Question about Ashton Digital WRUB-2011i 802.11g/b Wireless Adapter
Ok, so I have an Ashton Digital Wireless USB network device, which I have looked all over for drivers that will work properly with Windows 7 64 bit... Can somebody help me please? Air Dash WRUB-2011i Model wn220 F C C I D QDWWN 220
2 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: How to setup Ashton Digital Airdash Wireless Adapter without manual.
There is no support for the wireless adapters but if you click the link below for the driver, but you have to register free first to get it. http://list.driverguide.com/list/company2332/index.html When you download the driver, install it then connect the adapter to a free usb port and the hardware wil be recognised and the driver installed. Make sure in that all your computers have the same network name, either 'Workgroup' or 'Home' by clicking my computer icon, right click, then properties and look at computer name and if any are different you can change the name in here to be the same as every pc you wish to connect to the network. I presume you have a wireless router, so go into your routers settings and look for a DHCP section where you need this to be enabled to automatically assign ip addresses to each of your adapters. The adapters will find any wireless connections within it's area and show you in a pop up window, you then need to click on your home connection and enter the security code numbers if you have set up security on the connection, click connect and you should now be able to surf the net.
Posted on Jun 28, 2007
Problem with setting up a wireless connection using the AM10 USB Wireless Network Adaptor. The device is listed in Device Manager as working properly, but under Network Connections, the status for the...
Looks like, you are installing in vista or Windows 7..Sometimes in these OS , it needs elevated privilages..Try to enable in Network connection by clicking RIGHT CLICK on network icon & run as Administrator privilage..OR try to install with Administrator privilages...I hope this will work
OR if there is driver problem,,Try to download drivers from the below link
http://homesupport.cisco.com/en-us/wireless/valet/AM10
Please rate & vote if you like solutions
Thanks
Sandeep
Mar 13, 2011 | Linksys Valet by Cisco AM10 Valet...
Installed this driver and everything installed ok except it can't aquire network address
Computer not able to acquire the IP address is not an issue with the wireless adapter all-together. Check the device status for this Wireless N Mini USB wireless adapter under the Network Adapter category. It should say: This device is working properly.
If this is the case, you may check for any driver updates with the manufacturer.
Check for any Firewalls like Norton, McAfee, Zonealarm, Comodo, etc. Turn them off or configure them properly.
Update the operating system using Windows Automatic Updates.
On the wireless transmitter, try changing the wireless security type as "WEP" preferably 64-bit WEP with a hexadecimal password.
Finally, if even that doesn't help, try to assign static IP on the wireless network connection by right clicking on Wireless Network Connections and click Properties. Now ensure a tick next to Internet Protocol version 4. Highlight it and click on Properties on this page. Refer to your wireless router or wireless modem vendor to get this assigned.
For further clarifications, please revert!
Thanks for asking.
Regards,
Arvind S Iyer
Oct 08, 2010 | EnGenius EUB9707 Wireless N Mini USB...
I don't have the software to install - can I download it?
Yes you can download and install it. IF you know the link you can download it or you can find the software to download from this link below
http://www.edriverdownload.com/ashton-digital-wrub-2011i-driver.html
Jul 01, 2010 | Ashton Digital WRUB-2011i (Twin Pack)...
My Wireless connection status page is blank. Same with the wireless connection properties page and the "view available networks page"(or wireless network connection page) can't open, all it has is the top...
The AWL number was what I was looking for, thanx.
If the AirLink utility is running, there is where you would check the status. The way to set it so that the connection shows in the 'network connections '
Go into your Control Panel, then go into Network Connections
Right click on your AirLink wireless adapter and click “Properties”
Click on the “Wireless Networks” tab
Put a check in the box next to “Use Windows to configure my wireless network settings”
Click “OK”
If you wish to go back to using the AirLink101 802.11g Cardbus Utility, go back into the “Wireless Networks” tab in your AirLink adapter’s properties and remove the check mark next to “Use Windows to configure my wireless network settings”
Aug 03, 2009 | Computers & Internet
Ashton digital maximate 420
install the driver of your modem. is there a modem on your laptop? you can buy an external modem or a usb wifi device for wireless.
Apr 29, 2008 | Ashton Digital Maximate 420 Notebook
WRCB 1011r
It is possible that the card is failing. Think about anything that has changed in your network setup. Have you changed wireless routers, or changed any settings. Have you recently updated the drivers for this card. Do you use the wireless adapter at other access points or only a single one?  One thing you could try is to uninstall the device, then reinstall it. Also look for newer drivers if they are available.
Mike
Oct 30, 2007 | Ashton Digital (WRCB-1011R) Wireless...
Jun 02, 2007 | Ashton Digital WRUB-2011i (Twin Pack)...
Windows displays a message saying that the device is not recognized
Ok, there is no longer support for these adapters, and there are plenty of problems with getting them going and keeping them going. I would get a refund if they are new, if not don't waste any more time with them and buy a more user recognised product.
Jan 11, 2007 | Ashton Digital WRUB-2011i (Twin Pack)...
After connecting to the usb, led lights up, then off, windows does not detect it.
Is the hub you mention, an extension from another usb port only, as the adapter may need to be powered and require a AC/DC powered hub to work.
Jan 10, 2007 | Ashton Digital WRUB-2011i (Twin Pack)...
Lost cd
The only place you will get the driver is from www.driverguide.com although you may have to register free with the site first.
Dec 06, 2006 | Ashton Digital WRUB-2011i 802.11g/b...
Ashton Digital WRUB-2011i 802.11g/b Wireless Adapter Logo
448 people viewed this question
Top Ashton Digital Computers & Internet Experts
David Payne
David Payne
Masood Rasool
Level 1 Expert
Are you an Ashton Digital Computer and Internet Expert? Answer questions, earn points and help others
