Question about Garden
Mcculloch super airstream IV=> i need to know how to turn it on. what kind of oil/gas do i need? how do i mix them ?
finance535
SOURCE: pro mac 850 super cc rateing and fuel mix
ProMac 850 is 82cc capacity motor & Fuel mix is 25:1 - especially now that we only have unleaded... best to use BP Ultra 98 octane as these saws were designed to run on Super leaded fuel. I used to own a 797 Super (123cc motor)
Terry B
Posted on Jul 30, 2009
  • 1126 Answers
SOURCE: i guess he needs to know what kind of oil he needs also
Oil is mixed with gas for 2 cycle engines only, not 4 cycle engines.
http://odref.com/pdf/Ryobi/
Try this site for owners manual. Hope this helps.
Posted on Aug 23, 2009
VtToolMan
  • 704 Answers
SOURCE: mcculloch 310 oil mix ratio
The proper gas/oil ratio is 50:1, that is 50 parts gas, to one part (2) cycle oil.
If you plan on leaving gas in the tank when not being used, I always recommend adding some gas stabilizer, such as Sta-bil, which makes starting the chain saw easier regardless of how long the fuel mix has been sitting in the tank or saw (up to 2 years according to Sta-bil label)
Hope you find this Very Helpful and best regards!
Posted on Sep 09, 2009
  • 124 Answers
SOURCE: How to adjust the carb on a McCulloch super
There is no set adjustment on any blower or chain saw. If it were that simple there would be no need for adjustments. The problem is that most equipment manufactured in the past 10 years can not be adjusted by the user. Carburetors are now equipped with either adjustment limiters which limit the adjustment to less than half a turn or with adjustment screws that require a special tool to make the
adjustment. More than likely you will have to take it to an authorized dealer for those adjustments.
If you do have an adjustable carburetor, then gently close both needles and open each on 1 full turn. This should allow the engine to start and the final adjustments can be made at that point. If it still will not start then open each needle 1/8 to 1/4 turn and try again. If this still does not work then most likely your carburetor needs a good cleaning and a rebuild kit.
Posted on Sep 20, 2009
dontbother10
  • 2220 Answers
SOURCE: Gas, Oil Mix ratio for McCulloch Eager ******
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Posted on Sep 28, 2009
Fuel line is leaking gas on a McCulloch Super Airstream IV gas blower
Yes it may take some disassembly to get there, but yes.
Nov 21, 2013 | McCulloch Garden
Super airstream iv gasblower/vac mod.no.400048-04
Awesome! So what exactly do you need help with?
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jul 12, 2013 | McCulloch 26cc Gas Blower Mcb3208
Super airstream iv gas blower/vac
Please refer to the resource links below:
Contact us
User manuals
McCulloch Service
Gas mixture for McCulloch Super Airstream IV Gas Blower/vac #16 103848
Gas mixture ratios can be downloaded using the provided links:
Contact us
User manuals
McCulloch Service
Dec 17, 2012 | McCulloch 26cc Gas Blower Mcb3208
Where can i get a carburetor for my mcculloch airstream 30cc backpack gas blower?
I recommend contacting your local authorized service center for assistance.
Contact us
User manuals
McCulloch Service
Oct 27, 2012 | McCulloch ASB3206 - Blowers - 30cc Gas...
Fuel ratio for mcculloch chainsaw se 2000
Every modern chainsaw use 2% of chainsaw additive oil with gas. Use oil additive for chainsaw (not for motorcycle) because of less smoke. Its carburetor has rubber membranes for pumping of gas, and always when your last work is finished, use all gas from reservoir to protect that carburetor (if you don't need chainsaw for long times).
Aug 25, 2011 | McCulloch Garden
Need to know fuel mix for mcCulloch gladiator 550 petrol hedge trimmer
I don't know the age of this machine, but more and more of the newer units are using a 50:1 mix to satisfy the newest EPA emissions regulations. I suggest using a synthetic or synthetic blend of 2 stroke oil. ....the big box stores sell the oil...Echo one of the best. I would use synthetic and mix it 40:1. Here is a fuel mix chart to show you how many ounces of oil in a gallon of gas that is. If you make a 1/2 gallon batch of fuel mix, just use half of the listed oil amount for the mix.
http://support.mtdproducts.com/app/answers/detail/a_id/347/~/two-cycle-engine-fuel%3Aoil-mixture-chart
40:1 is 3.2 ounces of oil in a gallon of gas...or 1.6 ounces of oil in a half-gallon of gas
Jul 04, 2011 | McCulloch Garden
Pro mac 850 super cc rateing and fuel mix
Terry B
Apr 03, 2009 | McCulloch Garden
Garden Logo
288 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
