chkdsk /r" in the command line, which scans for and attempts the recovery of bad sectors.
If there is a bad sector somewhere, your system might crash at any time and it might be at a very inconvenient moment.
If you find bad sectors, you should consider replacing the drive
Mar 02, 2009 | Seagate Barracuda 7200.10 ST3160815A -...
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
275 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
