Question about Kenmore 46133 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
Oven element doesn't work, the ohm meter test them ok
  • 50 Answers
On electric there may be a thermostat or fuse trace the wires to see if they run straight to oven or to a fuse on back of oven or under cook top. if comes str8 off the board to element just check volts.
Posted on Aug 04, 2010
My convection oven ring does not work
These tend to crack and "unzip" because they are such a tight circle... Kill the power, and meter the ring element for ohm's resistance. If the element tests ok, check the wires to the element for overheating, and if those look fine, remove the control board and look for burnt solder joints where the relays are mounted. Multimeter DM10T
Feb 22, 2015 | KitchenAid Kitchen Aid KEBS177SBL Single...
How much would it costs to replace heating element on Whirlpool gas oven.
I would not replace the elements just yet it may be ur oven safety valve, u can test the elements with a multi meter for continuity and ohms..
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. ( by placing the each of the meter prongs on each end of the heater element connectors) If the element is burned or no longer has continuity, it will need to be replaced. Depending on the manufacturer of the element, you will normally read between 19 ohms and 115 ohms
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
I offer free advice bcuz God is so good!
Jul 15, 2014 | Whirlpool Ovens
U1442 main oven not heating
If you are sure there is 220v going to unit, it most likely is element or click / control. If you have a ohms meter, you can test the element
Sep 07, 2017 | Neff U1721 Double circotherm Electric Oven
My oven doesn't work at all on the bottom while the top works fine
1.Even a bad relay door switch will hinder your oven from operating.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
The bake element
Sep 06, 2011 | Belling XOU487 Electric Double Oven
The oven internal light remians on all the time and now the oven doesn't heat up
1.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
2.
3.Even a bad relay door switch will hinder your oven from operating.
THINGS TO CHECK:
the broil element
The bake element
Jul 12, 2011 | De Dietrich DOP390 Pyrolytic Electric...
Grease fire in oven. elements would not come back
First verify 220 volts to the range where the cord connects.
Second,unplug the range and remove the element again and using a volt/ohm meter set for ohms or continuity check the element. No reading is a bad element.
Third, if power is OK and the element reads continuity check for power in at the oven control in the control panel.
Set for Bake and check power Out of the oven control.
No power out is a bad element.
If the control is OK,remove the oven temperature sensor and with the meter check for 1100 ohms +or- 25 ohms.
If not correct,replace the temp sensor.
Mar 18, 2010 | Roper FES330 Electric Kitchen Range
Oven heats very slowly (Jenn-Air JGS9900BDS). Cooktop works fine. Broiler works. No error codes.
hi, Could be a bad bake element or a bad temperature sensor. If the element will glow bright red/orange with no hotspots it is OK. Take a volt/ohm meter set for ohms and check the temp sensor. If less than 1050 ohms replace it.
NephetZ
Jul 08, 2009 | Jenn-Air JGS9900BDS Stainless Steel Gas...
Oven not working. fans working no heat
You can test an element by using an ohm meter . Isolate (disconnect the two wires) and test it. It should have a fairly high resistance . low resistance means partly shorted.  zero resistance(no meter movement) means burned open.
Jan 02, 2009 | Ovens
Radiant heating elements
Check the element with an OHM meter.
This is not rocket science and an OHM meter can be used for many things. Any good appliance parts place, even Wal-Mart will have a meter which can be set to test AC/DC, OHM's etc. Set the meter on OHM setting and touch the two leads on the meter together, you will see the meter arm move. This is simply a test for continuity. Now take the element out of the Range, touch one lead to one end of the element and the other lead to the other end. If you do not get any reading then there is a break inside the element and must be replaced. If you get any reading at all then the element is good and the eye switch must be replaced.
There are some parts which require knowing how many OHM's but in this case you just need to check for a break inside the element (continuity).
You can check an extension cord this way or set it on the volts setting and check batteries. all kinds of fun.
Dec 17, 2008 | GE Profile JSP47 Electric Single Oven
Broken oven
First, verify it is the problem. (A working element has a conductive core, or wire, all the way through it). If the core wire is broken, it is defective. To verify it is broken, use an Ohmmeter - if value is above 500 Ohms the core is likely broken. Replace it.
To test without an Ohm meter, use a flashlight bulb and flashlight batteries, some wire and run the loop through the element. If bulb lights, core is ok.
If broken, take it in to any small appliance store as most oven elements are VERY similar. Likely they will have one in stock. They will be cheaper than over the internet.
Mar 25, 2008 | Kitchen Ranges
Kenmore 46133 Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range Logo
101 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
