Closed in 2inches on each side. - Televison & Video
  • twelvedad Aug 05, 2010
    The tv is a phillips/magnaox mod 9p5034c103. The problem no doubt is in the horz. circut
    I thought that youall had experts that would tell me how to fix the tv.Your expert advice is not worth two cents. Return my money please.
  • 1,476 Answers
After reading your rant I couldn't help but answer your misguided reasoning. 1st this site has the best troubleshooters you will ever find, I know because I have seen their posts. 2nd it does not mean that it is a horizontal problem. Obviously you do not understand the digital TVs of today. In the past I might agree with you but now it is more than likely a control or A/D problem. 3rd You would not be able to troubleshoot the board and would have to replace one or possibly more anyway. 4th. Doesn't sound like you could do that.
By the way. This advise is free. You get better service if you don't put the guy down that is trying to help you.
Thanks for using FixYa.
hardrocko
Posted on Aug 05, 2010
  • 12,061 Answers
This is a horizontal Width problem, usually caused by a lack of drive voltage to the screen. usually because of a power supply fault, or a faulty component in this drive circuitry. There is no realistic "Home Fix".
So, it is nearly always my professional opinion that one should always get a "Quote" from the manufacturers recommended service center, Toshiba in your case, please contact a local or head office and ask for a referral to an Authorised service center. I cannot stress how important that last point is. It is even worth the cost of shipping. You see an authorised service agent, will have trained staff, trained on their brand, also they have first hand access to parts, original parts. This will actually save you money and ensure you can actually get it back fixed. Of course asking for a "Quote" also gives on the option of repair or replace.
    Guru:
  • 374 Answers
I think you may be speaking about the aspect ratios on the Tv
What model TV do you have??? I can further explain how to change the ratios to fit the TV better and make the picture fit while keeping the content looks good.
Also, what kind of connection do you use and what kind of feed??(HD or normal digital)
Posted on Aug 04, 2010
Fuse blew as garage door was closing.Door slammed shut ,now only goes up 2inches then closes when switch touched !!!
Sounds like it may be a broken spring. Look above the door at the coils on the steel rod and see if there is a separation of the torsion springs. Or if extension spring it will be hanging down on one side above the tracks. If it is a broken torsion spring I would advise calling someone with experience. If not what is the make and year of opener?
Aug 16, 2011 | liftmaster Chamberlain Garage Door Opener...
I've been trying to find the ambient temp sensor on my 2002 ford taurus, can't find it. 3.0L/V6 GAS ENGINE.
The Amibient temp sensor should be located, in the front of the car, close to the hood latch. Let me know how you make out. It is plastic and black in colour about 2inches in length and has around 2 or 3 wire connection to it.
Good luck
Jay
Jun 22, 2011 | Ford Taurus Cars & Trucks
My sunroof closes all the way except for about 2inches at the end. any help?
There are springs/clips on both sides where the sunroof closes, if they are worn out/damaged/loose then it will not close properly/all the way. Inspect them while someone opens and closes your sunroof to identify the problem
Mar 04, 2011 | 2004 Ford Taurus
Where is fuel filter
There is an in-line fuel filter under the frame on the passengers side about 13inches forward of the rear wheel well. It is a canister about 4inches long and 1 1/2inches in diameter
Oct 23, 2010 | 1995 Buick Park Avenue
Cd tray will not open
Hello, look closely at the front of your cd drawer and you will see a small hole. If you straighten out a paper clip so you've got about 2inches of straight wire, push this straight bit of paperclip carefully into the hole until you meet resistance then push firmly. This will cause the drawer to open. The more you push on the paperclip the more the drawer will open enabling you to retrieve your cd.
Regards,
Nicam49
Oct 16, 2010 | Computers & Internet
SIR ,I GOT ACER E725 LAPTOP WITH S.NO.LXN780C0099463051D1601,ACTUALLY WHAT HAPPEND IS IN MY LAPTOP SCREEN DOWN SIDE(2INCHES)BLACK SPOT CAME WHATN IS THE CAUSE PLS REPLY ME SIR
they are probably dead pixel, try using the application from http://www.jscreenfix.com/. if it doesn't remove it, then there is nothing you can do about it other than replacing the lcd
Aug 27, 2010 | Acer eMachines E7254520 Notebook PC
My sable loses power after driving for a short time about 15 miles
several things could be problem 1st check your fuel filter it is on drivers side under car should be round about 2inches around or so if its new, then could be injectors cloged up i would get lucas injector system cleaner and try it if it is electral power i would have the battery and altanator checked
Apr 15, 2010 | 2000 Mercury Sable
Where is the heater resister located on a 2003 envoy
out in engine compartment on the passenger side to the right of the fan blower motor has a plug with four wires size is 2inches by 3 inches with 2 screws holding it at back of engine compartment towards windshield.
Jan 11, 2010 | 2003 GMC Envoy
How to get to heating element on dryer
the top will lift up put a putty knife in 2inches from the side and push in and release the tabs the element is in the back it looks like a spring
Nov 29, 2008 | Maytag Performa PAV2200
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
