Question about OKI C5100n Laser Printer
Oki c5500 toner sensor error 543:k - OKI C5100n Laser Printer
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 123 Answers
Hello Bryan !
The error 543:k usually comes up during initialization, and it happens whe the printer is not able to recognize the a cartridge or the drum. I have a C5500 my self with that same problem, after hours of research over the internet i fixed my problem following the instructions on this links:
http://www.katun.com/downloads/oki-c5100tnrcartiis.pdf
and
http://www.okic3400.co.uk/index.asp?menumode=0&content=sensorerror
If this doesnt help try doing a reset to the sensors on the printer following this steps:
1. Turn machine on while pushing and holding the (+/-) menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Press (- or +) button until (“ENGINE = PARAMETER SET 2”) is displayed.
6. Push Enter button
7. "TONER SENSOR = ENABLE" is displayed.
8. Push Enter button
9. Press (- or +) "TONER SENSOR = DESABLE" is displayed.
10. press "ON-LINE/CANCEL" buttons at same time.
11. (*) is displayed.
12..... READY
You can try an NvRam (Hard reset) :
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
If you need something else just let me know
Bryan
Posted on Aug 04, 2010
2 Suggested Answers
pdouglasss
  • 125 Answers
SOURCE: 540 : y toner sensor error
Hi moneybaggz52:
Here is your problem.
Symptom:
When setting up a brand new C5100n or C5300n out of box, a toner sensor error is encountered.
The printer can display any one of the following errors:
543K: TONER SENSOR ERROR
540Y: TONER SENSOR ERROR
541M: TONER SENSOR ERROR
542C: TONER SENSOR ERROR
Cause:
This generally can be caused by two things.
1. The toner cartridge lock lever is not in the correct position.
2. The Transfer Belt lock levers are not in the correct position.
Resolution:
Check the appropriate toner cartridge lock lever (Shown below) and make sure that it is in the correct position.
0.110?openelement&fieldelemformat=gif 2.1ac?openelement&fieldelemformat=gif
CORRECT POSTITION INCORRECT POSITION
Check both transfer belt lock levers (Shown below) to ensure that they are in the correct position.
5.2eea?openelement&fieldelemformat=gif
CORRECT POSITION
10.4086?openelement&fieldelemformat=gif
INCORRECT POSITION
Hopes this helps
Posted on May 24, 2009
543:K toner sensor error. How do I fix it?
Hi dianabusk:
You have a bad K (Black) toner cartridge or the sensor is dirty,the sensors are located on the toner cartridge and in the machine where the toner cartridge seats. Try cleaning the sensors and/or replace the K (black) toner cartridge. The sensors are a silver color.
Hope this helps
Sep 26, 2009 | OKI C5150n Led Printer
Hi moneybaggz52:
Symptom:
Cause:
Resolution:
CORRECT POSITION
INCORRECT POSITION
Hopes this helps
May 24, 2009 | OKI C5500n Laser Printer
Toner sensor problem k toner 543
Try reseating the toner cartridge, it might not be in good. Reseat the whole drum unit (the part the toner fits into).
May 03, 2009 | OKI C5150n Led Printer
Fatal error 980 OKI C5500 printer
I had a paper jam and removed the jammed papers. The paper jam cleared and then the Fatal Error 980 appeared. OKI C5500 printer
Mar 15, 2009 | OKI C5100n Laser Printer
Oki Printer c3200 error code
Suggest you order a black drum, which may include a black cartridge. Replacing BOTH the cartridge and the drum should solve the sensor problem, then you can swap parts to isolate where the problem is.
May 27, 2017 | OKI C3200n Led Printer
Clean the sensor. Reset the printer and that should help you with this error. If thet doesn't work replace the toner cartridge.
Sep 01, 2008 | OKI C3200n Led Printer
543 K: Sensor Error
I had the same problem, after lots of work and fooling around..............Place a piece of white paper in the window where the sensor looks
Jun 18, 2008 | OKI C5200n Laser Printer
Toner sensor error
After replacing a bad drum and toner cartridge, I'm receiving a 543: K Toner Sensor Error. It won't go away, we can't print :)
So i know its not a starter cartridge, and i've 'utilized' OKI's site for all its worth. Was hoping someone knew a possible solution. Thanks!
Feb 11, 2008 | OKI C5200n Laser Printer
Toner sensor problems
On the base of machine after removing drums and transport, there are 4 sets of 3 pins that connect to left hand bottom of each drum, these can get toner on them and not make proper contact, each set of 3 pins just pop out with the help of a flat blade, out of base to be cleaned. in yout case just switch the set under the cyan with another lot from different colour.
I am taking it that you are using genuinne non imported oki drum and toner. If this doesnt fix your problem then you must have fauly drum/toner
Nov 13, 2007 | OKI C9300 Led Printer
OKI C5100n Laser Printer Logo
2,764 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
