Question about Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television
Upon startup it has very wavy picture for about 20-30 mins. it then stays wavy across top of screen making it difficult to read box scores on games. now a flicker is happening on right portion of screen.
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
You are the second person with this problem on this site today.
The model indicated is one of many Toshiba sets with the same kind of problem: this set uses what is called a Hyper module---lines left to right and noise and it clears up after warmup with the time slowly getting longer and longer until it does not clear up.
The Hyper board processes all signal from tuners and all inputs in the set and is NO LONGER AVAILABLE FROM TOSHIBA. It can be removed and sent out for "rebuild", last one I did the net cost for this was about 200 dollars.
What goes bad is the Hyper board has about 2 dozen "surface mounted" filter caps that dry out after 3-6 years. I have had two people on this site I helped who were very skilled at soldering etc and were able to remove, repair and put the board back in the set.
For the most part this is NOT A EASY FIX FOR A DO IT YOURSELF PERSON; at the shop I work for we will only repair if the customer is willing to pay to have the board "sent out and rebuilt".
I have seen two other techs in our shop try to fix them in house and fail.
This problem with these tiny filter caps is not new; as far back as 1991 Hitachi and others had the same kind of troubles with signal and other boards that used surface mounted caps.
I own a 60 inch Hitachi made in 1991----great set but over 20 bad caps of this type on PIP board----when the caps really go they leak on the board and destroy it. My set also had the same problem in the digital convergence board which stores the set's memory of convergence.
I (after getting that board out) spent over 6 hours replacing nearly 25 caps on that board------I have over 30 years experience soldering and fixing TV sets and I was able to save the set which for its age has a very good picture and performs well.
If the Hyper board in your set (97% chance) is bad you have a tough decision----even if rebuilt it will happen again in 3 to 6 years or less depending on the quality of the caps used to replace those that are bad now.
Let me know if you have questions or need advise-I am here to help.
SD TECH
Posted on Aug 04, 2010
A couple of days ago I turned on my brand new (about 6 weeks old) Samsung 50'' plasma pn50b650 I noticed an imperfect picture at the top of the screen. Upon closer inspection, there were about 4-5...
U freeze video games 10-20 mins in video game alot of time.Never pause or freeze any kinds of video image in Plasma tv.It very easy cause to burn in Plasma tv problems alots.
Feb 25, 2010 | Samsung PN50B650 50 in. HDTV Plasma TV
Split screen, kind of inverted w/white wavy lines
It is a calibration problem, let me see if I can find some schematics for your tv.
Jul 19, 2008 | Panasonic CT-32SL14 32" TV
Wavy lines appear across the screen
Projection TV sets have two very common problems listed below.
Problem #1) Convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 01, 2009 | Panasonic PT-51HX42 51" Rear Projection...
32'' Toshiba Regza: Can't get the picture size to show all data.
An adjustment in the cable box fixed the problem.
Mar 23, 2009 | Televison & Video
TV picture
This set will need to be serviced by a tech shop as you have a problem called "vertical foldover"...accordianman
Apr 09, 2008 | Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Picture Size
Also, try adjusting the settings on your cable box, not on the TV. The usually solves the problem and will then allow you to adjust the size of the picture.
Mar 03, 2008 | Samsung LN-S4092D 40 in. LCD HDTV
Words at bottom of screen
Normallly, if the picture size button on the remote for the television does not achieve the desired affect, then, a cable box or a satelite box is where the change needs to be made.
For example:
A Motorola Cable box needs to be set up to go to a wide screen or zoom when an analog signal is detected.
Some Dish Network boxes have Size buttons on their remotes and also in their main menu.
It's difficult to determine the repair without knowing the types of the peripherals.
Hope this helps.
Nov 11, 2007 | Apex Digital AT2408 24" TV
Adjusting screen on HD TV
I had the same problem. My cable company told me to press the # button on my remote to change it from "zoom" to "normal" and it solved the problem.
Oct 21, 2007 | Televison & Video
Wavy picture on all video inputs except component video toshiba 57h82
make sure you replace all the 10uf caps and that the connections are good....
Sep 20, 2007 | Toshiba 57H82 57" Rear Projection...
Toshiba 65HDX82 65" Rear Projection HDTV-Ready Television Logo
465 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
