Question about Epson LQ 2080 Matrix Printer
Epson lq 2080 printer problem
Dear Sir
i have problem in lq 2080 printer it take paper from both tractor but give paper out error
  • Anonymous Dec 06, 2008
    when i set a paper in it, dont place right but always go out
    Genius:
  • 1,447 Answers
These steps apply to a Windows system.
1. Click on "Start", "Settings", "Printers".
2. Right click on the icon for your printer and left click on "Properties".
3. Click on the "Paper" tab. Here you should see a "Paper Source" option.
4. Make sure that "Tractor" is selected and not "Manual" as the paper source.
5. Once this change has been made click on "Apply" to save the change.
6. Now try printing a document.
Posted on Apr 26, 2008
Printer epson lq 2070 this printer are giving error paper out error linking the led
You may have tried to change the paper release lever position while paper was still in the printer. Return the paper release lever to the original position and eject the paper. Then change
the lever position.
Check that the printer cover is closed properly.
Feb 22, 2011 | Epson LQ 2070 Matrix Printer
HOLAS COMO NENCESITO EN DRIVER DE UNA IMPRESORA MATRICIAL MODELO LQ 2080 PARA INSTALAR EN CENTOS Y ASI PODER CONFIGURAR CON CUPS
Aqu? est?n a conductores para Epson LQ-2080. Por favor, seleccione a conductor para descargar. Adicionalmente, puede escoger Sistema operativo ver a los conductores que ser?n compatibles con su sistema operativo. Si usted no puede encontrar a un conductor para su sistema operativo, puede preguntar por los conductores para su sistema operativo en nuestro foro
http://driverscollection.com/?H=LQ-2080&By=Epson&dpage=2
Si necessita mas asistencia, permita que sepa. Si esto ayuda o resuelve el asunto, por favor lo valora y da una recomendaci?n para mi respuesta. Gracias, Jose
Nov 24, 2010 | Epson LQ 2080 Matrix Printer
Sir, I, have developed my application on windows 98 but now a days everywhere set the WindowsXp but my printer Epson LQ-2090 have not a Custom paper setting. Please tell me how I can solve this problem for...
have you created same paper size as per windows 98 custom paper size ..... if not create as same please create the same and select the printing area also in the server properties ...... in the printing preference change page size to your created page size in layout tab advance option and in paper/quality tab advance option ... and check it ....
Nov 20, 2009 | Epson LQ-2090 Matrix Printer
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
How to define a custom paper
Sir,
I, have developed my application on windows 98 but now a days everywhere set the WindowsXp but my printer Epson LQ-2090 have not a Custom paper setting. Please tell me how I can solve this problem for WindowsXp using printer Epson-LQ-2090. immediately
May 19, 2009 | Epson LQ-2090 Matrix Printer
EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Oct 28, 2008 | Epson LQ-2180 Dot Matrix Printer
Printer Epson LQ 2090 out order
Light Pattern Beep Pattern Problem
Solution
________________________________________________________
* Paper Out light An unknown or serious
* Pause serious error has occurred
** Tear Off/Bin ..... ______________________
*** Font Light Turn off printer and leave it
*** Pitch Light off for several
seconds; then turn
on the printer again
Jun 11, 2008 | Epson LQ-2090 Matrix Printer
Epson LQ 2080 Matrix Printer Logo
329 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
