Question about Vodavi 30-Button XTS Telephone
Can't get outside line
Employee hit wrong keys when trying to dial out. Now I can't get a dial tone for the outside line. We can receive calls just can't make any out.It's like she put a lock-out key on it.This is a Vodavi 30 buttonphone thanks
  • keyur_a_pate Apr 30, 2013
    I have Vodavi 8003-00 system as well. I have same issue where we can receive calls but can't dial out. when i press "9" its a dead silence (well some Static noise). Any suggestions on how i go about looking at what theproblem is and possible solution?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 448 Answers
If this hasn't been solved, I am a Vodavi certified tech. Give me a ring
Posted on Jan 08, 2009
How can I get set the outside line back on Line one and get the dial tone back?
try entering a 9 then the number you want .if that does not work try every number alone till you hear a dial tone
Jan 27, 2015 | Panasonic Lands Phones
M7310 Non-Stop Dial Tone
Intercom button/s provide dial tone when they are pressed. They are required to call other phones on your system.
Sounds like your button is stuck or issue with the motherboard.
Dec 17, 2012 | NorStar Meridian M7310 Phone
How do I activate the handsfree mute button on Norstar M7310? When I push outside line, then handsfree, I get dial tone, but cannot dial outside number. When call is incoming, after answering, I cannot...
familirize with devices user manual whether has feature functions requested. Second, ascertain that device was least malfunctioning since acquired. normally, familirising with innovative devices makes expertise in functionality.
Jul 20, 2011 | NorStar Meridian M7310 Phone
When I hit hook to send a fax I hear a click but I get no dial tone and the same on receiving a fax MP830
You only hit hook to hear the dial tone or use the machine like a speaker phone. To send a fax you press fax start. If you can't hear a dial tone when you press hook, there is something wrong with the phone line connection, or it's plugged in to the wrong plug on the machine. The phone line goes into the one marked with an L, the other with the pic. of a phone is for an additional telephone.
Oct 13, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Can receive calls but cannot dial out on Verizon landline phone
Try punching in the number to call first THEN hit talk.. It should dial and call at that point..
Just like when making a call from your cell phn - dial the # first..
good luck ;o)
Sep 17, 2009 | Uniden DECT 6.0 Cordless Telephone...
Can't call.continuous tone at the phone when i try to make a call
Check the dial pad keys for a stuck button, if it has a hanset with its own dial pad check it as well.
If you can not locate it, try listening on the line and pushing the dail keys one at a time. you should now hear dual tomes, the one you are causing and the offending tone, when you hit the offending key there will onlt be a single tone as this button is already sounding off.Do not forgrt the special keys(# &*)
Hope this is of some help.
Ed
May 08, 2009 | Sharp UX-P115 Plain Paper Thermal transfer...
Brother Intellifax 4100 unable to send fax but can receive
Is the fax sensing the paper you put in to send out? Check the little black levers that poke into the document area. They should move freely when you touch them gently with a finger, and return quickly when you take your finger off. If it can't sense the paper it won't try to send a fax. If, when the paper is inserted, the display changes from whatever it said to anything else, the paper is being sensed.
Let's try dialing manually. Just left of the 1 key is a button labeled "Hook." Pressing that will take the telephone line "off-hook," like picking up the receiver of a phone. You should hear a dial tone -- if not, try adjusting the speaker volume with the buttons just right of the numbers. Once you get a dial tone, dial a number, whether it's another fax, or your own cell phone. As far as the phone company is concerned, your fax is just a phone, calling another phone. If you can make a call, and the phone at the other end rings, we're closing in on the problem. If you can dial another fax machine manually, you can still turn this into a fax call, assuming there's paper ready to fax. After the distant fax answers, touch the Start button, and your fax should take over. If you can't dial manually, try unplugging your fax from the phone line, and replacing it with a regular phone. Can you make calls with it? If not, the fax is no longer a suspect - you have a phone line problem.
Are you at a business where you need to dial 9 to get an outside line? It's easy to forget that detail when you're using a fax, but it has to dial out just like any other phone on the system.
If you can't get a dial tone at all with the fax, but it works with the phone alone, the main board in the fax is probably bad. If you can dial manually, using the Hook switch, but the same number doesn't work when you dial xxx-xxxx-Start, that sounds like a main board problem, too.
May 05, 2009 | Brother IntelliFax-4100e Fax
No dail tone
Check the cor and cos setting of the phone It shold have the permissions to call outside
Dec 02, 2008 | RCA 25414RE3 Corded Phone
Incoming telephone calls
Refer to your manual. It may be under RX(recieve settings). Go disable FAX/Tel SW and make sure it is fax mode only
Jan 11, 2007 | Canon FAX-B820 Plain Paper Bubblejet
Vodavi 30-Button XTS Telephone Logo
221 people viewed this question
Top Vodavi Lands Phones Experts
Oloyede Monsuru
ray gallant
vince
Are you a Vodavi Lands Phone Expert? Answer questions, earn points and help others
