Question about Sunbeam Vacuums
I have a Sunbeam SGB8901 microwave and no instruction manual. How do I cook at 50%?
I need the manual for the sunbeam oskar food processor 14081
"This is the direct link to the manual (in .pdf format) for the Sunbeam Oskar Food Processor Model 14081, although the model number given on the cover of this manual is #4817. I own and use this food processor (model 14081 as printed on the bottom of my machine) on a regular basis and was also looking for the manual for it. After some very brief internet searching, I found the manual for my machine online and the link I provided will lead you directly to the manual for it as well."
This is the link to the manual
Thanks for using FixYa
http://web.archive.org/web/20070102192749/www.sunbeam.com/manuals/1999/4817.pdf
Jul 11, 2011 | Vacuums
Tip
Microwave cooking time tip
Do not be in a rush to eat the food when your buzzer sounds. Remember, that the way the microwave functions is to let the food sit for a few minutes when it is done cooking. The food continues cooking and distributes the heat evenly throughout your food. Test for doneness after the standing time.
on Aug 17, 2010 | Vacuums
How to clean sunbeam ultra 60 platinum iron. Can't find instruction booklet!!!!!
Do you mean the Sunbeam Ultura 60 Platinum iron? Wipe the exterior of the iron with a damp soft cloth and then dry the iron. To clean the steam valve, turn the Steam/Dry dial to Clean so that the tip pops up. Gently scrub the tip of the valve with a steel wool pad moistened with warm water. Rinse and dry with a soft cloth. Replace the valve and turn clockwise to lock into place (reset the dial to Dry when storing the iron). Clean the steam holes of any build up, use a cotton wool tip moistened with methylated spirits. The teflon plate should be cleaned with the damp soft cloth, just like the rest of the exterior of the iron. If you have ironed a polyester that melted onto the iron, then iron a damp cotton cloth when the iron is hot.
The manual for several Ultura irons, including the 60, is available here: http://www.sunbeam.com.au/Pages/Browse/ProductDetail.aspx?pid=1485 . The link for the manual is in the center of the page above the Image Gallery.
I hope this helps.
Mar 06, 2011 | Sunbeam Vacuums
I have a Delta microwave and grill Y-3 model We have lost the instructions on how to use it and cannot seem to find how I can download the instructions . PLease can you help.
Here is the manual for a Delta microwave and grill Y-3 You can go to this link to download it. Go to the site and you can read it there or Download the manual by clicking on it and doing a save as. Put it on your desktop so you can find it easier. Thank you.
Delta Microwave Y-3 Manual
Dec 22, 2010 | Vacuums
I need a replacement cap for the water tank Sunbeam humidifier model swm5251
Official instruction from this device suggests to call Sunbeam consumer service at 1-888-264-9669 to order replacement accessories.
Nov 28, 2010 | Sunbeam Vacuums
I purchased a Sears Counter Craft Crock Watcher crock pot at an Estate Sale, but there is no instruction booklet. It has low, high, and auto shift on the dial. Can you help provide some instructions for...
From a couple of different slow cooker manuals - most I looked at are the same:
When in the AUTO setting, the slow cooker will begin cooking on HIGH and then will shift to LOW after approximately 2 hours of cooking time. AUTO setting does not turn off the unit. Other favorite recipes may be adapted to the slow cooker. All times listed in the following chart are approximate and should serve only as cooking guidelines.
Regular Cooking Slow Cooker Cooking Times
1 (Low) 2 (High) AUTO
30 minutes 6-8 hrs. 3-4 hrs. 5-7 hrs.
35-60 minutes 8-10 hrs. 5-6 hrs. 6-8 hrs.
1-3 hours 10-12 hrs. 7-8 hrs. 8-10 hrs.
Sep 16, 2010 | Vacuums
Have lost manual for my sunbeam dehydrator model AR72716 07-03 cannot locate one any where
Sunbeam only have 2 listed:
  • DT100E Healthy Food Dehydrator link to manual: http://www.sunbeam.com.au/PDFDownloadHandler.ashx?id=11092
  • DT5600 Food dehydrator link to manual : http://www.sunbeam.com.au/PDFDownloadHandler.ashx?id=11096
Does your dryer go by another name such as Excalibur?
Sep 06, 2010 | Sunbeam Vacuums
I have an Amana above range Radarange, Model #AMV4204AAB, Serial # 10168958GE. Tonight after running for a 7 minute period and finishing, it would not again start. There is power to it, but various...
  1. Push the power cord all the way into the outlet in case it became loose and is causing the problem. If the microwave still isn't working, check for a blown circuit fuse, and repair it.
  2. Step 2 Check that the controls on the microwave are programmed correctly according to the owner's manual. If they aren't, program them.
  3. Step 3 Close the microwave door firmly. Touch the cook function on the Start Pad, not the timer. Check if the microwave works. If not, continue to step 4.
  4. Step 4 Program the Power Level correctly. If it's not programmed properly, the microwave will cook the food too quickly or too slowly.
  5. Step 5 Use only microwave safe dishes. Make sure food is evenly shaped and defrosted before placing it in the Amana Radarange microwave.
Thanks.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Jul 09, 2010 | Vacuums
Vacuums Logo
352 people viewed this question
Top Sunbeam Vacuums Experts
Marvin
Marvin
Are you a Sunbeam Vacuum Expert? Answer questions, earn points and help others
