Question about Weather King 10AJA2501AH Air Conditioner
Weather king Not blowing hot air out top of unit its cool not dripping water. the unit will come on and off but its not cooling the inside of my home. ??
The air conditioner is either low on freon: The compressor is malfunctioning due to a wire burned off on the side of side compressor:Or the compressor capacitor has gone bad. Good Luck, Gary
Posted on Apr 26, 2008
Why is my Weather King A/C Model #10AJA4201 not cooling house? Fan blows warm air. What is problem?
check the outside unit to see if it is running. If its not check the run cap which is the big silver round object. Make sure you are getting 240 volts to the contactor;
Sep 13, 2014 | Weather King Heating & Cooling
A/c unit not cooling house weatherking model #12AJA3601
I use a spray nozzel on my water hose to clean out the oustide coil. You can go to a local Hvac parts store and get a cleaning gun and foam to clean the coil. I just use my water hose and sprayer with arm and hammer baking soda.
Jun 03, 2010 | Weather King 12AJA4201AH Air Conditioner
No Cooling
The water pump or the float valve is not working.
Aug 02, 2009 | Fujitronic FH-797 Portable Air Conditioner
Can be the unit don't have enough gas?
Yes, you could be low on refirgerant. You should have a air conditioning technician test it.
Jun 23, 2009 | Weather King 10AJA3601AH Air Conditioner
Not cold air cool air?
Check your air filter. if its ok call the guy who installed it and have him fix the leak. It prob is a bad weld joint. Check the joints on the copper tubing inside at the coil and outside at the a/c and feel around and see if there is oil leaking from the joint. If not you may have a leak in a coil or on the txv inside on the coil.
Aug 31, 2008 | Weather King 10AJA3601AH Air Conditioner
Weather King AC
The motor of your air mover in the inside unit has failed.
It is responsible for circulating the air through the exchanger and your home.
This may be located in an attic space depending on the construction of your house.
Running the cooling with this not working could cause your outside unit to operate continuously or fail.
A more remote possibility is that the thermostat has failed and is only causing the outside unit to run.
Aug 19, 2008 | Weather King 10AJA6001AH Air Conditioner
Weather king
sounds like very high humidity in the house.....is water running out the drain?
Aug 06, 2008 | Weather King 10AJA2501AH Air Conditioner
Not Cooling
Yes, the compressor might not be running. Possibly a bad run capacitor or maybe burnt wires on the contactor or compressor flags.
Oct 26, 2007 | Weather King 10AJA3601AH Air Conditioner
Weather King 10AJA2501AH Air Conditioner Logo
125 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
