Question about West Marine Marine 200SS Propane Grill
My food is covered in black smoke. The whole inside of the grill is also covered. I just cleaned gril with warm water and a brilo pad. (no soap) Could it be bad propane
  • 700 Answers
You described exactly what never should be done... never use water to clean your grill.
Described symptoms indicate insufficient air supply to the burners, please remove burners and dry clean them with wirebrush and blow them with pressurised air if available to remove dust and rust particles, check if all holes are free of debris, water caused bit of rust to clog these holes. This cause insufficient air supply and in return, unburnt fuel cause sooth to appear on all surfaces, including food.
Grill after use should be just wipped off with old newspapers, fat prevent grill from rusting, when you start grill next time, you just splasch it with beer (no joke!) and whipe off excess. Acids and alcohols in beer will dissolve stale fat and clean whole grill area, beer as well will enhance flavour of barbecued food as well.
This advice is true not only for your particular grill model but for any grill or barbecue, regardless of mode of operation, be it propane, gas, electric, wood or whatever heat source you use.
Hope your next food will be delicious, that is recipy for my best teriyaki (marinade) for your meat:
Produce:
1 tablespoon freshly chopped ginger
1 freshly chopped medium size onion
2 cloves freshly crushed and chopped garlic
2 tablespoon honey
1/2 cup soy sauce (japanese or chinese!)
1/4 cup of water
Method:
Mix all ingrediens well, slice your met and add to mix, leave in cold for at least half hour (I prefer for about 4hours), skew and use as a shashlik marinade, or just as marinade for your grill steak, delicious anyway :-)!
Hope recipy will brighten your day.
Posted on Aug 06, 2010
What is a good way to clean up the master built smoker with glass door
I found that warm soapy water and a scrubby pad works pretty well. Try cleaning it after you have completed a smoke as the humidity inside the smoker tends to loosen up the grime. If it has been sitting cold for a while it is really tough.
May 11, 2016 | Grilling
Oven ( with combined grill) is very smokey and smelly
Your oven is one of the most-used appliances in your home, and when you use it for preparing strong-smelling meals, like fish or for curing jerky for instance (I speak from experience on the latter), you can be left with an oven that emits bad smells into the rest of your food for weeks on end. You have a spill in the oven. Wait until the burners are cool to clean them only with warm soapy water (no chemicals) and clean inside the oven. Like a self cleaning oven, it's only at high degrees it will "burn" off the food spills and will cause smoke. Shop Appliances and Furniture for your home from Appliances connection online store.
Jan 07, 2014 | Hotpoint Ovens
Unable to eliminate odour from previous cooking despite the fact that I wipe the microwave with a soapy cloth & then with a clean cloth each time to Microwave is used
  1. Fill a plastic bowl with 1 qt. of warm water. Add 2 tbsp. of liquid dish soap and 1/4 cup of chlorine bleach to the water. Thoroughly mix the solution.
  2. Dampen a clean cotton rag in the solution. Wipe all inside surfaces of the microwave with the soapy rag to remove food debris and stains. Scrub stubborn residue with a nylon scrub brush.
  3. Moisten another cotton rag with warm water. Wipe the microwave surfaces with the rag to wash away soap and loose food debris. Thoroughly rinse the inside of the microwave.
  4. Dry the microwave's interior surfaces with paper towels. If odors remain in the microwave, fill a microwave-safe bowl with 1 cup of cool water. Add to the water 2 tbsp. of baking soda, half of a chopped lemon (including pulp and rind) and four whole cloves.
  5. Place a microwave-safe plate on the microwave turntable. Set the bowl on the plate.
  6. Heat the microwave on high for three minutes. Operate the microwave according to the manufacturer's directions. Keep the bowl in the microwave for 15 minutes.7
  7. Remove the bowl from the microwave. Wipe the microwave's interior surfaces with clean paper towels to remove steam moisture.
  8. Leave the microwave door open overnight to completely air out any remaining odors.
  • Sep 05, 2012 | LG LTM9000 Microwave Oven
    Changed gas grill burner, now everything cooked is black on outside
    1) Sounds like you may have a smoking issue. Find the cause of the smoke and it should resolve the blackness issue.
    2) Is everything clean? if not clean grill and if you have cover over burner under grill clean that as well.
    Aug 05, 2011 | Fiesta 240 Grill
    How do you clean the burnt on food inside the base of a crock pot with a removable crock?
    I have the exact same problem! I cooked soup that slowly boiled over the edge and burned inside the base. I know you can't soak it and I don't want to ruin it. Help!
    Oct 04, 2010 | Nutritionist 10 Cup Rice Cooker RA10NR
    How do I get my panini maker clean again
    From the Owners Manual:
    Before cleaning, switch the grill off at the on/off button, switch off at the power outlet and unplug. Allow your Professional Grill to cool before cleaning. The appliance is easier to clean when slightly warm. Always clean your Professional Grill after each use to prevent a build up of baked-on foods. Wipe cooking plates with a soft cloth to remove food residue. For baked on food residue squeeze some warm water mixed with detergent over the food residue then clean with a non abrasive plastic scouring pad.
    May 24, 2010 | Breville 800 Class 800GR Indoor Grill
    How to clean/pull out reservoir in bottom of fridge?
    If the instructions are different than below,I will need you model number. Water Tank Assembly (some models)
    1. Remove crisper drawers from fresh food compartment.
    2. Remove hex screw holding water tank to rear
    bulkhead.
    3. On rear of cabinent remove hex screws holding water
    valve cover plate.
    4. Remove plate and tubing away from cabinet to expose
    water valves and tubing.
    5. Disconnect water tube from secondary valve coming
    from water tank, remove compression nut from tubing.
    6. On front of unit remove toe grill and disconnect water
    coupler going to water dispenser
    7. Remove compression nut from water tubing on cabinet
    side of connection.
    8. From rear of cabinet pull water tube out of conduit
    going to dispenser.
    9. From inside of fresh food compartment pull tubing up
    and out of cabinet to complete removal of water tank.
    10. Reverse procedure to reassemble.
    To clean I would use Clorox and warm water and rinse well before replacing. Thanks, Sea Breeze
    Apr 18, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
    Clean stainless steel grates with wire brush
    wire brush, heat up grill to warm and clean with wire brush. After you get the built up food and grease off remove grates and clean with soap and water to finish the job.
    Sep 03, 2009 | Grilling
    West Marine Marine 200SS Propane Grill Logo
    213 people viewed this question
    Top West Marine Grilling Experts
    Paul Carew
    Gary Kenady
    Gary Kenady
    Marvin
    Marvin
    Are you a West Marine Grilling Expert? Answer questions, earn points and help others
