Question about Compaq Armada 1700 Notebook
How or where is the memory cover - Compaq Armada 1700 Notebook
    President:
  • 2,678 Answers
Square plate on the underside in the middle (normally) held in by 1 or 2 screwa,
Posted on Aug 04, 2010
How can i make a motorola razr v3i accepts sd memory card 4gb
    • 1 Hold down the "End Call" button for several seconds to turn the phone off.
    • 2 Remove the battery cover. Turn the phone over and push the clamp on the backside of the unit. The cover should slide up easily; remove it and set it aside.
    • 3 Locate the memory card slot. It is located directly under the battery under a black cover.
    • 4 Pull out the black cover gently to reveal the memory card holder.
    • 5 Slide and press the memory card into place.
    • 6 Replace the black cover on top of the memory card by sliding it back over the card and pressing firmly in place.
    • 7 Close the battery cover; place the cover on its grooves and push gently until you hear a click.
    • 8 Turn on the Motorola phone. If the memory card was installed correctly, you can save contacts and other data immediately.
Apr 11, 2012 | Motorola Mobility RAZR V3i Cellular Phone
RAM upgrade
(1) flip the Notebook/Laptop PC over - see Fig.1 below
(2) find the memory cover - it really easy to find in this photo.
Fig.1 Toshiba M35X bottom view - the memory cover is seen at center left and secured by a single screw.
(3) remove the (1) screw securing the memory cover.
Fig. 2 Toshiba M35X laptop shown with memory cover removed and HDD (Hard Disk Drive) removed, and with the HDD cover flipped up.
The RAM (SO-DIMM boards) are visible at center left.
The HDD cover is seen at the bottom of the photo.
(4) Using proper anti-static/static control techniques, clip alligator clip or your anti-static wrist strap to a frame ground of the laptop at an I/O connector or frame ground under the HDD cover.
(5) carefully remove (2) old 256 MB SO-DIMM DDR333 memory modules.
Store old memory boards in the anti-static plastic baggie in which the new memory boards were shipped.
(6) install (2) new 1GB SO-DIMM DDR333 boards, for total of 2GB of system RAM.
(7) reassemble system, and boot OS (operating system).
The laptop's ROM BIOS will auto-detect the new RAM and begin a standard POST (Power-On Self Test).
(8) If OS is MSWindows, it will also auto-detect the new memory, and allocate it to application software.
The technology of the Toshiba Satellite M35X-S349 memory module is called
DDR333, meaning DDR (Double Data Rate) SDRAM (Synchronous Dynamic RAM), at a memory bus speed of 333 MHz.
The Form Factor of the DDR memory card is SO-DIMM, which stands for Small Outline DIMM (Dual In-line Memory Module) (see photo).
Reference: http://en.wikipedia.org/wiki/DDR_SDRAM
Reference: http://en.wikipedia.org/wiki/SO-DIMM
Fig.3 Each 1GB SO-DIMM DDR333 memory module will look like this one.
The Toshiba Satellite M35X-S349 supports a maximum of two SO-DIMM memory modules.
Each memory module can hold (a) 256MB, (b) 512MB, or (c) 1GB,
in the SO-DIMM Form Factor compatible with the Toshiba M35X-S349 Notebook PC.
Dec 03, 2011 | Toshiba Satellite M35X-S349 Notebook
How to remove memory card from camera
Confirm the power-on lamp and the monitor are off and open the battery-chamber/ memory card slot cover. Be sure to turn off the camera before opening the battery-chamber/memory card slot cover.
Removing Memory Cards 1 Before removing memory cards, turn the camera off and confirm that the power-on lamp and monitor are off. 2 Open the battery-chamber/memory card slot cover and press the card in to partially eject the card. 3 The card can then be removed by hand. Do not attempt to remove the card at an angle.
Insert the memory card.
4 Slide the memory card in correctly until it clicks into place. 5 Close the battery-chamber/memory card slot cover.
Oct 08, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
Need to install memory on a veriton Z290G desktop but dont know how to open the computer
1 Turn off your computer and all the peripherals connected to it before
opening it. Then unplug all cables from the power outlets.
2 Place your computer on a flat, steady surface. If your computer is in the
vertical position, rotate the plastic stabilizers and lay your computer on its
side.
3 Turn the screws counterclockwise to release the cover.
4 Hold the sides of the cover with both hands.
5 Slide it back about an inch and then gently lift it upward to detach it.
6 Remove the side panel.
7 Locate the memory DIMM socket on the mainboard.
8 Press the holding clips on both sides of the memory DIMM socket outward
to release the memory DIMM (a). Gently pull the memory DIMM out of the
socket (b).
9 Align the memory DIMM with the socket. Press the memory DIMM into
the socket until the clips lock onto the memory DIMM.
The memory DIMM sockets are slotted to ensure proper
installation. If you insert a memory DIMM but it does not fit easily
into the socket, turn the memory DIMM around and try to insert it
again.
10 Align the cover's hinges to the housing frame; then gently push it in to
slide it back into place.
11 Secure the cover with the screws.
Oct 03, 2011 | Acer Veriton Z290G 185 320GB
Where are the memory slots
On the bottom of the laptop there should be a couple panels with icons. Look for one that looks like a rectangular ghost from Pac-man. That's where the memory slots are.
Feb 23, 2011 | HP 6720s PC Notebook
Can not install additional Memory
you ONLY require phillips screwdriver for OPENING memory cover donot disturb the cpu and other components as this can create problem with the circuit if you are not a techenician. Install the same type ,speed and frequency of memory matching with the originally installed
Jun 06, 2009 | Lenovo 3000 N500 Notebook
Toshiba satellite 310 series (china)
Power unit off. Disconnect AC power. Remove battery. Remove the memory cover screw, memory cover and the memory modules. Peel back mylar from JOPEN1 solder pad. Short JOPEN1 solder pads for 30 seconds. Replace mylar. Replace memory modules. Replace battery. Power up unit. If all is well, replace memory cover and screw.
Aug 16, 2008 | Toshiba Satellite A135-S2276 Notebook
Removing cover on Acer 5720z to access RAM
Download Aspire 5720 User Guide. Extract the .zip file and open the User Guide Acrobat File.
You can finr info on Installing memory on page 75
ftp://ftp.work.acer-euro.com/notebook/aspire_5720/manual/EN.ZIP
Follow these steps to install memory:
1 Turn off the computer, unplug the AC adapter (if connected) and remove
the battery pack. Then turn the computer over to access its base.
2 Remove the screws from the memory cover; then lift up and remove the
memory cover.
3 (a) Insert the memory module diagonally into the slot, then (b) gently press
it down until it clicks into place.
4 Replace the memory cover and secure it with the screw.
5 Reinstall the battery pack, and reconnect the AC adapter.
6 Turn on the computer.
The computer automatically detects and reconfigures the total memory size
Regards
Mike
Mar 22, 2008 | Acer Aspire 5610 Notebook
Memory card
1>Open the back cover then remove the memory card.
2>Then take the memory card as well as the back cover
Jan 09, 2008 | Nokia 5300 Grey Cellular Phone
Compaq Armada 1700 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
